Question about Electric Lawn Mower
Battery is fully chared but red light on the mower
  • 28 Answers
Check the battery connections for corrosion and make sure they are tight. You may want to clean the connections and reinstall them. If this doesnt help, check for a short to ground somewhere along the connection wires.
Posted on Jun 10, 2014
Batteries shows fully charged. 24 volt shows 27 volts fully charged but shows RED light when install in mower.
it's never the motor, it's always the batteries.
you are most likely testing the batteries with just a meter and not under load
you will need a tool to put the battery under a load, it will end up costing more than two new batteries.
just replace the pair and you will be fine, i have done enough of these over the last few years.
good luck and you will have no problems with the new batteries.
May 21, 2015 | Electric Earthwise Corded Lawn Mower...
Problem charing
"charging"?
assuming you have got a battery warning light on dash? And it obviously doesn't go out. check the large red wire at the back of the alternator with a multi meter and you should have same voltage there as at the battery and its in good condition . If you have a good voltage there and a good engine earth then you need to disconnect the small wire at the back of the alternator - that should put out the warning light on the dash, This will prove the warning light circuit is ok. As long as your vehicle battery is ok and has a good voltage the only other thing that could be wrong apart from the alternator itself is the drive belt being broken or loose.
Aug 14, 2014 | 1999 Mazda B-Series
2007 is250 battery died, then was fully chared, now the car isn't detecting the key and won't start
all new cars are set up that if the battery deads it goes into lockout mode. it is so the dealer ships can make money
Dec 16, 2012 | 2007 Lexus IS 250
Does the red light go off when the 14.4 battery is chared
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you.
Feb 17, 2012 | Ryobi Garden
2005 lincon aviator charing system 12.2 volts after alternator install
check the black/orange wire at the alternator for battery voltage if no power check the fuesable link ( A )
check the orange/light blue wire at the alternator for battery voltage if no power check the fuesable links ( B & C )
check the light green/red wire for 12 volt with the engine running if no power replace the PCM.
if all wires have the proper voltage then replace the alternator
GOOD LUCK
Dec 31, 2011 | Oldsmobile Aurora Cars & Trucks
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
I HAVE A DC 222 AND NO INSTUCTIONS I AM CHARGING THE BETTERIES THEY ARE MEANT TO BE A 1 HOUR CHARGE IS THERE A LIGHT TO SAY FULL CHARE? ALL I GET IS A RED BLINKING LIGHT REGARDS MIKE
on the charger usually there is a guide to the different rates and conditions of the charge.some have flashing lights of different rates to indicate charging or fully charged. If you give me the exact model and brand I will try and find a user manual for you
Jul 17, 2009 | Dewalt Drills
Mazda RX8 starting problem
Check that your battery is fully charged. If it does not sustain a charge , replace it. Clean the cables and battery posts with baking soda and water mixture. About 1/4 cup to a pint. If it still does not turn with a fully chared battery, it is probably the starter that is bad. It will have to be replaced. One click usually means the starter is bad. Several clicks usually means the battery is bad.
Feb 20, 2009 | 2005 Mazda RX-8
Red light
most probably a software prob. try approaching a local mobile center
Mar 17, 2008 | Lands Phones
Not charging
Defective battery. call tech support and they will replace battery for you free of cost.
Oct 21, 2007 | Casio Exilim EX-S600 Digital Camera
Electric Lawn Mower Logo
60 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
