Question about Dacor PMOR30SS Microwave Oven
How to program rerig. for new board
Need to replace main board #w0317076 and need directions how to program code
I have a GE JKP62G microwave-oven combo. The oven works fine. The microwave blew the 15 amp fuse. When I replaced the fuse, per your earlier directions, and tried to use the microwave, the new fuse blew....
Cause 1
If too much current passes through the microwave circuitry, the line fuse will blow. If the line fuse blows, the microwave won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don’t resolve the underlying issue, the new fuse will blow too
Cause 2
Main Control Board
The main control board might be defective. However, this is rarely the case. Control boards are often misdiagnosed—check all of the more commonly defective parts. If you have determined that all of the other components are working properly,replace the main control board.
Cause 3
Thermal Fuse
The thermal fuse cuts off power to the microwave if the microwave overheats. To determine if the thermal fuse has blown, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. The thermal fuse cannot be reset—if the fuse is blown, it must be replaced.
Since its a electrical isue cal a liscenced professiona to resolve the issue . Your microwave oven isnt at fault . I belive the supplay to it has issue and would have blown anyway.
May 29, 2018 | GE Microwave Ovens
After each use, microwave clock disappears and microwave will not work until clock is reset. The clock will not allow itself to be reset unless we reset the circuit break which was not tripped.
Sounds to me like a fault with the main circuit board. Lets say the microprocessor on the board is bad and it locks up or just doesnt display the clock or time. When you reset the breaker you are resetting the main board. and it works until the processor fails again. Sound like may need new main PC board. Timer board. Caution!! Pricey??? Check cost of board before persuing, may be more wise to replace unit. and get new full warranty
Oct 13, 2017 | Microwave Ovens
We have code F84 coming up on our Electrolux microwave, wall oven. Seems to be affecting the microwave. Any ideas what might be going on?
The F84 code is a communication error between the user interface panel of the microwave and the main control board. This could be the result of a problem with the touch panel's interface board, the main control board or the wiring between them. (The wiring harness can come loose or have a bit of corrosion at the connectors.) The usual recommendation is to check the wiring at the interface board then replace the interface board first. If that doesn't solve the problem, you have to replace the control panel.
If you add a comment with the model number of the unit, I may be able to help you find the parts your unit needs.
I hope this helps.
Apr 09, 2017 | Electrolux Microwave Ovens
WMG30GS Whirlpool microwave display
please follow this steps and fix it. God bless you
  1. Main control board If the display on your microwave has gone out completely this is usually a sign that it is a malfunctioned main control board. To correct the issue the main control board would need to be replaced.
  2. Display board A display board can either malfunction completely or partially, causing two separate results. If the display on the unit has completely gone out, this can be attributed to either a bad main control board or display board. On the other hand, if the display has only partially gone out, this is usually a sign that the display board is defective and will need to be replaced
Nov 27, 2013 | Microwave Ovens
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Nov 15, 2012 | Whirlpool Microwave Ovens
GE Microwave # JESYO39WF001. Control panel locked up, beeps. Turned off and on. No help. Shows PF and other codes. Asks to enter code but key pad does not work. Help
Your the 2nd one today..bad main control board.. Cheaper to buy a new one
microwave unless you can find a replacement board and do it yourself... tell me what you want to do and I can walk you through..board is about $100 if you can find one.plus shipping repair shop would cost $200-225 incl. parts if they can get them
Oct 16, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Micowave shows f3 willnot clear
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.
The codes represent there is an error and as there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Aug 22, 2011 | Kenmore 61632 Microwave Oven
Brand new microwave lights up plate turns around everything works except nothing heats up! how can i fix it
Since this is a new set you must claim for the free warranty on the set before you try to tamper.
If you want to continue check with these tips.:
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean , solder and reset the board.
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
Jul 27, 2011 | Daewoo KOR6N9RR Microwave Oven
My micorwave
Hi and welcome to FixYa,
Your described problem indicates that the logic circuitry in the main controller board is faulty. Since the logic circuitry is integral to the board, it would require an assembly replacement. On most brands/models, the main controller board is directly behind the display panel. In some instances, it could be a stuck key/button hence the logic would not reset.
Good luck and thank you for using FixYa.
Feb 13, 2009 | Samsung Microwave Ovens
Fans runs when door closed, light always off
The first thing to replace is your technician. *grin*
You have a shorted main relay (lamp relay) on the control circuit board and a burned out light bulb.
You do not need a new board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Page 24 of your owner's manual shows you how to replace the light bulb. Be sure to unplug it first.
If you don't have your manual, you can download it here.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 13, 2008 | Maytag MMV1153A Microwave Oven
Dacor PMOR30SS Microwave Oven Logo
15 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
