Akg c4000b hum - Audio Players & Recorders
    New Friend:
  • 40 Answers
Usually humming is caused by defective cables. Check if the cable is wired correctly. Open both XLR plugs and check:
Pin 1 shield
Pin 2 hot (usually red wire)
Pin 3 cold (black, blue or whatever)
Pinnumbers are written near pins usually.
If that doesn't help shake the cable for contact issues.
The microphone could have a broken shield connections as well. Maybe there's a small screw near the XLR output connector. Unscrew (sometimes this screw needs to be turned CLOCKWISE) and check connections.
Posted on Apr 24, 2014
C1000s hum/buzz on phantom power
possibly the microphone needs more power than your sound card can supply although I cannot imagine as the duet is a good piece of equipment.
Is the duet USB bus powered?
Have you tried another cable? Possibly one wire is defective which means that phantom power will superpose the audio signal. In this case you might hear a hum. By the way this results in 6dB of signal loss. This is why XLR plugs have 3 wires. If connected with a 1/4" jack it has to be a stereo plug (tip, ring, sleeve)
Mar 26, 2014 | AKG Audio Players & Recorders
I have a AKG T912 Head phone how i can re charge it
Hi,thanks for posting your Question.
You can only charge the AKG T912 Head phone with its cradle...
Use the link to get a replacement..
http://www.listeningpost.co.nz/Brands/AKG/Listening-Post-Christchurch-AKG-K912-Wireless-Headphones__I.13996__N.27183__C.27343
Hope it helped.
Sep 14, 2011 | Audio Players & Recorders
Hum which is made worse on touching top half of mic. clearly an earthing matter. engineer has checked bottom half but does not know how to get into top half.
I have the same mic, same problem. I disassemled the mic, put it back together, and the problem fixed itself. I can't explain exactly why.
To disassemble the top part of mic, turn the 2 plastic posts inside the mic clockwise.
http://www.akg.com/mediendatenbank2/psfile/datei/96/C4000b4055d1f13eb44.pdf
Mar 18, 2011 | AKG C4000B Professional Microphone
Need a new "guitar bug"(wireless
It looks like you are after the AKG GB 40 guitarbug
They appear to be a discontinued item in a lot of places
This list several place that say they have them, one for $29.95
www.thefind.com/electronics/browse-akg-gb40-guitar-transmitter
Also
fatheadmusic.co.uk/product/2367/akg-gb40-guitar-bug
or
www.proaudiosuppliers.com/akg-gb-40.html
Jan 31, 2011 | Audio Players & Recorders
I have three working AKG C1000S. They all need grills. Who can I trust to service or sell grills?
AKG sells the replacement screen and tube assembly direct from AKG Acoustics, U.S.
+1 818-920-3237
akgusaservice@harman.com
They are expensive, $80.00 each.
Oct 25, 2010 | AKG C1000S Professional Microphone
AKG D12E, WIRES INSIDE SEEM OK AM GETTING GROUND HUM BUT NO SOUND OTHER THAN GROUND HUM
One of the coil wires in the diaphragm might be broken. Try testing it with a volt ohm meter.
Jan 22, 2010 | AKG Audio Players & Recorders
AKG C 451 E sometimes it cuts out. It cannot take
It might be a humidity problem.Here is a repair link:http://www.akgmicrepair.com/ Here is where the service documentation can be found :http://www.akg.com/site/powerslave,id,7,nodeid,7,_language,EN,cat,11.html
Oct 23, 2009 | AKG Audio Players & Recorders
I have a slight hum in this mic. have swapped cables, mics, et. It definately comes from this mic this is the original C3000 (black) not the B model.
Try the mike on another PA. Sometimes power phantom do weird things with electrical installations hum on the line. Let say commercial fridge.
Aug 05, 2009 | AKG C3000B Professional Microphone
Akg mic buzzing
constant unrelenting hum?
check the fuse housing and make sure it is setup for your local voltage(120/240)
Jul 23, 2008 | AKG SolidTube Professional Microphone
111 people viewed this question
 Grubhead
Grubhead
