Question about Sceptre X20g-Naga III 20.1" LCD Monitor
When im gaming, about every 5 minutes, the screen just turns off
On my sceptre monitor. over and over again. it just turns on and off as if it's trying to adjust to something. is there a download that can fix the problem?
What type of video card do you have, sounds like it could be several things at this point. I recommend checking you have the latest video card drivers, and that your video card is being kept cool, as well as the inside of your PC case.
Posted on Jun 19, 2009
Sceptre LCD screen ..replace backlite
The lamps are integrated inside the LCD panel. What kind of problem are you haveing with the monitors? see some pictures here: http://s807.photobucket.com/home/budm/allalbums
Feb 21, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check newegg.com or orverstock.com
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
Sceptre LCD monitor blank screen, blinking power light
Something has failed or is failing in the monitor. It may be serviceable, but may not be cost effective to do so unless something has just come loose. I'm assuming you have no problems with the new monitor. Your time line is a little confusing.
Dec 13, 2008 | Sceptre Dragon Eye D219A (White) 21 in.CRT...
Sceptre X20G Naga II 20.1" Widescreen monitor
I am working on one of these for a customer. Found leaky cap on 5 volt power supply. replaced it, still no backlight. Looked at the inverter with an o-scope and it runs for a few seconds then shuts off. I hooked a ccfl across each of the transformer secondaries on the inverter and it lit up! I believe the problem is failed ccfl units. There is plenty of voltage there to light them up, I have an rf burn on my thumb to show for it. I have not looked at the ease of dis-assembly of the display to replace the backlights. It does not look easy.
Oct 22, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Sceptre LCD - no display
I have same problem... just went off warranty and they won't cover it.. they want $100 for repair plus $35 shipping plus I have to pay to ship it to them... For $179 I can buy a new 19" with 3 year warranty...I wouldn't buy another Sceptre at half the price
Jul 13, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Dead scepter x22 monitor
Had a Sceptre DCL9A model for mine. There are plastic snaps which hold the back and front covers together. After I took off the screws and detach the monitor stand, I slid a very small flat head screw driver along the sides until I found each snap. They should come loose easily with a slight twist of the screwdriver. There are about 5 on each side of the monitor (not counting the monitor). Do not try to force it as you can warp or crack the plastic.
Jun 22, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G Komodo IV 19" Monitor
Hi dgp1952, Check with www.lcdrepair.net if you want a repair. Something is wrong with your backlight or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. Dust can cause the circuitry to heat up faster and put the power supply into Clamp mode. Clamp mode will turn the supply off to certain circuits which may be the reason your display is going black after 5 minutes.
Oct 09, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X20g-Naga III 20.1" LCD Monitor Logo
187 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
