Question about Broan-NuTone Broan Range Hoods Alpine Canopy 11000 Series - 30'' Range Hood - 1130
How to clean blades of Broan 11000D Alpine Range hood
Is there a way of taking the blade off to clean?
  • 4102 Answers
SOURCE: Replace Broan Model K260A Range Hood Light Switch Slider Assembly
Hi if the new part has no screw holes or place for clip and it is only push in connector ie you dont need to solder the wires to it then it will just pull out use a small screw driver under the edge and gently pry free you cant damage it anymore than it is anyway can you.
Also on the side of the new switch if their is no groove cut into it for a push on clip to hold it in place then it will just pull out and push the new one in.
Posted on Jan 30, 2008
  • 1548 Answers
SOURCE: Broan Allure range hood fan
The fan switch contacts are probably welded together or the actuator mechanism is broken. Your best bet is to replace the fan switch, probably with a similar type having a higher current rating so the new one won't also be susceptible to contact welding. If you have an industrial electrical supply dealer or electronic surplus parts store in your area, those would be good places to look for a replacement.
Posted on May 19, 2011
  • 224 Answers
SOURCE: My Broan range hood keeps
This sounds like something has got into the track area and is setting off the safety. they are designed to stop raising or lowering if they meet any resistance and anything in the track area will cause it to happen in both directions
Posted on Jun 26, 2011
GodBlessU
  • 3513 Answers
SOURCE: All electronics in the Broan
Hi
Turn off the main switch and rcd and open the CU. A residual-current device (RCD) is an electrical wiring device that disconnects a circuit whenever it detects that the electric current is not balanced between the energized conductor and the return neutral conductor. Connect temporary wires (preferably some bright color you would not normally see in a CU so it can be easily removed later) between the earth bar and the neutral bars.
Check for continuity with a multimeter between the earth and neutral wires at the cooker hood feed position .If there is no continuity at this stage you have serious problems and should get a sparky in then disconnect the neutrals of each circuit from the CU neutral bar one at a time and retest continuity at the hood (start with the likely ones like kitchen sockets and downstairs lights and cooker circuit if present) .When you find out which circuit it is put its neutral back in the bar and start breaking that circuit in various places until you find where it's spurred from .
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 26, 2011
ekcnoel
  • 998 Answers
SOURCE: I have a Broan range
Sir try to check the starting capacitor and the ac supply feel free to send feed back good day and best regards.
Posted on Sep 13, 2011
Noisy loose fan.Found a nut in the fan and trying to get it to stay on fan shaft but keeps falling off. Will this fix problem if can get it on?
Take the nut to a hardware store and ask for a self-locking nut. That type nut shouldn't spin off again. That MIGHT solve the noise problem, if the fan blades are wobbling, or the shaft is spinning within the fan's center.
Mar 05, 2014 | Broan-NuTone PK22 Kitchen Hood
I installed a new Broan QML30SS range hood and fan makes loud humming sound as it runs
An old elecricians joke says "do you know why it hums? It dosn't know the words" Al kidding aside ,have you checked to see how free the fan blade is? The should spin very freely. It kind of sounds to me like it may be having a hard time comming up to full speed. You may try some graphite lube on the motor. If I recall Broan has a lifetime garrentee on the motor. You might just want to repace it if I am correct.
Mar 02, 2013 | Broan QML30SS Pro-Style Under-Cabinet...
I just had a Broan Elite E662 hood installed and it is blowing out instead of pulling air in. I held a tissue up to the filter and it does not pull it up...rather it blows it down. Was something done...
It sounds like the fan blade may be installed upside down, or the entire motor/fan assembly is upside down. Typically, these small motors aren't reversible, so you should check the blade first.
Dec 13, 2009 | Broan-NuTone Broan Elite RM605404 Kitchen...
Noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Dec 11, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Nutone motor is ****
Are you replacing the blade at the same time? An unbalanced blade can ruin the motor before its time.
Aug 24, 2009 | Broan-NuTone Intermediate Whispaire ...
How to clean the blower wheel/housing
Yes you can.
Steps for allure 2/qs2 3/qs3
blade located to the left (squirrel cage)
1.remove filters
2.remove both screws retaining metal plate underneath filters
Now you have room to remove the blade completely for washing.
The blade is only held on by pressure (no tools needed)
When re-installing, make sure the plastic lever on the blade is securely located in any hole on the motor face.
For allure 1
Blade located dead center of the hood
Steps
1.Remove filters
2.Remove pin
3.Remove blade (only held on the pressure) you may have to pull hard
4.When re-installing: make sure the flat side of the hole in the center of the blade is alined the flat side of the shaft of the motor.
Jan 30, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Fan blade broke off
Part # K7458-000
1-800-363-0566
Jan 03, 2009 | Broan-NuTone Intermediate Whispaire ...
Wobbly Fan----Nutone Whispaire WA6500
Definetly need a new blade
#K7458-000 Boan/nutone part number
Dec 09, 2008 | Broan-NuTone Intermediate Whispaire ...
Vibration at high speed
check these causes fan blade brackets,fan blade for cracks, any grease on blades.
Dec 27, 2007 | Broan-NuTone AllureĀ® I WS136BC Kitchen...
Kitchen Ranges Logo
65 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Phil Lovisek
Phil Lovisek
Steve
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
