Question about Hotpoint Microwave Ovens
I have a hotpoint microwave model rvm1335bc001 manufactured in 2001 and it has an error showing 6:ZA:AA I can't find this in the manual. What is this error?
Error showing in the display 6:ZA:AA what does this error mean?
  • Cathy Craven
    Cathy Craven Apr 17, 2014
    The microwave still works, turntable rotates, door seems to close properly and keypad is working. I unplugged the unit because of the error, afraid to continue to use until I know what the problem is.
MicrowaveSvc
  • 9098 Answers
SOURCE: My microwave shows a H98
That would be a Panasonic inverter failure code, but please reply back with your brand and full model number.
Posted on May 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore Microwave Model #665 6861 1891
F6 appears to be a relay failure on the main board, but it may be a door switch or door switch mount.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave runs for only a
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Being 6 months old means it will be repaired free of charge.
Posted on Aug 03, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: My Kenmore Elite Ultra Wave Technology microwave
Here are a couple of quotes from another forum:
"Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave."
"F-9 on this microwave IS inverter related. There is a service tech troubleshooting document stuffed in behind the control board cover which has some testing proceedures. My problem was the magnatron and checked out bad with the help of this document. It would run for a few seconds making clicks and then say F-9. It has been working great since I replaced the magnatron PN 6324w1a002c."
Note that part numbers mentioned may not for your model.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
BUT once you have the part number from the Sears parts site, you can often get the parts cheaper here
Posted on May 28, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: My Maytag microwave has error code "SE" on the
SE error means you have a shorted membrane keypad.
The full model number would be MMV1153AAB or MMV1153AAW and denotes color.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly ("control panel/switch" as it's called) which comes with a new keypad.
It's actually a pretty easy do it yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Some connectors have a lock:
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
You can get the part from the Pros here. They're our favorite supplier.
You can also find helpful exploded view diagrams at that link.
Posted on Apr 29, 2011
Hotpoint microwave model RMV1435BD under recall??
None to my knowledge, but common faults include keypad failure (may show error code "F3") and cooktop light failure, both of which can be affordably repaired. (See link below)
For more free DIY and other help & advice, feel free to contact me via my site below.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 14, 2017 | Hotpoint Microwave Ovens
How can I get a copy of the manufacturer's installation instructions for a Hotpoint JX-81J over the range microwave oven?
JX-81J is the microwave recirculating charcoal filter for several models of GE and Hotpoint microwaves. The installation instructions will be available from the manufacturer with the model number of the microwave itself.
One microwave that uses this filter is the RVM1535MMSA . See http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=HPSPECPAGE&Sku=RVM1535MMSA#tab1_ for all of the details on this microwave. The owner's manual, http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=39-40541-1.pdf , shows the installation of the filter on page 34. The guide for installing the microwave above the range is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=39-40425.pdf .
If you have a different microwave, add a comment with that model number. I hope this helps.
Feb 13, 2017 | Hotpoint Microwave Ovens
Rvm1335bc001
sounds like the control board, but most times the magnetron fails and if a fuse failed then it needs a capacitor too
Nov 27, 2013 | Hotpoint RVM1635 Microwave Oven
I unpacked my new hotpoint countersave plus microwave RVM1535 and there is no installation manual. how can i get on online?
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 23, 2011 | Hotpoint RVM1325BW Microwave Oven
Hotpoint bd35 electric oven instruction manual
Here is a link for you to download a PDF instructional manual for your Hotpoint cooker or Hotpoint oven.
how to use this service
1 click on Link,
2 click manufacturer (Hotpoint)
3 enter your model number and download the PDF file .
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Jan 28, 2011 | Microwave Ovens
How do you replace intermittent door switch on Hotpoint RVM1335BC001 microwave
Open the Micro door, and remove the air/Vent cover on the top if there is one, Usualy 2 screws on top or the middle of the cover.
Remove the screw holding the Controller board and then you will have access to the door switches 2-3 of them depending on Manif.
Also make sure you have the power unpluged befoe you do any of this.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Oct 27, 2009 | Hotpoint RVM1635 Microwave Oven
I need a manual for a GE turntable microwave oven, manufactured in March 2002, model # JES636WD001.
Go to geappliances.com and click on the "Service and Support" link. Under the drop down menu, locate "Owner's Manuals and Installation Instructions". Type in your model number and your Owner's Manual is available in .pdf (Adobe) format. Save a copy to your PC, or print one out.
NOTE: Before you ask...Although your microwave carries the GE logo, it is manufactured by Hotpoint.
I hope this helps you.
Jul 23, 2009 | Microwave Ovens
Melted turntable support
Yes, that's part # WB06X10138 (coupler) and you can get it here.
You will need to remove the bottom cover of the microwave and remove the turntable motor to get the new coupler in.
Jul 03, 2008 | Emerson MW8108P Microwave Oven
Powers on, rotates- but does not heat
Thanks for mentioning that growling sound, which is a classic clue to a bad mag, though not all bad ones make that sound. Sounds like someone growling into a coffee cup! *grin* For this job, the unit will probably have to be taken down from the wall mount. I recommend 2 people for that job. A spotter, if you will. When replacing the magnetron, it's very important to be sure the new one has the wire mesh "washer" (RF gasket) around the antenna which sticks out the top. If it's not on the new one, use the one from the old mag. Very important. Also, you should really discharge the high voltage capacitor. This case also illustrates an interesting thing about part prices: GE http://www.geappliances.com/shop/prts/ WB27X10017 $121.75 Appliance Parts Pros http://tinyurl.com/gv383 10QBP0230 $60.42 (check this one to be sure picture matches yours) A-1 http://a-1catalog.com/10qbp0230.html 10QBP0230 $54.00 Tritronics http://www.wehaveparts.com 10QBP0230 $42.85 I can advise you further concerning safety and disassembly if you need help: http://www.fixya.com/GetServiceUrl.aspx?advid=14&ctgid=153
Dec 14, 2006 | Hotpoint RVM1635 Microwave Oven
Microwave Ovens Logo
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
