IOR P552P OR IOR P617H 8-SOP what is it?
I have damaged LCD LG Power Supply. this piece IR P552H short-circuited. In another PCB in the same place I found IR P617H I would like some Info or Substitute.
    Top Expert:
  • Televison & ... Master
  • 36,376 Answers
You are referencing proprietary LG part numbers. LG probably is the only source of replacement information.
Posted on Apr 15, 2014
  • Krasi
    Krasi Apr 15, 2014
    Is it possible.
  • Krasi
    Krasi Apr 15, 2014
    maybe it is IRP552H 8-SOP
SOURCE: Maxent 26" lcd tv, shorted circuit board
the best and easiest way to track down a short is with a digital multimeter just check for continuity throughout the circuits.If you you cannot get your hands on a multimeter use a compass.It will detect and move left to right when there is a complete circuit and as soon as you hit the short the needle will be dead still. Fix the short and test.It would probably be alot cheaper than trying to track down a part with no certainty of it.Hope this helps
Posted on Mar 18, 2009
  • 188 Answers
SOURCE: Phillips 42PFP5532d/05 LCD tv, stuck in standby.
Check 15V line,12volts is too low.
Posted on Jul 27, 2009
SOURCE: I need a main power supply PCB for my WT323 LCD
hi my english is not good but, I have TV FA2B-42570, i have problem similar buy the secction the voltage o source is bour and many ic dot have the munbers, for example Q14, IC3, IC1 etc. if you source is similar of my please help
Posted on Dec 06, 2009
  • 222 Answers
SOURCE: Need a new power supply. Where?
Try E-bay
Posted on Jun 06, 2010
Testimonial: "THanks."
jdvillanueva
  • 2098 Answers
SOURCE: I'm looking for help troubleshooting a Toshiba lcd
Hi robbroys,
What is the symptom of your unit, is there an initial steps that you've done to the board.
Let me know to assist you further.
Jdvillanueva
Posted on Apr 06, 2011
Canon ir 2220 ERROR CODE E261
U NEED TO INVESTIGATE
the input/output ports of the DC controller PCBs.
COPIER>I/O>DC-CON<DC-CON (5/7)>
P020 xxxxxxxxxxxxxxxx=runs from left to right 15>0
ADDRESS=P020
BIT-
0- zero-cross signal -
1- heater trigger 1 signal 0: ON
2- heater trigger 2 signal 0: ON
3- heater error OFF signal 0: error
4- not used
5- not used
6- M9 registration motor phase A pulse signal -
7- M9 registration motor phase B pulse signal -
E261 0000
The intervals of zero-cross signals deviate from the tolerance range while
the fixing heater is supplied with power.
Main cause The wiring is faulty (short circuit, open circuit). The main power supply
PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
Are the connectors J205 on the main power supply PCB and the connector
J308B on the DC controller PCB securely connected?
(zero-cross signal: J205-7 <-> J308B-1)
NO: Connect the connectors securely.
2. Main power supply PCB, Main controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Jan 22, 2013 | Office Equipment & Supplies
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
My canon IR 3100 CN displays an error code E000004-0001 plaese help me solve
E004
The main thermistor (TH1) has an open circuit or has poor contact. The sub thermistor (TH2) has an open circuit or
has poor contact. The thermal switch (TGP1) has an open circuit. The main heater (H1)/sub heater (H2) has an open
circuit. The AC driver PCB is faulty. The DC controller PCB is faulty.
E004 0001 protection circuit error of the fixing unit
Description: A short-circuit is detected in the triac (for 1 sec or more continuously) while the heater remains off (hardware detection) for 40 msec continuously.
Remedy: Turn off and then on the main power supply.
Remarks: fixing assembly triac malfunction/13V power supply error
Feb 04, 2011 | Canon imageRUNNER C3200 Color Printer
Error code E000803-000
that mean low power or The 24V output from the composite main power supply PCB is absent for 1 sec or more.
Main cause The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
PCB (J300)?
Feb 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Please help!!!!!!!!!!!!!!!
Good Day;
It sounds like you may problems in the TV's circuits, but try resetting first by unplugging TV from power source. If no fix try these areas of concern:
1. SHUTDOWN CAN BE CAUSED BY NO VERTICAL DEFLECTION. SINCE THE VERTICAL CIRCUIT IS POWERED BY THE SWITCHED POWER SUPPLY THE UNIT MUST BE TURNED ON TO TROUBLESHOOT THE CIRCUIT. THIS CAN BE ACCOMPLISHED BY TEMPORARILY DISCONNECTING THE VERTICAL INPUT TO THE X-PROTECT CIRCUIT. ** TO PREVENT DAMAGE TO THE CRT'S YOU MUST UNPLUG THE CRT PCB'S. ** TO DEFEAT THE X-PROTECT CIRCUIT, UNSOLDER D4A1 LOCATED OFF THE COLLECTOR OF Q4A1. IF THE UNIT POWERS ON AT THIS POINT, YOU HAVE CONFIRMED A VERTICAL FAILURE AS THE CAUSE FOR SHUTDOWN. ** D4A1 MUST BE REINSTALLED IN CIRCUIT TO PREVENT CRT DAMAGE. ** 2.CHECK PIN 1 OF IC401 FOR 10.7VDC. IF LOW OR MISSING CHECK FOR SHORTED D4000 LOCATED OFF PIN 1. (PCB-MAIN) D4000 PART #264P487030 3. CHECK PIN 8 OF IC401 FOR 27.7VDC. IF MISSING CHECK FOR OPEN D955 AND L961 AT S1 TERMINAL OF T902. (PCB-POWER) D955 PART #264P102040 L961 PART #411P012010 4. CHECK FOR DEFECTIVE IC401. IC401 PART #272P239040, OR INSTALL PT# IC-401, THIS KIT CONTAINS CAPACITOR C920, D4000 AND IC401. BE SURE TO MOUNT C920 ON FOIL SIDE OF PCB. 5. EXCESSIVE 130V SUPPLY. CHECK C911 47 UFD 100 V AND C914 47 UFD 50 V, IN THE IC900 CIRCUIT. Good Luck, big IRISH.
Sep 26, 2008 | Mitsubishi Televison & Video
Model vs-4543 mitsubishi tv
Good Day;
One of these may be your problem:
Sep 14, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubisihi hd 1080 t.v.
Good Day;
Try this when th TV wont turn on:
Aug 21, 2008 | Mitsubishi WS-55807 TV
Mitsubishi
Good Day, ya'll;
TRY THIS:
1. SHUTDOWN CAN BE CAUSED BY NO VERTICAL DEFLECTION. SINCE THE VERTICAL CIRCUIT IS POWERED BY THE SWITCHED POWER SUPPLY THE UNIT MUST BE TURNED ON TO TROUBLESHOOT THE CIRCUIT. THIS CAN BE ACCOMPLISHED BY TEMPORARILY DISCONNECTING THE VERTICAL INPUT TO THE X-PROTECT CIRCUIT. ** TO PREVENT DAMAGE TO THE CRT'S YOU MUST UNPLUG THE CRT PCB'S. ** TO DEFEAT THE X-PROTECT CIRCUIT, UNSOLDER D4A1 LOCATED OFF THE COLLECTOR OF Q4A1. IF THE UNIT POWERS ON AT THIS POINT, YOU HAVE CONFIRMED A VERTICAL FAILURE AS THE CAUSE FOR SHUTDOWN. ** D4A1 MUST BE REINSTALLED IN CIRCUIT TO PREVENT CRT DAMAGE. ** 2. WITH VERTICAL PROTECTION DEFEATED (D4A1 OUT OF CIRCUIT) WHEN THE UNIT POWERS R514 (PIN 11 OF THE FLYBACK) OPENS. CHECK PARALLEL CAP. C512 .33 UFD 400 V IF C512 IS GOOD REPLACE THE FLYBACK PART # 334P191020 ON THE MAIN PCB. 3. CHECK PIN 1 OF IC401 FOR 10.7VDC. IF LOW OR MISSING CHECK FOR SHORTED D4000 (PART #264P487030) LOCATED OFF PIN 1. (PCB-MAIN) 4. CHECK PIN 8 OF IC401 FOR 28.4VDC. IF MISSING CHECK FOR OPEN D520 AND R540 AT PIN 5 OF FLYBACK TRANSFORMER T503. (PCB-MAIN) D520 PART #264P102020 R540 (1.2 OHM 1/4 W) PART #103P398010 5. CHECK FOR DEFECTIVE IC401, PART #272P239040 ( PCB-MAIN) 6. CHECK R540 1.2 OHM 1/4 W OFF PIN 5 OF FLYBACK (PCB MAIN). 7. EXCESSIVE 130V SUPPLY. CHECK C911 47 UFD 100 V AND C914 47 UFD 50 V, IN THE IC900 CIRCUIT.
If you are not technical then you should call a factory authorized service dealer and an estimate, as you can see this can get complex.
May 19, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
202 people viewed this question
Top Televison & Video Experts
Electro Med Services...
