Question about Canon Office Equipment & Supplies
Out put not clear,when i type *28* the problem show"the belt is low" what i must so with this problem?
  • 33 Answers
You sure its not saying the ink is low or the belt is jammed. theres alot printers out there so its hard to tell. Contact MFG to seek error code meaning if thats what its really stating. Good Luck !
Posted on Apr 15, 2014
E000003 0002 error
Check fixing thermister or heater then clear first 3 errors through *28*
Nov 18, 2013 | Canon imageRUNNER iR C2880 Color Copier
In my canon ir 7200 machine, it is showing the error E602-0003
machine off and press 1&9 then machine on .the hard disk was reset. try this
Oct 24, 2013 | Canon Service Manual For Ir 7200
Rockwell/Delta 20" bandsaw. Locked
This site has the best collection of online manuals for older Delta machines. Have a look through the list and see if you can't find one of similar vintage. Hint; if you click on the pub type heading the list will sort by machine type. Also confirm that model number is correct. There are manuals for the 28-340 that may provide the needed information. I'm afraid I'm not familiar enough with that saw to suggest a solution to the low/high speed issue.If you are running on the correct pulley positions, and they pulleys are corectly aligned, the belt tension adjusted, and the motor in good shape, I don't understand what the obstruction could be. Perhaps you neglected to adjust the belt tension when changing positions? See the guide suggested above for more on that.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 28, 2011 | Delta 28 640 20" Single Phase Wood Cutting...
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
Very low compression
Check timing belt/chain for proper alignment.
Jun 02, 2009 | 1997 Toyota Camry
When its switched on it shows me system error 000. send me a solution immidietly.
it is a fiser related error, you need to reset error code servie mode.
* 28* will put you into service mode,
then choose copeir, option, clear, then clear error, highlight that press ok,
then restart machine.
May 12, 2009 | Canon imageRUNNER 1023iF Black and White...
Why does my van squeel
You didn't say what type of pump was replaced, water, power steering, or ???
If it was the power steering pump you may be low on fluid or the belt is not tight enough. If it was the water pump it still may be the power steering belt was not tighten enough.
Go to www.youtube.com, type in power steering belt and select the appropriate video and it will show you how.
Mar 06, 2009 | 1998 Dodge Caravan
1997 Honda civic, fan belt?
It sounds like your power steering pump, not the belt. Have u checked the fluid level? If it's low it can make a 'growling' type noise. Any leaks under the car from power steering? U can check by putting a big piece of cardboard under the car at night, check where any leaks show up on it the next morning.
ålso check the belt for fraying or cracks (if u find any, replace it), also the belt tension, if it's loose, the belt may squeal (not what u describe),
Oct 23, 2008 | 1997 Honda Civic
MFC 7420 always say toner low after you change new toner
1. Open the front cover door.
2. Press the "Options" button.
3. Type *00 on the keypad.
This will clear the error message.
Enjoy!
Nov 20, 2007 | Office Equipment & Supplies
old marine
old marine
