Question about Goodman Heating & Cooling
Tirn ac in blowing hot air fan not moving
Model ckl24-1d
    Genius:
  • Goodman Master
  • 1,363 Answers
Capacitor or motor bad.
Posted on Aug 14, 2015
Ice maker
  • 8 Answers
SOURCE: ac blowing hot air instead of cold
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
Posted on Mar 27, 2008
koolbreezes
  • 540 Answers
SOURCE: central ac blowing hot air outside fan not moving but making a noise
This is nothing but an either or -or ! First, make the thermostat calls for cool, there are suppose to be 2- noise outside, the fan motor and the compressor (and if a old system,a humming noise which is the contactor coil which picks up the main 240-volts).. hurry up and take a stick or something and turn the fan blades, if it picks up speed and run, then its the capicator. If not then the fan motor is bad.! (BOTTOM LINE)!
Posted on Jun 09, 2008
22yooper
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
  • 8 Answers
SOURCE: fan blows.. no cold air... no hot air exhaust blowing
This sounds like you either need to clean or replace the filter, but if the filter is some what new you might want to take a look at the coils just past the filter, if the coils do not have a shine to them then you might want to buy some coil cleaner (i found simple green or formula 50 works great), then you will have to spray the coils with the cleaner, let sit about 10-15 min, then give it a very good rinse with warm water. After that it should work like it is brand new. Enjoy!
Posted on Mar 30, 2009
  • 77 Answers
SOURCE: ac BLOWING HOT AIR INSTEAD OF COLD
Check to see if your outside unit is running. If not, check the breaker. If it is running you may have an issue with the reversing valve. It looks like three lines coming out of the top and one on the bottom. Trace the wires back to see that they are tight and secure. Of course, TURN OFF THE POWER first. good luck.
Posted on Apr 18, 2009
Vents won't blow hot or cold air. Comes from defrost and feet when you put fan on.
It's the vent actuator, it moves the baffle that changes the direction of the air flow.
Here is a video of a broken vacuum hose that creates the same problem.
It could also be a failed actuator.
Sep 19, 2016 | 1997 GMC Safari
A/c blowing hot air
Need a few more specifics:
in park? when moving ac will start to work?:
check Fan clutch or condenser cooling fan
Dec 22, 2013 | Lands Phones
My ac is acting funky. my ac will blow cold air as im moving. once i stop and idle for longer than 3 or 4 minutes, something will kick on and then it will start to blow hot air. as this happens, my car...
Start by checking to make sure that the a/c condensor and radiator is not full off debris. If the condensor and radiator were full of debris it will limit the air flow from the engine cooling fan which in tern will cause a high discharge pressure on the discharge on the a/c causing poor or no cooling at idle and could also cause vehicle to overheat. Check and make sure that the cooling fan as well as the condensor fan are coming on together when the a/c is turned on if equipped with 2 fans.
Sep 12, 2013 | 2004 Chevrolet Cavalier
Air cinditioning wont stay on, it switches to heat and wont shut off
What do you mean when you say it wont shut off? is it blowing hot air or do you just feel a lite flow of hot air even if you have the settings to cold?
If this is the problem that you always feel hot air at low flow and the ac goes to hot air then i would say one of two things, first if you have the selector to cold and you feel hot air then there may be a problem with the blend door, this door move to allow hot or cold air, the door may be broken or just a bad motor that controls it. keep in mind if the ac system shuts down for any reason the air then will be warm, it will be about the same temp as outside and maybe a little hotter.
this problem almost sounds like the ac compressor shuts off and then you are getting the outside air which is hot, there are many reasons for the compressor to shut off, it could be the compressor clutch heating up and disengaging , this would be due to a bad compressor clutch.
another reason is the fans are not working, the best thing to do is when the system starts to blow warm check and see if the compressor is running, start engine and look at the front of compressor, with ac off the front of it will not move, and then with ac on the front will spin, check it out and let me know, if it blows warm air and ac is not working then it may be compressor problem but if you are getting warm air and the compressor is spinning then it may be a door problem.
This is hard to check with out testing the system, so i listed a few things to check and let me know the out come. also the ac blows cold for how long before it gets hot air blowing out of the vents, good day.
May 25, 2012 | 2000 Dodge Grand Caravan
Ac blowing hot air
call service tech to check compressor
Aug 11, 2009 | Maytag M6X06F2A Air Conditioner
Air cinditioning blowing from cold to hot air
need to check ac fan or fans ,are they working? if not check fuses and fan relays,,,,,and fans (hot wire the fan to see if it/they work
Jul 05, 2009 | 2000 Acura TL
I have a 2002 Toyota Corolla Le and everytime my car is at stop sign my aircondition starts blowing out hot air but, once the car is moving the air starts back blowing cold. Do you know what might cause...
Make sure your fans are running. It sounds like your fans are not working all the time. With the AC on the fans should run constantly. Check fan relays and fuses.
Jun 13, 2009 | 2002 Toyota Corolla
Lennox air conditioner is blowing hot air
Check your coils for ice, check your breaker and fuses for condensing unit, and is your condensing fan running? If not, you either have a bad fan motor or capicitor. After you hit the button, and wait for it to time out, (you should hear a click) take a butter knife, and spin the fan if it is not moving. If the fan start spinning by itself after your assistance, you have a bad capacitor
Jan 29, 2009 | Heating & Cooling
Heater blows cold, and fan switch only works on 4 and 5
working on 4 and 5 speed that the resistor that broken cold air you got to move the selector to see the motor that move the trap hot and cold sometime when the motor was not move to the hot side for a long time its jam the motor on the passager side under dash put to hot and gently tap the motor tanks pierre
Oct 24, 2008 | 2002 Chevrolet Malibu
Central ac blowing hot air outside fan not moving but making a noise
Jun 09, 2008 | Heating & Cooling
Heating & Cooling Logo
37 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
