Question about Samsung DV330AE Dryer
Clunking noise When drier is running it sounds as if its climbing then falling onto the support even with no load turning drum by hand this will occur what do I need to check
  • 822 Answers
Open the door.........hold drum at the top and see if it lifts up a bit................if it does.......the bearing on the drum will be knackerd..............cheers
Posted on Apr 15, 2014
My Kenmore stackable washer makes very load noises in the rinse and spin cycle but still works. Anyone have idea why it's making so much noise
Try spinning the drum by hand when empty, the faster the better. Does it sound noisy or is there a grinding sound? It should sound silent or whir as everything turns. If noisy then it may well be the drum bearings. If it clunks then it may be one of the arms that holds the drum in place has broken.
Oct 05, 2015 | Kenmore Washing Machines
When the dryer switch is turned on, it makes a humming sound for a few seconds and then stops but the dryer does not come on. What is the problem?
The slipper pads are most likely warn out and the motor is tripping on overload. Was it making a rubbing noise when the drum is rotating, try turning the drum by hand and listen. If you have a drier that will run inverted turn it over and try.
Apr 24, 2015 | Dryers
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
When the dryer is on it makes a loud clunking sound during each rotation
Check to see if something was left in a pocket when dried and fell out. like a coin, a magnet, a wrench. Often, things fall out of pockets and make a loud clunking sound when the drier is turned on.
Feb 05, 2011 | Dryers
Clunking noise and drum gets stuck
It sounds like your washer needs an overhaul . A new tub and bearings it's a big job with a big price tag.
Jul 02, 2010 | Hotpoint WMA32 Front Load Washer
Washer motor / gear makes a clunking sound after running a while ,sounds like something breaking up.Small 6 inch disc under motor maybe the problem. Otherwise runs great. Just when washing,noise is heard.
Hi, could be drum bearing wearing down.the disc you found sounds like the outter ring of it.just reduce your load if you want get more life out of m/c.the bearing will have to be replaced if you want to continue using this m/c. to check, with power disconnected,rotate the drum slowly by hand---if you feel a gritty feeling in your hands,then its the bearings. was this helpful? regards paig
Jul 30, 2009 | Washing Machines
Makes clunking sounds & throws belt off pulley.
I think you have the answer. I suspect it will be the bearings that have seized up. Or possibly the spyder / drum axle broken
Oct 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Samsung DV330AE Dryer Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
