A34 riso ez200e gives error code A31
Cant clear e78 error code
CR set to wrong country code in Memory Switch - Setting no. 200 (machine model setting), needs to be "B"
May 05, 2014 | Riso Office Equipment & Supplies
A-34 is the code. what is it?
A34 code is "master not set in place".
Sep 05, 2013 | Riso RZ390 Duplicator
Rizo ez200E p12-309
Error type P12: System ErrorError point 309: Master-compression-motor encoder sensor count did not change as the master compression motor activated in the compress direction and moved out from the home position.
Try this: Press reset-key. If recovery fails you machine needs service.
Sep 19, 2012 | Riso RZ220 Duplicator
Riso kz30 error code a34
j ai un rizo kz30 aui ne marche il signale une feux orange n 4
Jun 20, 2012 | Office Equipment & Supplies
Riso HC5500 System Error - Restart!
I need help with the error code. s04-307 in my riso hc 5000
Oct 22, 2008 | Office Equipment & Supplies
Riso Rz 220
Remove the master that is on the drum. Then check the master roll remove it cut about 18 inches off then re install master roll. hit the reset, then print bottons.
Jun 11, 2008 | Riso RZ220 Duplicator
18 people viewed this question
jasbo
jasbo
