Question about Sony PlayStation Portable (PSP) Console
Oops,... i dropped my psp
I fell off a swing and landed on my psp. When i turn it on, it stays on the loading screen (the orignal blue background) and doesn't show anything, please tell me its a fixable problem.
  • 18 more comments
  • dude1199 Nov 05, 2007
    Hey, its working now, it just wont play UMDs any help there?
    It didn't work as well as I thought, it did stop the long load time, but now it says disc can not be read... help if very much appreachated
  • dude1199 Nov 06, 2007
    Cerfer, love the help, can you just put like 3 or 4 of your tricks on your next post, that way i can try back to back,... thanks so much!!!
  • dude1199 Nov 07, 2007
    yes it does light up and it does spin, so why won't it read my UMDs?
  • Anonymous Nov 13, 2007
    I droped my psp on my floor and i cannot fix it and the power button does not go green
  • DejanZ Nov 25, 2007
    i dropped my PSP in my garage concrete floor, and now it doesnt turn on unless its plugged into the wall, and when i do plug it in, it turns off by itself after only like 5 minutes of use!! when it fell the battery back holder thingy popped off and the button came off and i lost that, and my UMD and memory stick popped out too!! so now idk what to do, any help please??
  • Anonymous Dec 05, 2007
    I dropped my purse and my psp was in it everything except when i tried to play the umd it just made made a sound but it didnt play it my boyfriend replaced the lens but no luck would anyone know what else it could be?
  • dfghjdfd Dec 15, 2007
    i droped my psp and the back fell off help me please!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • malique Dec 16, 2007
    where the disc is inserted there is something hanging to the cd casing. it is silver and bent.
  • Celeste Drake
    Celeste Drake Jan 23, 2008
    i had my psp in a psp case, however i did drop it and now the power switch isnt working, its like it got disconnected from whatever it was connected to...there is no tension in the switch, how do i fix it?
  • whymike Mar 03, 2008
    i turn my psp on and it just stays as a blank green screen than i take out my game and than it takes me to my home page but after waiting for around 5 min. it says disc can't be read what should i do i dont want to buy a new psp.
  • connorz54321 Mar 27, 2008
    my psp broke when i was putting my keyboard under my bed.It hit the chord and fell.I turns on and does everything except read my umd disks.When i put them in it says cannot read disk can anyone help me
  • Anonymous Apr 08, 2008
    i dropped my psp in a toilet three months ago. it comes on but wont play games
  • boardmstr2 Apr 10, 2008
    i tried the qtip thing but it didnt work. wat wer the other solutions u mentioned
  • Selverf0x Apr 19, 2008
  • snoopy11 Apr 22, 2008
    i dropped my psp and the umd worked for a while then it said error disk could not be started and after a while it said disk could be read and i tried pressing the right trigger button but did not work i have the new psp series 2001
  • SHABMW3 Jul 29, 2008
  • Anonymous Oct 14, 2008
    i drop my psp psp while walking and everything fell out like the battry and now it wont turn on and i getttin fustrated cause its my 2nd time dropping it but the 1st on ewas not that hard can it be fixed
  • Anonymous Nov 14, 2008
    I dropped and it doesn't even power up!
  • Anonymous Dec 31, 2008
    i dropped it and now it wont read or load my umd games
  • 709 Answers
Hey Dude,
All things are fixable. Try going into recovery mode. This is done by Pressing and holding the R button when powering up the PSP. You then can press the brightness control button to see the firmware. This might help you reboot the PSP. If it is worst than this, you may consoder sending it back to Sony for repair, although they usually do not want to fix a Squooshed PSP. I would not tell them you Sat on it. You can call SONY support at 1-800-345-7669.
If you cannot get them to Repair it, you can check out my website, . I can fix it for a very reasonable price.
Posted on Nov 02, 2007
  • 1 more comment
  • Greg Stokes
    Greg Stokes Nov 05, 2007
    Hey Dude,
    Glad you got it running again. On the UMD drive. Get a Q-tip and some window glass cleaner. Lightly dampen the swab with the Glass cleaner, and swab the lens of the UMD laser. Use a dry Q-tip to dry the lens. Hopefully this will get it back to reading UMD's I have some other tricks up my sleeve if that doesn't work. just comment back.
  • Greg Stokes
    Hey Dude,
    Do not use rubbing alcohol on the Lens. That is only for Glass lens like the older Big PS2 uses.
  • Greg Stokes
    Greg Stokes Nov 07, 2007
    Press the little Black probe sticking up in the UMD drive. It is about 3/4 inch from left and 3/4 inch from top of the UMD drive. When you press it, look for the Disc spindle to rotate, and the Laser to light up and the Laser movement to occur. This will tell you a lot in what is working or not in the UMD drive.
Try letting it sit for a night if it dosent work call sony at 1800 345 7669. from Donte Bethune
Posted on Jul 01, 2008
I have dropped my PSP, when i switch it on Power light is glowing, but no display & no sound at all, after few seconds power light also turning off.
Plz help anybody, what can i do.
Posted on Mar 11, 2008
Try removing the Memory stick if you are using 1.... remove the battery then restart the psp without the memory stick.. if it boots up ... try using a diffrent memory stick
=)) hope that helps
Posted on Apr 05, 2009
I tryed the reboot menu and it wouldnt work and my psp slim 3000 wont read UMDs can someone plzzzzz help me
Posted on Nov 27, 2009
Psp fell ,turn psp light turns on.screen stays off
Hi first i will say sorry for that. I will recommend that you see a certified technician to fix it up, there are a few things i guess are wrong with your psp... the system of psp are fragile and should be handled with care because i think one or more parts are broken and need replacement. Cheers
Dec 23, 2009 | Sony PlayStation Portable (PSP) Console
How can you help me with my psp
try a different battery and find out if it does the same also when plugged in to the charger
Aug 19, 2009 | Sony PlayStation Portable (PSP) Console
Psp screen stays black
i think your graphic card or motherboard has been broken, try to get a replacement
Jan 26, 2009 | Sony PlayStation Portable (PSP) Console
Games not loading
try putting in a UMD that what i did for mine games works find if that dont work go into recovery mode turn off the psp system and turn it back on and hold the r button and go to configuration then go to use no umd and enable it then exit then the games should work just find.
May 26, 2008 | Sony PlayStation Portable (PSP) Console
oops..that's not going to help out too much. I'd say that your printer is really going to need some professional onsite or depot help. Dropping any computing device will upset it's mechanicals dramatically.
Feb 06, 2008 | HP DeskJet 810c InkJet Printer
Psp will not load in any games
"tap" not hit.. the back of the psp, (where the game goes in on the back) and see if that works.. that will usually get the laser to read the disk.. perhaps the umd is dirty..  only tap on it "lightly" when you hear it loading.. i know that sounds stupid, but it worked for me countless of times.
Oct 31, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
3,853 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
