Question about Amana NTW4750YQ HE Top Load Washer
How do I reset the sensing cycle
Did diagnosis and there is a problem with the sensing cycle. the machine would not go past the sensing cycle and the noises for filling sound different
Washing machine will not start the cycle
Hello Teresa,
+What type of washing machine are we talking about here?
If its a newer electronic model... try unplugging the power cord for
a few minutes or consult your owners manual for a possible reset
feature.
If it is a older mechanical model then it's likely component failure.
Apr 19, 2017 | Washing Machines
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
My electrolux front loading washer won't go past sensing mode. What is wrong? What do I do?
Thank you for your inquiry, Sarah!
I see that your Electrolux washer will not go past sensing mode. This sounds like a possible issue with your sensor or door latch and I would recommend performing a reset on your washer to help clear out any miscommunications. You can reset your washer by disconnecting the power cord for roughly ten minutes.
I would check your door latch and door strike for any physical damage that could halt the progress of your washer. If you continue to have issues with your washer I would suggest having a professional out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Mar 17, 2015 | Electrolux Washing Machines
I have a whirlpool h2low top loader washer. The sensor will not advance past the wash cycle. What should I do.
Might want to check the switch that senses when the lid is closed. It won't spin if it thinks the lid is open. That might be holding up the advancement of the cycle.
Feb 12, 2015 | Whirlpool Washing Machines
WHy won't my washer finish its cycle?
check lid switch first, this is most common.(machine thinks lid is open), carefully lift and lower lid an you should here a faint click. otherwise i hit some timer issues but not so common. there is no reset, the model you gave comes back as electro-mechanical and not electronic
May 10, 2014 | Maytag MAT12PD Top Load Washer
How do I reset the machine
usually unplugging maching for a few minutes then plug back in if not then try opening and closing the lid slightly 6 times within a 12 second period
Apr 17, 2014 | Amana NTW4750YQ HE Top Load Washer
Top-load Whirlpool washing machine gets stuck on "sensing" stage of wash cycles
Hi my name is Charlie Lapinski. I will help you with your problem
is it locking the door at all?
Mar 29, 2014 | Whirlpool Washing Machines
Whirlpool WTW4950XW Washer won't go past the sensing cycle.
It may be as simple as a defective door switch or even a clogged drain hose (the hose between the tub and drain pump. Here are some videos that may help you more than i can. This guy knows:
http://www.youtube.com/watch?v=Aq7a3j7pFUM&playnext=1&list=PL5258B1D98A50745F
Jan 12, 2013 | Whirlpool WTW4950XW Washer
My display comes on. It stays on sensing. No error code. And dryer will not start the drying cycle.
Perhaps something in the manual. If you need one, I believe they are still available here - click on link or copy and paste into your browser -www.manualowl.com
Jimmy
Apr 07, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Amana NTW4750YQ HE Top Load Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
