Question about Dryers
Kenmore dryer model 970-C85092-00 no heat
After a couple of minutes of running it goes to cool down and there is no heat
  • 822 Answers
Element or stats........cheers
Posted on Apr 15, 2014
  • 156 Answers
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Posted on Feb 28, 2008
  • 212 Answers
SOURCE: gas dryer heats for couple minutes then goes cold
sounds like gas valve is not opening. your ignitor has to pull 3.2 to 3.6 amps to open gas valve. check amps
Posted on Jun 22, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Posted on Jul 27, 2009
  • 3640 Answers
SOURCE: My dryer heats up when running about 10
usually when this happens it is one of the heat thermotats going bad, when the thermostat goes bad it will shut down flame.
Posted on Jan 14, 2010
  • 88 Answers
SOURCE: I have Maytag dryer with Model No. LDG8424AAE. It
how long have you had dryer....have you ever had dryer cleaned out inside...it could be plugged up...chek airflow,disconnect vent line...feel if you have lot of air...or little....then it might be internal tstats problems.....check all this first.....good luck...
Posted on Apr 03, 2010
I have kenmore washer/dryer combo model 970-C98802-00. Been using for years until last week it starts tripping the breaker when using the dryer. It does not trip the breaker if no heat. It only trips the...
since it runs on air you have a grounded heater coil. Either the heater has sagged or broken and is touching the frame, here is a website that will assist you, Tim:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
May 31, 2011 | Dryers
The dryer is taking a couple of ctlces to dry items. I opened the door and depressed the button, so that the dryer would run while I was checking for heat. The heat comes on but then after a couple of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'
Mar 12, 2011 | Kenmore 72802 Gas Dryer
DRYER RUNS BUT NO HEAT.WHERE CAN THE FUSES BE ?MODEL NO 970-17802-20.SERIAL NO XE73210031.KENMORE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
Dryer is running but very little heat if any sometimes
is it gas?if it is and it heats for the first 15 to 30 minutes then you have bad gas coils,they work correctly till they heat up and then they fail,when they cool down they will work again.send model number and i can help you
Jan 22, 2011 | Kenmore Dryers
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
Jul 27, 2009 | Dryers
Gas dryer heats for couple minutes then goes cold
Jun 22, 2009 | Kenmore 63942 Dryer
Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Feb 11, 2009 | Kenmore Dryers
Dryer runs for 15 minutes and stops
check the in-line limiters on the heating coil tube.
Jan 15, 2009 | Kenmore 62882 Electric Dryer
Dryer heats up cools down in few minutes? Kenmore gas
we need to take a look at the heating system and exhaust,,where going to start with simplest ok..your filter is cleann...check exhaust from back of dryer leadind all way out house make sure that path is clear...next pull exaust off and run dryer,,if not good,,let me know ,,onthejob
Jan 10, 2009 | Dryers
Dryers Logo
243 people viewed this question
Top Dryers Experts
