Question about Canon NP 6050 Copier
The belt is low - Canon NP 6050 Copier
  • 33 Answers
Its probley worn out do to heavy usage if refering to feed belt or other feeding mechinism. needs serviced by professional cause copiers are rather delicate and in need of know how as in the form of a tech.
Posted on Apr 15, 2014
Powerhead won't rotate on low-pile carpet
Sounds like the vacuum is adjusted too low on the carpet. Adjust it to a higher level. If this is not the problem, then the belt is slipping. Buy a new belt.
Dec 02, 2015 | Hoover Vacuums
Need belt 38528- brush belt
belts will stretch when they slip. There no adjustments on beater-bars. The way to prevent this is to have a height adjustment to be high on high pile and low for low pile rugs.
Oct 28, 2013 | Hoover U5780-900 Windtunnel Cyclonic...
Power steering for my Bora/Jetta 4 V5 has suddenly gone and its hard.
Priority Action Part Type Cause
1 Inspect Power Steering Fluid Low Power Steering Fluid Level.
2 Inspect Power Steering Pump Worn out or Damaged Power Steering Pump.
3 Inspect Power Steering Hose Leaking or Incorrectly Installed Power Steering Hose.
4 Inspect Belt Tension Incorrect Belt Tension Will Allow Belts to Slip.
5 Inspect Belt Incorrectly Routed, Adjusted(Tensioned), Missing or Worn Drive Belt(s).
7 Inspect Ball Joint-upper Worn, Damaged, or Faulty Ball Joint.
8 Inspect Ball Joint-Lower Malfunctioning Ball Joint.
What happes when a vehicle experiences a loss of power steering, is that the car reverts to a
manual steering car (like in the Model T days), making steering difficult, especially at low speeds,
and during low speed maneuvering.
May 13, 2011 | Volkswagen Jetta Cars & Trucks
Engine makes a squealing noise when running. No
is it comming from the serp belt?look when the car is off to see if the belt looks brown and shiny and or cracked,,it could be the belt is loose or just old and worn and slipping on the pulleys,,may be your noise,or if you mean squealing while driving it could be the brake pads are low and the low indicator squealers are hitting the rotors to let you know the pads are low and need replacement
Oct 15, 2009 | 2001 Ford Taurus
I am replacing belt on kenmore dryer but the new one from lowes seems to small are there multiple size belts for kenmore?
You need to match the belt to the specific make and model of dryer. There are several online appliance repair parts suppliers that can provide great assistance, and in some cases, the OEM part number for the belt. With the latter, appliance outlets like Lowes should be able to verify that the belt purchased is the part needed. In addition, check your owner's manual for a specific part number for the drive belt.
Oct 04, 2009 | Kenmore 63942 Dryer
Belt Keeps Coming Off
Replace the belt with afresh, proper sized one. Yours is stretched. It will be shiny on the underside. hoover belts are meant to fit snug. Check the bearings on the end of the brush roll to remove dirt and thread. The proper belt will need to be stretched into place using the brush for leverage. Likely that your low carpet is more dense causing enough drag to throw the stretched belt.
Sep 13, 2009 | Hoover U6616-900 WindTunnel Bagless...
Pressure low.
how do you know the pressure (im guessing you mean cylinder pressure) is low? this can be caused by : Leaking or bent valves from a broken t-belt or skipped timing (from loose t-belt), and bad piston rings how many miles on this motor and does it run at all? you should check your timing belt and be sure the timing is set correctly please let me know and be sure to rate this solution -jeff
Aug 29, 2008 | 1994 Honda Civic
Canon NP 6050 Copier Logo
old marine
old marine
