Question about Jura Capresso Impressa Coffee Makers & Espresso Machines
Impressa c5 steamer
The steamer on the machine is sending so much steam it will not hold onto the steamer attatchment. I have scrubbed and maid sure the nozzle is milk free but the steam still blows it off ,too much stem coming out. Is there something I can do at home to fix it?
3 Suggested Answers
  • 2039 Answers
SOURCE: Milk frother /steamer not working
if you could remove the pipe put the pipe in a solution to remove the calcium in thr pipe dry calcium is like concrete dip it and use a piece of wire to clean cheers
Posted on Jan 19, 2008
SOURCE: No milk,or steam coming from cappucinno nozzle
If you pull the cappacino component off. The black plastic thing at the end of the metal tube (where the cappacino component's attached to) can be unscrewed by rotating it with your hand. You can clean it with a brush and a thick needle to clean the hole the make sure that it's not blocked. After that just screw it back on and reattach the cappacino component.
Posted on Jan 09, 2009
How can I deactivate the filter for impressa c5
With the machine in standby mode (that is plugged in, with the main rear power switch on, but you have not yet pressed the dial to turn the machine fully on), press and hold the filter button until the all three lights on the dial start to flash.
Simply turn the dial to the left until no lights flash.
That's it. The filter has now been deactivated.
Jul 09, 2014 | Jura Impressa C5 Automatic Coffee Center...
Looking for service manual for the Impressa X90. trying to figure out the routing on the steam knob hoses inside of the machine. I wan to make sure that I have them set correctly.
there is no such a thing as service manual only Capresso own repair pesonnal can see a repair manual,Capresso do not want anyone else to touch the inside of the machine,they want you to contact them and send in the machine
let me know if you can find any other solution
Aug 25, 2011 | Jura Capresso Impressa X90 Espresso...
Jura Capresso Impressa S9- no steam
I had a similar problem. I took off the side and rear cover, followed the hose that comes from the steam wand to the rear of hte unit. It enters a solenoid made by ACL Italy. I dismantled the solenoid unit by disconnecting the two hose ends, removing the relay, and unscrewing the plunger unit (vertical pipe). The plunger unit internals should move freely up and down like a piston in a cylinder , powered by a small spring. In my unit, this plunger was calcified and seized. I soaked it in boiling water and pressed on it gently several times and it unstuck. I put it all back together again and presto! Good luck
Feb 13, 2010 | Jura Capresso Impressa S90 Espresso...
How strong should the output for the cappucino/ latte steamer? Mine just sort of dribbles the steamed milk. Thanks
When steaming the milk/cream make sure to hold the rubber nozzle to the very bottom of the cup and also make sure you are leaving enough water to produce the steam after brewing a cup of espresso. Also you'll want to check the breather tube that sticks up from the nozzle and make sure it is free of buildup.When the steamer is operating correctly it should produce a loud growling sound.
Nov 06, 2009 | Nespresso D290 Espresso Machine
Eureka Hotshot Enviro steamer
Remove the 2 screws on the bottom of the steamer, that holds the center panel on. (Not the screws that hold the whole bottom.) Use a needle the clear the steam holes. Soak the panel in white vinegar for a couple of hours and scrub with aa brush to remove the lime calcium deposits. Check the center hole that goes into the steam and make sure it is clear. Reattach the panel. If the panel does not fit snuggly (either end does not contact the base panel, add two more screws about an inch in from either side. I used stainless steal screws because of the consist moisture. Used screws that are no more than 3/4 on an inch long and about the same diameter as the two you removed.
Jun 08, 2008 | Eureka Enviro Steamer 310 Stick Vacuum
Need directions on how to clean clogged steam nozzle
If your steam mop is Enviro Steam Mop by Eureka. remove the 2 screws on the bottom of the steamer, that holds the center panel on. (Not the screws that hold the whole bottom.) Use a needle the clear the steam holes. Soak the panel in white vinegar for a couple of hours and scrub with aa brush to remove the lime calcium deposits. Check the center hole that goes into the steam and make sure it is clear. Reattach the panel. If the panel does not fit snuggly (either end does not contact the base panel, add two more screws about an inch in from either side. I used stainless steal screws because of the consist moisture. Used screws that are no more than 3/4 on an inch long and about the same diameter as the two you removed.
Apr 06, 2008 | Eureka Enviro Steamer 310 Stick Vacuum
Coffee Makers & Espresso Machines Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
