Question about Irons
Home touch steamer
Steamer is leaking out the bottom. Is there a way to correct this?
    Top Expert:
  • Irons Master
  • 34,153 Answers
Replacement may be the only practical solution.
Posted on Apr 15, 2014
SOURCE: Conair GS4 Steamer
faa3e02.jpgthis is from conair instructions included with steamer, finally found it, hope it helps some!
Posted on Jun 28, 2008
geokohler
  • 304 Answers
SOURCE: conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Posted on Jul 24, 2008
SOURCE: rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Posted on Oct 31, 2008
SOURCE: would you return this PS200 steamer?
If the steamer starts making a "gurgling" noise, like its running out of steam, hold the hose straight up for several seconds. It says to do this in the manual and gets the steam flowing again--works great!
Posted on Dec 31, 2008
SOURCE: Home touch 300 no steam coming out
If you are using tap water - there may be minerals clogging the machine. try dumping all the water out and rinsing the machine then add distilled water. That was the issue I had...
Posted on Jul 08, 2009
MANUAL FOR PS 350 HOME TOUCH GARMENT STEAMER
First-time ever used. Water filter installed. WON'T STOP BEEPING AND START STEAMING.
Mar 03, 2012 | Irons
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Nov 23, 2009 | Rowenta Commercial Garment Steamer - White
Need a User Manual
my home touch ps200 has the reset button that wont reset ?
Oct 10, 2009 | Irons
Conair steamer leaks water and wets my clothes.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Jan 24, 2009 | Conair Compact Garment Steamer Iron
IS8100 Commercial Steamer is leaking water
Try "cleaning it" with vinegar. It could be clogged with calcium carbonate. Replace the water with a potent solution of white vinegar and water and operate the unit until the vinegar solution is used up. I use 100% of the supermarket white vinegar and avoid breathing in the "steam." Repeat the procedure once or twice with plain water. If this works, let me know.
Dec 24, 2008 | Rowenta Commercial Garment Steamer - White
Conair steamer
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Would you return this PS200 steamer?
Jun 13, 2008 | Homedics PS-200 Iron with Auto Shut-off
Wonder Steamer
Have lost the cord & instruction booklet for the Wonder Steamer.. Can you help?
Feb 20, 2008 | As Seen On TV Wonder Steamer Kit Iron
Conair GS4 Steamer
Oct 28, 2007 | Conair Gs4 Iron
Irons Logo
223 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
