Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
Horizontal lines on copies and scanning
Hi I am using Samsung SCX 4521f Multi Function Printer. There are three to five horizontal lines on xerox copies and on scanning, but not when i use as a printer.
    Welcome Back:
    Visited the website for 2 consecutive days.
When you scan and or copy are you loading them in the place??....If you are not try cleaning the glass and the rollers..Any type of dust. dirt or hair will leave and artifact on the copy...
Posted on Apr 15, 2014
  • 167 Answers
SOURCE: Can a Samsung SCX-4216F scan to pdf format?
In windows, Scx 4216f comes with Samrthru3 which does not come with pdf scan option , however you can use the newer verasion of smarthru4 which is available with scx4100/scx4521f .
All you need to do is choose Scx4216f as the device in smarthru window. and you will be able to scan in PDF format.
Will be quite simple.
Happy Scanning
Omnipresent
Posted on Oct 26, 2007
SOURCE: New Samsung SCX-4521f Laser printer problem
when u enter the time use the 12 hour format  am = pm
had the same problem , now everything is OK
Posted on Jan 25, 2008
SOURCE: problem scanning with samsung scx 4521f
My connection is via a parallel to parallel cable, and I am also having a similar problem. I'm reading that usb to usb cable is the only way it will properly function. good luck with it!
Posted on Oct 20, 2008
SOURCE: Samsung SCX-5421F Laster Printer crashes my pc
Have you tried uninstalling and re-installing the software. Perhaps there is an updated driver for your system since you first installed it, or maybe yours is simply corrupted. I would suggest removing and reinstalling will solve the problem - if, in fact, that is your problem -I've not heard of this happening before.
Drivers are here if you need them:
http://www.samsung.com/ca/support/download/supportDown.do?group=printermultifunction&type=printermultifunction&subtype=monochromemultifunction&model_nm=SCX-4521F&disp_nm=SCX-4521F&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010300&model_cd=&menu=download
Posted on Apr 14, 2009
SOURCE: Samsung scx-4521f-How to scan multiple pages to single pdf file?
get acrobat professional, its pricy, but it workes
Posted on Nov 11, 2010
Message showing LSU Error
this is a laser scan unit error, either lsu reuires services , else needs replacement.
Nov 20, 2016 | Office Equipment & Supplies
Horizontal lines when copying or scanning from platen
The silver cable inside the scanner that goes from the CIS to the motherboard is cracked internally. You can purchase a replacement cable from
http://www.fixitfastelectronics.com
Nov 26, 2012 | Samsung SCX 4521F All-In-One Laser Printer
Samsung scx-4521f xerox and printout taken a black vertical line appear on the paper
black vertical lines are generally an indication that the imaging drum needs to be replaced
Nov 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How do I activate the scanner on the SCX-4521F multi function printer?
Click this link http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=N0000191&model_name=SCX-4521F
Go to Scanning, then How to scan.
You have to configure the printer first to scan. Follow the steps and you should be all set
Feb 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Hi I have a Samsung scx-4521F I am trying to send and receive Fax over IP now I know that I have to change the Baud rate to the lower one. but How can I do that? other than changing Baud rate what do I...
I have a samsung scx-4521f i am trying to copy some document but i cannot copy clean. my printer was copy in document black line or black paper ground what do i need to clean copy ? please help me.
Sep 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4521F / Fuzzy thin lines when printing from PC.
If your toner cartridge is very old please replace it or it new clean scanner unite all mirror with glass cleaner or cystal cleaner.may be fix your problem.
May 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Problem scanning with samsung scx 4521f
Sorry to have missed your initial posting...
In any case, to my understanding, this particular printer is likewise capable of USB connection. Perhaps you can try connecting it pure USB and go through the installation again. this might simplify interface and communications between notebook and scanner/printer.
If for some reason you would want to retain Printer/Parallel to Notebook/USB, you need to check your Imaging Devices in the notebook's Device Manager and verify that all drivers are installed for the Samsung SCX-4521F. There should be no yellow or red marks. If there are or if the Samsung SCX-4521F instance is not present, you may need to reinstall using the Add Hardware Option in the Control Panel. You may need to manually select the imaging device/scanner. This holds true if you are using Windows XP.
If you are using Vista, you may need to download all the Vista drivers from the Samsung website. Further, pls be informed that to my knowledge, Vista has certain issues with USB ports. Microsoft has issued a patch/update specifically for this concern. It may be downloaded from here or here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samung SCX-4521F Compatibility with Windows Vista
Sorry but no way out here. Lexmark and Samsung did not updated correctly there drivers, evan a lazy all-in-one inkjet printer will print but not scann or copy, it's a huge problem and they promise for 6 months now that it will be solved, but nothing until today.
Feb 03, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Can't scan and copy from computer
Why can't you use a regular USB printer cable instead? Those conversion cables are not the most reliable or compatible solutions.
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
175 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
