Question about KitchenAid Refrigerators
Where should i look first
The compressor and the fans are not running and the touch control is not responsive
    New Friend:
  • 12 Answers
Is it plugged in? Is there power? Does the light come on?
Posted on Apr 16, 2014
3 Suggested Answers
  • 74 Answers
SOURCE: Refrigerator not cooling, only fan is running.
Somewhere air is getting past the door seal. The door may not be closing all the way. Frost cannot accumulate without a source of water. It comes in the air thats getting in past the seal. Check the drawers to be sure they are all the way in. Check anything that may be sticking out that may prevent the door from closing all the way. Check the door seal for damage and replace the seal if any significant damage is found. Good luck
Posted on Dec 13, 2009
heatman101
  • 43501 Answers
SOURCE: The Compressor is running and
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 14, 2011
RF267aewp french door refrigerator is acting crazy. Sometimes compressor fan runs, sometimes it doesn't same with freezer fans. Front control panel will not respond so I cannot get into diagno
Had same problem on my fridge a long time ago. Here is what was wrong on mine. Debris had clogged up around the fan blades to the point where the very small motor that runs the fan was not powerful enough to make the fan turn. When this happens the compressor has to work harder and harder until it finally shut down on safety cutout. I had to open the back of the fridge and clean up the fan blades, [ took the opportunity to put a small amount of oil on the fan shaft too, my Norge fridge is now over 50 years old.]
Nov 05, 2014 | Samsung RF267AEWP - 26 cu. ft. French Door...
Compressor & fan not running.
Hi and welcome ti FixYa, I am Kelly.
Since you did not include your model number this will be a GENERIC response.
Reasons for the compressor and fan not to run.
1. Defrost control problem. Mechanical defrost timer stuck or failure. On units with Electronic Adaptive Defrost controls; a PCB failure.
2. Defrost thermostat or defrost heating element failure.
3. Fresh Food temp. control failure.
These are the 3 most common failures. The fans should run anytime the units temp control is above the "set temp" and the unit is NOT in the automatic defrosting cycle.
If you provide a model number I can pass on some troubleshooting tips to hopefully help you isolate the failed componenet.
Thanks for choosing FixYa,
Kelly
Jan 26, 2011 | Kenmore Refrigerators
Fridge compartments too warm
There are several possibilities on your model. Compressor start components and Adaptive defrost Control. I would like you to pull away from wall and unplug , rempove the cover over compressor and feel the compressor to tell me if warm, hot or too hot to keep your hand there, Waiting for your response, Sea Breeze
Mar 27, 2010 | Jenn-Air JCD2389G Side by Side...
Fan runs, all controls work compressor does not run.
It sounds as if the unit has lost it's refrigerant charge. Take to small appliance repair for confirmation, but it probably leaked out.
Jun 27, 2009 | Maytag M7DH45B2A Dehumidifier
Penguin model 610012-001a/c compressor won't start
I would check to make sure that the control is sending the "cool" signal to the control unit. LO on the room temp display usually means that the fan speed is set to low. Is LO and Auto showing on the display at the same time. Try resetting the thermostat first. Hold down the Mode and Zone buttons with the tstat off. While holding them down, turn the tstat back on and hold the buttons down until FF appears on the screen. Release the buttons and try the AC.
If this does not work, on the control board is a freeze control switch plug (blue usually). Try unplugging this unit and insert a small jumper wire. If the Compressor comes on and runs then you have a bad freeze control switch. If not, then you should replace the control board.
Hope this helps,
Jeff
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Refigerator not cooling and hot to the touch
It sounds a lot like lost charge caused by a leak in your system. If your unit has been moved or improperly cleaned, some part of the pressurized system may be damaged.
Refrigerant (with very small molecules) may leak off over many years but it shouldn't happen in the single digits.
Apr 05, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Freezer cold, fridge warm
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Mar 17, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Fridge / Freezer no longer cooling F26R4ARS
it could just be the start switch on the side of the compressor. the only way to test that is to replace it. <$20
Jun 29, 2008 | Frigidaire FRS26R4A Side by Side...
Rs2360ww hot to the touch
yellow pine ..when your compressor is running the condenser fan should also be running. located next to compressor. clean coils and replace condenser fan.
Feb 07, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
23 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
