Reset canon mp390 - Office Equipment & Supplies
Printer model#mp390 I replaced both cartridges but the alarm keeps going off stating put in cartridge?
i had same problem with 350 you need to google how to reset mp390 and follow instructions it sould be fine then
Apr 03, 2011 | Canon Office Equipment & Supplies
Tip
Reset procedure of Waste Ink Tank for Canon MP390 and Canon MP360
<p><span>Manual Reset procedure Waste Ink Tank for Canon MP390 and Canon MP360 Just Follow these steps to reset waste ink tank:</span><br /> <p><span>Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.</span><br /> <p><span>Select Test mode which is like the last available selection</span><br /> <p><span>Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button</span><br /> <p><span><span>&middot;<span> </span></span></span><span>The menu will now say EEPROM Clear</span><br /> <p><span><span>&middot;<span> </span></span></span><span>Select Ink count which is option (0) and press set</span><br /> <p><span><span>&middot;<span> </span></span></span><span>Then press Stop/Reset Followed by the power button and then wait for it to restart.</span><br />
on Nov 28, 2010 | Computers & Internet
My Canon MP390 Printer has come up ''Waste Inn Tank nearly full'' What should I do
CANON printers "compute" the "fullness" of the waste-ink container, based on the number of pages printed, and the "density" of the ink on each page. So, this calculation has produced a "nearly full" prediction. Take the printer to a qualified technician.
They will empty the waste-ink container, and "reset" the electronics in the printer, back to "zero-per-cent-full".
Aug 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Canon mp 390 waste ink near full
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
Dec 06, 2009 | Canon SmartBase MP390 All-In-One InkJet...
Canon multipass mp390 inkwell is full
You have to remove the entire printer engine and replace the ink absorber pad, you have to s, After that you have to go into diagnostic mode to reset the ink absorber level
Jun 18, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Canon Multipass390 Waste Ink Tank near full
Have a look here
http://resetters.blogspot.com/2009/04/reset-waste-ink-tank-canon-mp390-and.html
Apr 29, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MP390 Waste Ink Near Full message
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
Sep 11, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
sounds like it's not seated properly. That can happen when it's pressed in unevenly. Try to seat it straight on, with the printer on a shelf or table, at almost eye level.
Jan 06, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon Smartbase MP390
hope it helps
cheers
Dec 11, 2007 | Canon SmartBase MP390 All-In-One InkJet...
22 people viewed this question
k24674
