Question about Konica Minolta Office Equipment & Supplies
Paper error copier showing error to B5 paper instead of A4?
  • Konica Minolta Master
  • 6,161 Answers
What model ###### check the draw guide settings a4 is equal to 81/2 x 11
Posted on Jan 10, 2016
Cogz
  • 1326 Answers
SOURCE: PAPER SIZE DETECTION ERROR
Are you tring to use a paper tray or the manual by pass tray?If you are tring to use a paper tray for more then one or more copiers, you are going to have to ask your service techs to change the setting of one of your paper trays to A4 in service mode. Or if that has been done, look behind the paper trays for a wade of paper blocking the size detect switchs behind the paper trays. Good Luck
Posted on Mar 07, 2008
checkitright
  • 1362 Answers
SOURCE: How to set the paper size in the trays?
most are set by the trays itself, when you adjust the "guides" that go against the paper it adjust some levers on the side or back of the tray which push on some sensors behind the tray.
Some however you need to turn a dial in the tray to the paper size you need.
make sure the guides are snug against the paper, the dial or settings are correct and that there is no paper behind the tray.
Also I'm not sure what country you are from but in the US we do not use A4
Posted on Nov 24, 2008
xptareq2000
  • 1447 Answers
SOURCE: My canon image class D340 copier is showing red on
Dear sir,
the problem is paper feed sensosor i mean paper add sensor is broken or diplace
Posted on Aug 16, 2009
Testimonial: "Thanks for the answer...somehow, it seems to have fixed itself. I'll contact you again if the problem persists.Is there any way to get a manual D340?"
  • 99 Answers
SOURCE: My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Posted on Dec 12, 2009
canontech
  • 1219 Answers
SOURCE: in A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
Posted on Jan 13, 2010
Where do I load paper in a Kyocera FS-C5350DN Full-Color Laser Printer
At the bottom of the printer you will find the paper cassette. Pull the handle and the cassette will slide out. Eventualy you will need to ajust the size of the paper.
Jun 23, 2014 | Kyocera FS-2000D Laser Printer
Special paper tray is empty error
Sounds like someone requested A4 size paper in a print job instead of the normal Letter size paper...
Try putting regular letter size paper in the bypass tray and then set it up as A4 size...the print job should then print out on that paper.
Apr 09, 2014 | Xerox WorkCentre C2424DN All-In-One Laser...
My aficio 1013f can not scan a4 but only b5
CHECK THE PAPER SENSOR, U CAN SEE ON THE RONT OF TRAY COLOR GREEN AND SELECT THE RIGH PAPER SIZE RICH FOR U
Jan 17, 2014 | Ricoh Aficio 1013F Copier
I can't get my toshiba estudio 162 copier to print 8.5 by 14 inch copies. how can i change the length?
Drawer feeding:
A3, A4, A4-R, B4, B5, B5-R, LD, LG, LT, LT-R,
FOLIO, COMPUTER, 13"LG, 8.5" x 8.5", 8K, 16K, 16K-R
Bypass feeding:
A3 to A5-R, LD to ST-R, FOLIO, COM-PUTER, 13"LG, 8.5" x 8.5", 8K, 16K, 16K-R
Jun 25, 2012 | Toshiba e-Studio162D Copier
Change paper size from B5 to A4
open the tray . in the front u will see a slider for paper size on tray.set it on A4
Oct 14, 2011 | Canon iR 2016i Black and White Copier
Dec 12, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Paper Type and weigth Fot Lexmark C912
Media paper weight: is 20lb or 75gsm.
Media type: card stock, envelopes, Glossy paper, Paper Labels, Plain Paper, Transparent.
Media size: A3, A4, A5, Banner up to 11.69"x36", Executive, JIS-B4, JIS-B5, Ledger, Letter, legal, Super Tabloid, B5, C4, C5 DL, 7 3/4 9, 10 Envelopes.
demension is in inches, you need to convert it to centermeter.
Oct 30, 2008 | Lexmark C912 Led Printer
Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
Lexmark t630
Paper size is incorrectly set!.....
Merlin's idea, of what paper Lex has, and Lex's are different or you have loaded Lex's tray with the paper sideways
Your in Oz so it would be A4 standard and I guess your trying to print B5 script. Try these
The printer has been loaded with one size paper but thinks it is another. change printer settings via keypad on printer
The B5 scripts paper is being loaded sideways instead of length ways or visa verse
There is a incorrect setting in the printer driver that is set up for this specific printer that 'merlin' uses, check print driver setting (control panel,printers and fax, right click on lexmarkt642's icon, properties and check properties fully) in windows software that is running under merlin, also check merlin settings if any for this printer
Nov 20, 2007 | Lexmark T642 Laser Printer
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
