Question about Dell C1765nf Multifunction Color Laser Printer
When printing labels some are faint and some have a background.When i print on plain paper they are perfect
  • 78 Answers
Try using the manual feed tray and set it as printing labels.
Posted on Apr 26, 2014
SOURCE: 'Load plain paper' message
Make sure that you have set the same paper type on both the printer driver and on the printer itself, using the on-printer menu. When I get this message, I usually had forgotten to change the paper type on the printer.
Posted on Nov 06, 2008
dan231
  • 236 Answers
SOURCE: Background printing showthrough on paper
might be your transfer roller.
If the printer has a lot of use on it, I would recommend a maint/ kit.
It would replace your fuser and rollers. around $190
I would shop around for best prices.
http://store.l-f-l.com/cgi-bin/cp-app.cgi?rrc=N&pg=prod&ref=P56P1409&op=P56P1409&bd=Dell&sd=&md=M5200&CMP=BAC-nextag&zmam=33951326&zmas=5&zmac=91&zmap=P56P1409m2912703
Posted on Dec 15, 2008
freetek
  • 5568 Answers
SOURCE: printer was printing fine ran
I don't know this specific printer but have seen many printers mishandle the last sheet of paper causing a jam and leaving pieces behind when forcibly removed from the paper path.
You might try peering into the paper tray slot to see if there are any obstructions. Different printers use different methods of sensing 'paper out' and yours may use a mechanical flag that interrupts a photo sensor that really detects on the passage of the sheet and if this is impeded in some way, it may just think it's out of paper.
Posted on Jan 22, 2009
  • 547 Answers
SOURCE: A dell 3010 which prints fine from webpages etc.
Outlook's printer options are set to load paper from the Manual Paper Feed (mpf) instead of the regular paper tray.
In outlook, select file->print and look for the printer properties button on that dialog box.
Select the paper tray you want to use (or simply uncheck "MPF" or "Manual Paper Feed") and hit OK.
Posted on Sep 04, 2009
SOURCE: it says load mpf plain
Check to see if the settings are pointing to the MPF paper feed, if it is then you can either change the settings to point in the direction of tray one or tray 2. If its not, then you have to open the front and single feed the paper..
Posted on Oct 30, 2010
When printing labels (Avery 5160) the labels start being shredded half way through and then the printer jams.
Have you setted up in the printer driver to print on label? the printer will automatically adjust the internal parts for printing on a higher density paper!
If you done it gently remove the Duplexer unit from the behind of the printer and chech for pieces of paper or everything could cause the paper jam!
Hope you found it useful, for futher questions i'm here :)
Dec 07, 2015 | HP Officejet Pro 8610 Inkjet Multifunction...
When I try to print on a 6x6 envelope on my hp envy 110 printer it tells me it is the wrong size paper. No where is there a setting for a 6x6
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
menu.
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Tallon41
Sep 08, 2012 | HP ENVY 110 Wireless e-All-in-One Inkjet...
My Kodak esp 3200 won't print labels on Avery label pages. WILL print the labels on regular copy paper. Any suggestions on what to do?
I am having the same problem except you didn't address the problem. It's not that the printer prints badly, jams or crashes. The printer literally passes the label paper through the printer and then prints on the next piece of copy paper. I reset my printer not to print the last page first and it still did it. Then I put the label paper second in the feeder. It passed through the first piece of copy paper and the
labels and printed on the third. It's like the printer senses the thicker paper and skips it. My printer is a Kodak ESP C315 and I have no setting for thick paper only plain and photopapers.
Sep 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I am trying to make labels for cd's but they are not printing correctly. The sheets show the cd to the side of the page but it's only printing straight down the middle so it's not letting me print...
I had the same problem. The solution I came up with was to use Microsoft Publisher to print the labels. First I drew a circle about the size of the cd and another inside it for the centre. I printed it out on a plain sheet of A4 paper and measured held it over the label to see how they matched up. I dragged the circles in publisher using trial and error until the circles came out in the same place as the circles of the labels. Then I designed the label inside the circle using publisher and when I printed it on the label it came out in the circle.
If you don't have publisher just check the paper shown in your print dialog and make sure you have changed it to the label type you're using rather than A4 Plain which is the standard.
Jul 27, 2010 | Avery DesignPro Deluxe CD-ROM...
When I pint pictures it seems to not "seal" them down, I get blotches and globbs onink on other parts of the page and the folloing pages.
Are you using plain 20lb paper? If you are using anything thicker or heavier than plain paper then you must use the bypass feed and tell the machine you are using cardstock, thick paper etc. I have the same machine and have had the same issue when printing labels. Works perfectly if you tell the machine what paper you are printing onto.
Now if this is not the case then you might have an issue with the fusing unit.
Good Luck and Thank You for using Fixya.
Apr 28, 2010 | Ricoh Aficio CL3500N Laser Printer
Faint type on metallic refills
Faded print is nearly always the 1st sign the batteries are nearly worn out - try new batteries. (it could be that metalic tape requires more power to print than the paper tape)
Jan 18, 2009 | Dymo LetraTAG Thermal Label Printer
CD label (Neato) printing problem
Try to change your paper type to plain paper - it could be because it is a bit glossy that it thinks it's photo paper that is not inserted correctly.
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
Will not print labels
you have connected two printers on a data switch.right.
1. Print test page through Printer driver.
2. If you are using command for printing on Intermec printer, you should not use generic printer.
3. Interchange the cable connected to printers
May 01, 2008 | Intermec EasyCoder PC4 Label Printer
Label Printing Problems
Your problem seems to be due to worn out of rollers. Try a less glossy paper and you can find the difference.
Dec 12, 2007 | HP Officejet 4215 All-in-One Color Photo...
Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
Dec 05, 2007 | HP DeskJet 3940 InkJet Photo Printer
Dell C1765nf Multifunction Color Laser Printer Logo
51 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
