Question about HP Compaq 8200 Elite Convertible Minitower Desktop PC Save
Motherboard Problem PSU is functional but motherboard is not work
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
I don't mean to sound stupid, but how do you know the PSU is functional if the motherboard wont fire up? The power supply has to have a load on it before it will test positive. You could disconnect everything from the PSU and put a large 10k resistor in place of the power connection to simulate a load. Does the mobo have an LED Activity light when it is connected? Have you previously worked on this computer? Is the mobo properly grounded? Have you looked for any signs of a resistor or other electrical component having failed?. There can be numerous reasons why you are having problems. I would need a more detailed explanation of the events leading up to the problem and a better description of the equipment and the environment.
Posted on Apr 18, 2014
  • 22 Answers
What type of motherboard do you have?? Brand and model. After you find it out search the web for a manual. Then open up your pc check the cables which go from PSU to Motherboard and check if they are connected properly (See on manual the correct positions ) :D . Hope i helped
Posted on Apr 15, 2014
My hp_compaq_8200_elite_convertible_minitow PSU is functional but the motherboard is not start
On some models, an unplugged Processor fan will prevent the motherboard from starting. Check your fan connections. How have you determined that the PSU is functional? Is the PSU fan starting?
Apr 15, 2014 | HP Compaq 8200 Elite Convertible Minitower...
Asus P5GC-MX/1333 system wont boot up, motherboard light on (blinking), fans on PSU not working, fan on motherboard not working, is that a sign PSU went bad? (it was OK a few days ago)
yes
it can be problem wth psu hence insert a wire in green socket and another in black socket of psu and this will short and psu fan will rotate. if psu fan rotates then you need to check the voltage supplies of the psu.
Apr 01, 2014 | ASUS Computers & Internet
Diagram of 24 pin and its function to a mother board
24 pin socket in motherboard is used for connecting the power cable from the PSU.
Image are given below..
Motherboard connector.
PSU connector..
Thanks for using FixYa.
May 19, 2011 | Computers & Internet
Unable to install windows7 on MotherBoard Version: ZX-I945LM4 VER:2.2
You need a fully functioning PC to install an operating system like windows 7. This includes a CPU, GPU, RAM, HDD, motherboard, PSU, and generally a case. Just a motherboard isn't going to cut it.
May 02, 2011 | Computers & Internet
Problem with the EliteGroup ECS A790GXM-AD3 AM3 AMD 790GX HDMI ATX AMD Motherboard Help please, no power What is the recommended Power Supply Wattage for this MB i am using a Diablotek 550 Watt. I checked...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 15, 2010 | EliteGroup ECS A790GXMAD3 AMD 790GX MB w...
My P4 VMM 1.0 with win 98 and XP always restart after shuting down. Please help me to solve the problem
This is most commonly an issue of either the ACPI instruction being sent to an ATX power supply being misinterpreted as a restart command, or the controller in the power supply being faulty in general.
The root of the issue can be either your motherboard, or your power supply itself. To test this, try using a different power supply on the motherboard. If it works fine, try testing your power supply on another motherboard. If your power supply works fine there as well, then there's simply an incompatibility of some sort between the motherboard and PSU.
If on the other hand it doesn't work fine on the other motherboard as well, then you know the PSU is faulty.
The degree of fault in the PSU can be anything between harmless and severe; for safety's sake, I would recommend replacing the PSU entirely if a new/different PSU resolves the issue, as your PSU burning out may cause damage to your motherboard and/or (other) connected devices.
Mar 16, 2010 | EliteGroup P4VMM2 Motherboard
PC dead. Replaced power supply. No lights. No nothing.
When that happens it is usually the motherboard.
To test parts you need a benchmark.
PSU can be tested using a multimeter.
Motherboard is tested using a tester like this one: PCI Test Card, PC Analyzer, Motherboard Test Card
Ram and CPU (CPU sometimes get damaged) are usually not damaged by this kind of problems, they can be tested mounting them on a working motherboard. For the RAM we also use a RAM tester that costs about $200.
Ensure also that the switch contacts to new motherboard are installed properly. A technician can test cabinet power switch using a multimeter, or carefully bridging with a screwdriver the switch on contacts on motherboard (do not do this unless you are sure about what you are doing)
Test the new PSU on a different socket, when a PSU blows , it may damage the main socket.
Also remember that new power supply units have two connectors. The big rectangular main one (24 pin) and a smaller 4 pins squared one.
As an home user you may not have access to testing equipment, therefore my suggestion is.
Ensure you are using the right PSU.
Ensure that the motherboard is connected to power switch.
Test the new PSU with a multimeter.
Examine the motherboard for blown or leaking components and burnt areas.
If you do not find anything, but the mainboard is still not working, then buy a motherboard-cpu bundle compatible with the PSU that you bought and assemble a new system inside the old cabinet.
Regards.
May 04, 2009 | MSI K8MM-V Motherboard
Working fine until psu packed in, replaced psu, begins power up
The PSU dying may have destroyed the motherboard also. Try removing all interface cards and disconnecting all drives to make sure.
Nov 11, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Upgrading power supply
The next time you get a PSU. Tell them what you have. Apparently you got one that is not compatible with your compaq.The power (500 wattage) will work with your MB.
Get an OEM PSU from Compaq(HP).
Dec 02, 2007 | Compaq (253219-002) Motherboard
No beeps, no picture!
please check whether there is burning in the motherboard due to this there is no switching in the motherboard. plz get the motherboard repaired. their is no problem in replacing the 20-pin psu
Oct 04, 2007 | Compaq 187498-001 Motherboard
HP Compaq 8200 Elite Convertible Minitower Desktop PC Save Logo
339 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
