Question about Kenmore 22313 Bagged Canister Vacuum
Have suction, new bag, brush moving but does not
I have a Kenmore Elegance canister vacuum. I have suction, new bag, brush moving but does not pick up dirt. Just pushes it around. Help.
Solved!!!
I went to my local Sears store and the salesman there looked at my vacuum and was able to resolve the issue. There was a piece of wire that had been sucked into the machine that then blocked anything else from being vacuumed up.
Thanks for your help.
Posted on Jun 19, 2009
My fuller brush household canister vacuum doesn't have as much suction as usual. I've changed the bag and cleaned filter. Any other ideas?
. Test the suction without the pipes to confirm that the motor is sucking strongly, then check that there are no blockages in the pipes and fittings.
Jan 29, 2011 | Fuller Brush FBPTCAN Bagged Canister...
Does not pick up lint on carpet
I have a four suggestions. First, check the wand and see if the suction vent is completely closed. If this little vent has the slightest opening, the suction is reduced. cSecond,if that's not the case, you might want to check the brush/roller area. Threads and fibers caught on the brushes can prevent the vacuum from picking up lint. Third, make sure there are no fibers in the wheel of the vacuum head. And fourth, make sure the bag is not full! I often forget to check and back and a full bag is one of the main reasons a vacuum will not pick up items. I hope this helps. If one of my suggestions solves your problem, please contact Fixya and rate my solution!
Nov 21, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Vacuum shrinks, power is still on but no suction
perhaps there is something stuck in the vacuum. Look where the hose fits in. There is obvioulsy no blockage in the hose because you have suction. Do the power brushes spin on the vacuum?? Take the bag off, and inspect the area the bag fits in for blockage.
Jer
Jan 16, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
Kenmore canister vac 25614
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Feb 13, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
Jan 26, 2009 | Kenmore Vacuums
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
Carpet setting not working, no brush turn, no light, etc.
if the motor is running, its the belt, if not there is a break in your wire likely in the stub going from the wand to the head
Oct 18, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore 22313 Bagged Canister Vacuum Logo
480 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
