Question about Ridgid Rd80702 3300 Psi 3.0 Gpm 7 Hp Subaru Ex21fi Ohc Gas Powered
Ridgid rd80702 will not start
Will not fire, floods out
  • 33 Answers
In alot of cases like this after its been flooded a bunch the spark plug is fuel fowled and you need to replace and make sure air filter is clean. Also make sure you have good spark by holding wire to spark plug about a one fourth of an inch away from plug and try to start at same time but not to do this alot . Just enough to test and see if you get ark of juice between wire and plug. I would do this test with old plug first if you have spark install new plug. This type of equipment has a notorious on - off switch malfunction problems. Worst come to worst carb needs rebuilt or magnito is out. Good Luck !
Posted on Apr 15, 2014
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Sounds like the float is stuck open. A few taps with a screwdriver handle on the fuel reservoir might fix the problem.
2005 Saab 95. No start engine cranks but no start
Probably not the crank sensor if it is firing.
You can disable the fuel pump and try to dry it out if you think it is flooded. Then find out why.
Aug 26, 2014 | Cars & Trucks
It starts easy and runs for about 10 minutes and cuts off. Have to wait 30-45 min. to restart with the same cutting off problem. Have always had a problem with restarting even when I shut it down on m
If your oil is too low or even a little bit low or if your machine is sitting on an incline, it will start and run until the oil is dispersed within the motor. Spreading the little amount of oil that is in there all around the inside of the motor would then reduce the amount of oil that is "sensed" by the "low-oil safety shutoff" switch, which would then shut down the engine. Its possible that your "low-oil sensor switch" is bad. You can test it by unplugging it. Just look for a wire that runs from your ignition switch or ignition coil to a sensor mounted on the engine block somewhere. Usually, it just unplugs right at the sensor. Simply unplug it and crank the engine and if it keeps running, then you know you have a bad switch (if you've topped off the oil, of course!).
Jul 07, 2014 | Ridgid Pressure Washer. 3000 psi 2.6 GPM...
Ridgid pressure washer motor runs choppy when choke is disengaged
The choke reduces the air flow into the carb. If you are having problems with the choke off, it means that not enough fuel is getting into the engine and it is running lean. When you choke it, the reduced air flow causes the mixture to be correct and it runs fine.
Feb 09, 2014 | Ridgid Rd80702 3300 Psi 3.0 Gpm 7 Hp...
Flooded r4512 total rebuild
Ridgid might be able to supply some data.
Nov 07, 2013 | Ridgid 10 in. 13-Amp Professional Table...
Pneumatic framing nailer firing pin
sounds like you need to replace the oring around the firing pin piston , or replace the oring or band around the cylinder that the firing pin goes in , it should be the smaller oring that has tiny holes behind it when removed
Sep 22, 2012 | Ridgid Air Tools & Compressors
Ridgid mobil airpressure switch trouble
This condition will occur when the in-tank check valve is stuck open. Pressure from the tank increases load on the motor by flooding the pump with tank pressure not allowing motor to start thus reset opens. Easy test. Run compressor for one minute then unplug cord from wall. Remove hose at the check valve and test for leak with soapy water. If leaking remove valve and attempt cleaning or replace with generic valve. Cost about $20. Good luck.
Sep 08, 2012 | Ridgid Compressor With Toolbox On Top
The gun will fire but the plunger will not retract back up into the chamber.
This unit likely needs oiling +/or O-rings. See the link below and enter your model number to get a complete parts breakdown diagram. Focus on the o-rings for the main plunger assembly.
Dan
Link: http://www.ereplacementparts.com/ridgid-parts-c-7929.html?gclid=CJj0yNXm0qMCFZxo5Qod9QMmug
Aug 19, 2010 | Ridgid 2 12" Angled Finish Nailer R250AFA ...
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
I have a ridgid brad nailer. I am running about 100 psi. It will not fire. I hear it try, meaning the I hear air coming out, but not a fire. I tried my other gun ridgid finishing nailer and it is doing the...
insert a open fitting adapter into the connection end and make sure you are getting a good air flow with open ended connector hold away from face and eyes while doing test and be sure the fitting is well seated into coupler before releasing . let me know result
Dec 28, 2008 | Stanley Pneu Roof Stapler
Ridgid Rd80702 3300 Psi 3.0 Gpm 7 Hp Subaru Ex21fi Ohc Gas Powered Logo
161 people viewed this question
Top Ridgid Garden Experts
protojexxx
Lakeland Appliance...
Are you a Ridgid Garden Expert? Answer questions, earn points and help others
