Question about GE 24769 Futura HDTV Indoor/Outdoor Antenna
Problem with HDTV POWERED FUTURA ANTENNA 24769. Amp light goes out when connecting cable to amp. No difference in picture quality or quantity.
  • 33 Answers
Well I think you are trying get a better picture not a better stereo signal unless TV tuner is in AMP. If not try connecting it to TV dirctly but first inquire manual to make sure that is how it is sappose to be connected. But if I was a betting man thats probley what it is, but not sure what equipment your working with besides the info on atenna that you sent.. Good Luck !
Posted on Apr 15, 2014
What is the best method when using your antenna amplifier. Installing close to the antenna, or close to the tv? I have rca outdoor antenna mounted in the attic.
What I would try is replacing the co-ax cable from the antenna with the best quality you can find (not cheap), and make it as short as possible, then connect the amp. to this, then use another length of HQ co-ax from amp. to TV or recorder (if you are using one). In my own set up, I have two aerial amps, one for TV, one for DVD recorder, to ensure the best possible quality signal to each.
Feb 23, 2016 | RCA Ant751 Outdoor Digital Tv Antenna
Ameriwood 9354303PCOM instruction manual
You can find more information here http://usemyreviews.com/ge-24769-outdoor-antenna-digital-hdtv-futura/
Aug 22, 2013 | Generic L-Shaped Desk with Side Storage,...
Find fuzion digital scales fz-75 instruction manual
I have written reviews on GE HDTV antenna, please read this http://usemyreviews.com/ge-24769-outdoor-antenna-digital-hdtv-futura/ GE 24769 Outdoor Antenna for Digital HDTV Futura
Jun 05, 2012 | Office Equipment & Supplies
Went black and white rca f32648
so far no proper details are available regarding resetting this particular TV ( f32648 ) .... i have checked user manual also
have you tried following things
1 - playing different dvds (dvd player )
2 - changing different channels ( cable tv or antenna )
3 - increasing ( to maximum ) & decreasing ( to minimum ) [in menu ]
contrast colour tint black level sharpness
picture presets auto colur colour warmth
4 - auto channel searching ( cable tv or antenna )
even after these trials if picture is in black & white then it is a hardware problem - since it is a rare problem no details are available about which component might have got deffective ...... only the service engineer who opens & checks your tv can tell the exact deffective component .......... sometimes it can be loose connection ( cracks at soldering joints - hit your TV lightly with your hand on left side or right side or on top - if color comes & goes then it is loose connection problem - all soldering joints should be resoldered by service engineer ) ..... or an IC might have got deffective ......... only after opening & checking your tv mainboard exact deffective component can be identified ......
for nearest RCA service center call 1800 336 1900 ( this number got from your TV's user manual - click this link for your TV's user manual - free down load - RCA F32648 model - http://download.rca.com/FilesForRCAcom/Manuals/15491880.pdf
Nov 06, 2011 | RCA F32648 32" TV
The tv s autostore will not retune
i think in your TV...... design ..... is such that once channels are autostored it cannot be retuned ..... so you try this ...... it may work ......... disconnect tv antenna cable ( or local tv channels cable ) from your TV & then click autostoring (auto tunning ) ..... definitely it will scans (search for channels ) ..... but since no cable is connected no channels will get stored ...... but previously autostored channels will get removed ...... so now again connect your antenna cable or local tv cable & then click autostore ...... it will scan for channels .... like this you can retune ....... but remember again you may get same quality of picture which you got earlier ..... if you want better quality of picture you have to use signal amplifier (increases cables signal's strength - then picture quality improves ) .....
Nov 05, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
-wilson antenna installation diagrams for, Wilson Trucker2000 - display pictures of exactly, how antennas appear when being attached with coax cable, using stud mount between coax & antenna mount... -...
I have a wilson 5000 mirror mount. I mount it on the drivers side mirror on the upper cross arm that goes to the mirror. It is mounted on this arm with a bracket and a so 239 connector so I can undo it if I have to ,leaving the antenna connected.I can change coax and not have to worry about undoing the antenna. Remember one thing. The antenna has to be checked for SWR.each time you move it to a different spot or to a different truck.
Oct 11, 2011 | Cobra 29 LTD CB Radio
Nintendo Wii works fine on standard tv but not on hdtv.
FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
Dec 29, 2009 | Nintendo Wii Console
Sanyo HDTV 42"
'Clear' can mean different things-
The 'front end' of TV sets can differ greatly in the sensitivity of its tuner.  If you have 'snow,' then the new set is inferior to your previous one and you may need to buy an external broadband amplifier to boost the signal before it goes to the TV. The quality of antenna inputs has declined since there are fewer owners (by percentage) who depend on 'over the air' reception. Cable companies and satellite receivers supply a lot more signal than can your antenna so the input sensitivity is not as critical as it once was.
The demo sets one sees at retailers are fed a lot of signal and have for that reason a better picture than you might find after getting a set home.
Aug 04, 2008 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
GE 24769 Futura HDTV Indoor/Outdoor Antenna Logo
116 people viewed this question
Top GE Electronics - Others Experts
ka4iup
ka4iup
cwradio73
Tom Chichester
Are you a GE Electronics - Other Expert? Answer questions, earn points and help others
