Question about Bandai Toys
Hi I have a metal composite #1008 gundam unicorn prism coat, over time (1 year) it's developed some yellowing over the body parts. Can you please advise me methods to remove the yellowing? Cheers
2 Suggested Answers
beltronic205
  • 1466 Answers
SOURCE: hello, i have hinari lifestyle 800w, model number:
Can get spares from espares.co.uk..depending on age may be cheaper buying new machine...good luck
Posted on Oct 08, 2009
On my bernina 1008 the selection lever is all the way up but I want it on the straight stitch but won't move.
Are you able to remove the top cover of your 1008? The 930 has a "lid" that can be removed to access the internal mechanism. Am suspecting that perhaps the selector has seized from old oil solidifying. If able to open machine, apply 1-2 drops of liquid Tri-Flow Synthetic Lube to every place where metal rubs against metal. Do NOT oil belt or nylon gears! Be sure to move the selector dials and levers and oil those moving parts too. To help speed things up, direct hot air from a handheld hairdryer into the internal mechanics.
Dec 27, 2016 | Bernina 1008
What do optical components contain?
Glass of certain formulations to get the different wavelengths of light to focus to the same point along with coatings to do the same
Look at a cutaway image of a lens system to see the construction
Like 11 elements in 7 groups if you want the exact composition of the lenses quite secretive with their recipes for glass or plastic elements
Oct 10, 2016 | Schneider Optics Cameras
I am going to buy a 150 cc motrcycle which one is best kawasaki unicorn 160 or unicorn 150?
Hi, Sally your a regular wheeler-dealer I would go for the 160 if they are priced the same for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Owner Service Manual Kawasaki Vehicle Manuals
OEM Parts for Kawasaki
Honda Unicorn Wikipedia the free encyclopedia
Honda CB Unicorn 160 Price Specs Review Pics Mileage in India
Apr 13, 2016 | kawasaki Motorcycles
2011 Honda CB Unicorn setting ignition timing
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to Set Up Ignition Timing in Motorcycles
setting ignition timing on honda cb350 part 1
https://sajonfollprefti.files.wordpress.com/2016/07/165.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Apr 12, 2014 | 2011 Honda CB Unicorn
2011 Honda CB Unicorn Dazzler headlight not working
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chafed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil
11. Faulty voltage regulator/rectifier ground or overcharging.
Honda unicorn dazzler Multiple issues
Problems in Honda CB Unicorn
http://www.ghemedia.com/honda-unicorn-bike-service-manual.pdf
Honda CB Dazzler User Manual English here
Feb 27, 2014 | 2011 Honda CB Unicorn Dazzler
I'm cleaning my rim and for some reason it is turning a gold color. What could be the reason for this?
Can be several reasons. Some types of plating or covering is the top finish of the wheel, but the base metal is a different color and not pretty.
I have seen chromed wheels bleed down to the core behind the lead wheel weights. Those left a bronze mark in the same place and outline of the lead weights.
Now there are different procedures in producing a finish on metal. Some use an acid bath and different chemicals produce colors in metal. Sounds like the wheel you have could have been surface etched and now the top finish is rubbed down below its finish. Some makers use a clear coat to maintain the finish longer.
You should contact the Car company who made your wheel for ideas about refinishing them. Now there are some excellent spray paints for coating wheels and the cost is minimal and some use spray cans and others need air compressor spray guns. Likewise some need an adhesive base coat and some need a protective clear coat. Its all about compatible layers of coatings.
My personal experience, for instance, on my 83 GM Pontiac Aluminum rims was to use the finest grade steel wool and remove the old chipped surface by hand rubbing to clean metal. Then using Mothers products to hand buff to a brighter finish and then thoroughly remove all traces of chemicals with an alcohol wash. The top coat was a spraycan application of specific "Wheelcoat" clearcoat.
Please rate my info.
Jan 18, 2013 | Cars & Trucks
Crossfire game cheat
Hello
Mobile Suit Gundam is a popular Japanese animation show that has a number of series in its franchise. This cartoon has grown into more media including comic books, movies, action figures and video games. Mobile Suit Gundam: Crossfire was the first video game from this series to be released for the PlayStaion 3. This game was developed and published by Namco and released in conjunction with the PlayStation launch in November 2006.
Unlocking New Suits and Pilots
The Mobile Suit Gundam series is known for the vast number of robot suits that are used in space combat. These machines are piloted by humans and are the future replacement for ground and air troops. In Crossfire you are capable of unlocking many of the suits from different versions of the Gundam anime. None of these suits or pilots is available at the start of the game, so you must complete specific steps in order to unlock them as playable characters. Complete each step to unlock the corresponding character.
If you are able to reach the rank of colonel while playing the Federation storyline you will unlock the RX-78-2 Gundam suit. The Kampfer mobile suit becomes playable once you reach the rank of lieutenant colonel in the Zeon campaign. Reaching the rank of warrant general will unlock the first version of the Gundam mobile suit. Char Aznable is a special pilot that you can use once you complete the Zeon campaign mode on the very hard difficulty setting. Finishing the Federation story mode on the very difficult setting will release Amuro Ray as a playable pilot. Beating either campaign on the hard setting will unlock Fraw Bow as a new pilot. Kai Shiden becomes available as a pilot by beating either campaign mode on very hard. To unlock the Hildolfr Gundam suit you must reach the rank of brigadier general on the very hard setting. You have to reach this rank in the December time period before completing the unidentified enemy mission. A successful completion of this mission under these circumstances will also reveal the Gelgong mobile suit. The Xamel mobile suit becomes available in the December month of the Federation campaign. You must be playing on the very hard difficulty setting.
These new pilots and mobile suits have special abilities and strengths not available to those which are initially available for use.
Sep 26, 2011 | Crossfire
Paint colour for 1973 tx750 yamaha
Can duplicate the 73 paint but it is gold candy over silver metal flake.
  1. apply Grey primer sealer
  2. apply silver base coat, apply 3 coats
  3. apply silver metal flake mixed with clear, about 3 coats
  4. apply about 2 coats heavy clear
  5. sand clear smooth because metal flake makes it rough
  6. apply about 3 coats of tinted clear (candy gold or yellow)
  7. let it dry, inspect it, wet sand with 600 or finer
  8. apply final coats of clear to all parts except the fuel tank, apply only one coat to tank
  9. lightly wet sand the tank
  10. paint the gold and black striping on the tank, don't have any stickers and paint is thinner
  11. apply 3 medium coats of clear to the tank
  12. west sand with 1200 grit and polish all parts
  13. mix huge glass of good tequila, get lawn chair, sit back and admire
hope this helps
John
May 23, 2011 | Yamaha TX 750 Motorcycles
HOW TO SLOVE THE ERCORE OF 000064 PLESES TELL ME SIR
composit power supply or DC controller pcb was faulty please check it.
or check all this connector on DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller,
developing assembly, transfer charging roller?
DC controller PCB (J301) <-> composite power supply PCB (J136)
composite power supply PCB (J130-7) <-> primary charging roller contact
composite power supply PCB (J130-1) <-> developing assembly contact
composite power supply PCB (FT133) <-> transfer roller contact
if all this are corrcet then you have to replace these pcb
Apr 06, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Feb 24, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Toys Logo
55 people viewed this question
Top Bandai Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Bandai Toy Expert? Answer questions, earn points and help others
