Macbook pro firewire 800 port not working. Was working last night but when turned system on today drives didn't boot. I have tried rebooting the PRAM but no difference. Have also tried the obvious by tring different drives and cables - all devices show up on my PowerBook G4 Computer is a mac book pro 3.1 2.2ghz Intel Core 2 Duo Memory 4GB 667 Mhz DDR2 SDRAM
  • colinboland Jun 19, 2009
    ginko came to the rescue and helped me solve the problem. I stumbled onto this service in a search engine and now will happily use this and reccomend to others - A+++++
    Thanks ginko
  • 19,396 Answers
The first thing you can do is turning off the Mac, unplugging power adapter cable, and removing battery. Wait about ten fifteen minutes with no battery, and then connect everything back.
That operation will drain power completely, and can fix a jammed firewire circuit because of electrostatic charges accumulating o firewire control circuit capacitors.
If after this the forewire is still not working , try switching ports, look for port conflicts, and use Mac updater to update the system.
You can follow general troubleshooting instructions on this website:Mini-Tutorial: Dealing with FireWire problems.
If still no luck after you do all the above, then the firewire may be faulty. to test it you have to reinstall mac os, and test different devices on same port. However, before taking this way, contact apple, as a faulty firewire on a Mac is quite uncommon.
Regards.
Posted on Jun 18, 2009
Colored circle comming up
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Feb 28, 2014 | Apple Computers & Internet
Locked
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Feb 23, 2014 | Apple Air Computers & Internet
World icon with exclamation mark in the center macbook
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jan 27, 2014 | Apple Computers & Internet
Restart appears on start up
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jan 26, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jan 12, 2014 | Apple Computers & Internet
Can not click on icons
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Dec 25, 2012 | Apple MacBook Air
Forward slash not working on my macbook air
Did you change the system font to one you downloaded from the Internet? Some of those are missing characters. If not,
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Dec 04, 2012 | Apple MacBook Air
Keyboard not working
If you were using a bluetooth keyboard, it may still be looking for that keyboard.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Nov 22, 2012 | Apple MacBook Air
Three-finger swipe between desktops not working as expected.
I'd try adjusting your setting in
Apple menu
System Preferences
Trackpad.
Not sure what key combination can affect those settings.
If that does not help try resetting the PRAM and or the SMC.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jun 06, 2012 | Apple MacBook Air
My apple macbook air shows a question mark when i turn it on
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
May 22, 2012 | Apple MacBook Air
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
