Question about Garden
How do you set up a carbaretta on a flymo petrol qs46sd
It seem as if the choke has stuck,and keeps reving up,i just need to set it
    Guru:
  • 145 Answers
2 stroke or 4 stroke engine? Check out the link from "tillitson" 2 stroke carb theory. GOOD LUCK http://www.tillotson.ie/docs/techinfo_HS_US.pdf
Posted on Apr 16, 2014
2 Suggested Answers
  • 1082 Answers
SOURCE: flymo petrol mower starts but
Probably needs the carburetter cleaned out. Smell a lot of petrol? could be flooding out. Starts up but dies. No smell of excess petrol? Fuel line clogged at tank inlet, rust? Other crud? Gas gets to carb, engine starts then runs out of fuel. I dont know the flymo carb, but generally...
Start by removing the bowl under the carb, 2-3 screws. Youll need to remove the air filter box first. You should find a float tank which operates a needle valve. This can be released by popping out a pin pivot. DO NOT LOSE THE NEEDLE VALVE which will come out with it. A pointed stem which closes the fuel as the float rises. If you see a lot or just a little crud around here, that can be the problem. Clean it out with carb cleaner spraying up into the where the needle seats, also spray into every opening you see. Carefully replace the needle and float. The needle generally snaps into or is locked into the float loosely, then pin the float back in place while guiding the stem back into its hole. Replace the bowl and try to start it.
Good luck
Posted on Jun 05, 2011
Why wont my Flymo qs 46sd rev ?
does it have a throttle cable fitted?? you really dont need an idle as as soon as you release the opc or dead mans handle it will cut out anyway. engine should be reving at 3000-3100 rpm. if this mower has a briggs and stratton engine fitted, remove the air filter and check the spring and linkege is still attached to the air vane govenor
May 20, 2014 | Garden
Flymo qs46sd handbook
Flymo with wheels ?
Mar 06, 2014 | Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Flymo petrol mower starts but won't tick over.....keeps cutting out
Good luck
Jun 05, 2011 | Garden
My flymo briggs & stratton quick silver 46d
Your carb needs to be taken apart and cleaned
Jun 19, 2010 | Briggs & Stratton Garden
I need to get to carbaretta to clean but cant lift petrol tank due to petrol pipe connected. how do i turn off petrol
there is no valve to turn off on modern bikes. you will have to syphon off petrol into a safe container and can pinch hose with a small pair of mole grips or bend hose back 180 degrees and put a rubber band on
Sep 22, 2009 | 2006 Aprilia RS 125
Mower running rough
This engine may need overhauling,You seem to have either bad valves or rings, or both.
May 13, 2009 | Garden
I am looking at rebuilding a petrol flymo ( Model L300)
hello
go to a web site called diplodocs.com and type in flymo L300
it as the parts list on there
hope this helps
Mar 11, 2009 | Garden
Renault clio
Hi
There is a good chance (amongst other things) that the EGR valve is stuck open. It can easily be removed and cleaned.
However, the engine management light is the way forward. Have a code read done and it will point you in the right direction.
Regards
Geordie
Jun 13, 2008 | Renault R5 Cars & Trucks
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
