Question about Samsung UN40ES6100 40" Series 6 LED HDTV
I have a samsung LED TV series 6 it does not have ARC hdmi ports. I have a new 5.1 pioneer home surround sound system. As soon as i switch on my Tv there is no sound after 10 seconds do i need the opt
Pioneer Receiver VSX- 523 No sound from my TV it disappears, if i turn off amp in hdmi.. i get sound. what connections and how to get my TV sound through the Receiver? I bought a Digital optics cable and it still don't work
  • Ken Sainsbury
    Ken Sainsbury Apr 17, 2014
    I have resolved the problem. My TV is not ARC compatible to read audio through the HDMI cable. I purchased a Optical Audio cable TOS and put it into my TV and Surround Sound Pioneer VSX-532 still no sound.. I turned of Anynet+ on my TV I then turned off ARC on my Receiver. I then noticed that each device connection (GAME, DVD, TV, BD) has a setting for Audio Parameters (HMDI or Analogue) once I changed to Analogue, I could change the signal to Optical 1. And then sound still remained on my TV until i switched from TV internal speakers to external speakers and it resolved the problem.. I hope this helps anybody who has an older TV without HDMI ARC. Cheers!....
3 Suggested Answers
  • 8457 Answers
SOURCE: Just purchased a Samsung LE46C650 LCD tv and it is
No,half a second that not consider a problems.There are hundred of hardwares and softwares design by dozen of compannies and corporations.Putting these diveces together 100% functionals are not gaureentee.99.99.....% out of 100% is not cosider a problems.
Posted on Nov 20, 2010
info76732
  • 221 Answers
SOURCE: Vertical hardly noticeable lines appearing on my samsung led tv
If you've cleaned the connexion between the motherboard and the display panel, I'm afraid the likely problem is the display panel.
If you have a friendly local repair shop, they might take a look at it and test with a replacement panel to diagnose the problem.
Posted on Dec 10, 2013
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Jan 23, 2016 | Samsung Audio Players & Recorders
When selecting the source, HDMI 2 will not highlight, Only TV. HDMI cable connected to box and to HDMI2 port on TV
You have to check the HDMI cable. In Samsung tvs the HDMI sources only highlights if the a proper HDMI sources is connected to the corresponding HDMI port of the tv. Also check by connecting any other device which have and HDMI connectivity to the HDMI 2 port.
www.electro-medical.blogspot.com
https://www.facebook.com/electromedservices?fref=nf
Oct 02, 2015 | Samsung UN22F5000AF 22 LED 5000 Series TV...
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
Mar 27, 2015 | home Audio Players & Recorders
I have to a samsung LED SERIES 5, how do I connect a pioneer home theatre XV-DV333? Considering am using a set box!
You need a HDMI out on the Pioneer and a HDMI in on the TV. Then use a HDMI cable to connect the two. The input on the TV needs to be the same as the HDMI in port.
May 19, 2014 | Audio Players & Recorders
Have hooked up system according to manual (I think) using HDMI, to Samsung plasma set. Also have audio cable hooked up (from subwoofer to tv). Get absolutely no sound through system. I imagine I have...
Look on the back of your TV for an HDMI port that has "ARC" on it, connect that to the HDMI Out on the subwoofer. Make sure that your HDMI cable supports ARC. That is the only connection you should need to the subwoofer, remove everything else. Other option is an optical cable between the TV and the Subwoofer.
I just discovered this after fooling around with it for the past couple of days!
Dec 27, 2012 | Samsung HW-E550 Crystal Surround Air Track...
I have the btt350 home theater system connected by a hdmi cable from blu ray player connected to a panasonic 50" plasma 3d tv when playing a disc or listening to the radio from the blu ray player the...
Page 22 in the Manual details the required input to be selected dependent on the connection type.
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
[OK].
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
connection.
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Cheers
Andy
Apr 26, 2011 | Panasonic SCBTT350 Theater System
Cant get led tv to play sound through surround sound on blu ray
you have to have a connect going back into the player, the hdmi is only one way there should be and analog the red and white
or
an digital optical out from the tv
May 08, 2010 | Samsung HTC550 Theater System
Installing a pioneer home theatre dvd/speaker system.
On page 36 of the Pioneer users manual, it describes how to set your audio for HDMI interconnect. Follow the directions, and hopefully it will work. You can down load the manual from the Pioneer web site. Google "speaker system HTZ171 DVD". Click on the Pioneer site for your system and look for the download on the right side of page.
I hope this was helpful...
Jul 25, 2009 | Pioneer 45X4 DFS BLUE LED CAR CD
Sound Problems with HD TV
This seems to be a problem that has to do with your HDMI audio output.
First check in your TV setting if audio out is selected on your correct HDMI port. Than check if your receiver is able to receive audio via HDMI (i assume you used the HDMI connection). Some receivers have HDMI IN connections but are not able to receive audio on it, the latest receivers/sets do have this feature. If your receiver doesnot support audio IN via HDMI you can only do one thing, connect the stereo audio-out of your TV to an AUX IN connection on your receiver.
Jan 18, 2009 | Samsung HT-Q100 System
Samsung UN40ES6100 40" Series 6 LED HDTV Logo
56 people viewed this question
Henry  Thomas
Henry Thomas
