Question about Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer
Washing machine tub fell down about 3 inches in back
2 Suggested Answers
Excellency
  • 20 Answers
SOURCE: Front end washer lights come on but doesn't fill.
it fell out of the dispenser, hold the dispenser facing away from you on the left side there is a small slot, place the magnet in vertically so the long side of the magnet is on the right when looking from the front with the drawer closed good luck
Posted on Dec 10, 2008
Overflow during cycles
There is an adjustable water level sensor up in the electronics bank on many Whirlpool toploaders. It is usually metal, about 2 inches around and has a 3/8" diameter hose going down to the tub that senses air pressure as it fills. Try to back off the half inch screw in the center a little. Check on Google images to see if your machine has something that looks like this somewhat universal adjustable "water level sensor"
(use quotes around your search phrase).
Mar 06, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
The wash tub is overfilling with water
Number 10
Is yall's washer water level switch. It is connected to a tube comin up from the base of the tub.
That tubing must be clear and firmly attached to the switch so that air pressure from rising water can trip the water level switch. The switch has 3 wires. one common wire from source, a wire to the water valves and another to the motor. When pressure builds to desired setting power is shifted to motor and wash cycle begins. Water valve is shut down. You have a clogged tubing (sediment) or the tubing has fell off the switch. The switch also could be bad but that is RARE.
More Here
Feb 27, 2011 | GE WWRE6260D Top Load Washer
At end of spin cycle,machine seems to be out of balance. Vibration and noise are severe
1=WASHER MUST BE ON SOLID FLOOR,IF YOU CAN FELL IT SHAKING 2FT OR MORE BACK FROM YOU,YOU HAVE A WEAK FLOOR.
2=BALANCING RING BAD,REPLACE ..
3=MAKE SURE THE TUB IS NOT LOOSE
THANKS LACUZ12
Feb 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I HAVE REPAIRED THE RUBBER DRIVE COUPLING ON MY WHIRLPOOL 3LBR6132EQ TOP LOADER. WHILST REPAIRING IT A FLANGED PIN OF 10MM DIAMETER FELL OUT. THE WASHING MACHINE SEEMS TO HAVE VERY BAD VIBRATION IN SPIN...
The pin fell out of a catch cup used for transporting the washer when new. It is not important unless you put it some place it does not belong.
If you laid the washer down to do the repair you probably got the base plate out of alignment. Open the lid,reach inside and grab the wash tub. Pick it up as much as you can and shift it around. It will usually reseat the plate.
Also block the front of the washer with your foot and raise the rear of the washer off the floor. The self leveling legs should drop down. Let the back of the washer loose and it will settle in on the leveling legs.
This washer should be left in the upright position to change the drive coupling.
Jan 04, 2010 | Whirlpool Washing Machines
I have a Kenmore top loading washing machine model 92529110. My wife has been noticing that the tub leans toward the front causing the water to hit the back edge of the tub instead of running straight into...
The machine needs to be leveled. Unscrew the front legs until the machine is level. If there isn't enough screw, or if your floor is really uneven, put a board under the front legs. After you get the front level, lean the machine toward you, tilting it front, until the back feet are about 3 inches off the floor. Let the machine drop. This will set the back legs into position. They are self leveling.
Nov 14, 2009 | Kenmore Washing Machines
Drips from center of front cover when filling at 3-4 inches
after carefully reading this, the leak is at the machines water valves, or from them to hose to tub.
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Dec 10, 2008 | Frigidaire ATF6000ES Front Load Washer
The tub @ my Fisher&Paykel model #GWL-08-US1 is off balance
you can lift the top and get a closer l;ook, by opening lid and looking approx, 4 inches back along side rail, youll see a rubber plug, remove the plugs toreveal the screws hoding down the main top. after emoving screw lift the top back and you see the 4 suspension bars tha hold the machine, either one "popped" or the left front corner should have a sdpring attached form it to the tub( clips on to the red little bracket on side of outer tub). either of thesse swill fixyour problem
Dec 03, 2008 | Fisher and Paykel GWL11 Top Load Washer
Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer Logo
22 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
