Question about X2Gen MG19MY 19" LCD Monitor
X2gen monitor power like just blinks and I have get no display.
I woke up this morning to the issue mentioned in the subject line.
I see micromend answered a question with the exact same description and monitor brand that I have at:
http://www.fixya.com/support/t2096687-blinking_power_light_monitor_will_not
I have plenty of experience with soldering and I am completely comfortable taking apart my monitor. Is there something I can replace to fix this issue?
  • 3 Answers
If you have soldering iron and can place an order at DigiKey.com (and are willing to get your hands down on this), this is a rather easy fix with some direction. You basically will be replacing some failing capacitors inside the unit. Post the values of the capacitors (brand, capacitance, Voltage rating and series) and I can suggest the replacements.
Posted on Jun 18, 2009
I have a X2gen MW19A monitor that will not display anymore. The green power button just blinks no matter what computer it is attached to. Any ideas on how to fix it or even how to open it up to see what is...
What kind of operating system ex. (Vista, XP, Win 7, etc.) are you using? Trying going into display settings. Start > Control Panel > Hardware and Sound > Display >Change Display Settings > Then click detect. If your computer cannot find it then there is a problem with the actual screen.
Feb 01, 2010 | X2Gen MG19MY 19" LCD Monitor
Bought a refurbished x2gen monitor, sent the wrong power adapter, not sure what one I need. The sticker on the back of the monitor says 12volt 4.0 amp but no hertz do you have any idea
You need to check on the monitor itself.Most of them will normally mention their ratings etc,,now 12v , 4 amps means 12*4 = 48 watts.So you can use a different adapter as long as it matches the power and voltage and it has the applicable connection.
Dec 08, 2009 | X2Gen Computers & Internet
Power lamp just blinks after power outage on my street
The post in following link fixed the same issue I was having with one of my 22 in X2Gen monitors. http://www.fixya.com/support/t2356502-x2gen_capacitor_location
Oct 07, 2009 | X2Gen MW22U Monitor
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Blinking Power Light and monitor will not come back on....
The monitor needs an internal eletronic repair. Do you have the the necessary anti static tools including soldering iron. If so I can help you with the repair, else take it to a pro.
Apr 27, 2009 | X2Gen MG19MY 19" LCD Monitor
X2gen 19 inch monitor wont power on
Had the same problem with mine. First you need a volt meter (radio shack about $15). check the push in connector and make sure it has coming from it.
Place you meter on DCV for DC voltage, Then place one lead in the end of the plug in the hole. (will not fit all the way so will need to hold it there, Put the other lead on the shiny part of the plug. If you get a reading of 12 volts +/- 1 volt your good. Depending on which lead is were you may get a minus reading this is fine as if you switch your leads around it will go positive. you must have the cord plugged into the wall to do this test. You will not get shocked or anything as 12v is not enough to hurt you.
If you have the 12 volts the problem is in the monitor on the male plug or on the board. this takes more to fix and must take the back off the monitor and fix the connection or replace. I did this to mine and it is working right now.
Apr 10, 2009 | X2Gen MG19MY 19" LCD Monitor
New computer, monitor issu
when you power on the computer ............after a second press F8
then advance boot option come after thet there is a option"enable VGA mode ............." press enter .finally window start up
then goto display properties and change the refreshing rate of moniter.
Apr 05, 2009 | X2Gen MG17J 17" Monitor
X2gen monitor flicker, unstabe display
The monitor costs about 100 bucks. The company is bankrupt. Chuck it and buy another.
Jun 26, 2008 | X2Gen MG15VT 15" LCD Monitor
Monitor area black
Please refer to the solution I just posted on the other problem posted in regard to this monitor.
--- Unfortunately, X2Gen has declared bankruptcy (see http://x2gen.com/) and there is no way to go back to the manufacturer for either support or warranty service. If you are still within a given time frame with either the retailer or perhaps through a credit card company, this would be your best recourse. My experience with this type of issue is that the hardware has gone bad. Particular with the nature of your problem, it seems that it is not a minor problem, and does not appear to involve drivers or other software-type fixes. If you could get a professional tech to repair it, the cost would most likely be more than replacement of the monitor. Sorry for the bad news, but I don't think there is a better solution.
Thankfully you have another monitor, so you are not left with no display device, but I am sure if you are using 2 monitors, there's a good solid reason and need for it. The other problem posted did not indicate that you were using 2 monitors, and so this presents one remote possibility. Try to switch the 2 out - move them between ports. If the "good" monitor continues to be good and the "bad" monitor still displays the same issue, I think that is absolute confirmation that you have a "nonnegotiable" hardware issue. If not, in other words, if you see something go wrong with the good monitor or the bad monitor improves upon the switch, there could be a graphics card/driver issue that we could work on.
Please post back if you need additional assistance, or this does not answer all your questions. Otherwise, thanks for using and rating FixYa! (Also, I would be very interested to know what does happen when you switch the two monitors... Thanks!)
May 29, 2008 | X2Gen MG19MY 19" LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
330 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
