Question about Toshiba e-Studio 2050C Multifunction Copier
Document feeder paper jam file storage error estudio 2050 toshiba
  • 643 Answers
SOURCE: automatic document feeder
U need to check whether the flap-exit is working or not.
http://img.photobucket.com/albums/v390/anthonydidi/flap_exit.jpg
Posted on May 12, 2009
  • 125 Answers
SOURCE: I have a toshiba EStudio 162 error message L100-00 how do I fix
Hi:
If the error code is an L-1 the most lokely cause is the scanner lock on your machine is engaging with the scanner assy. Bend down and look at the left front corner of the copier right inside of the area where you grab your copies. You should see a clear round plastis knob. This has to be in the fully unlocked position If it is partly turned then this can be stalling your scanner assy and throwing the error code your seeing.
Good Luck
Andrew
Posted on Jun 27, 2009
  • 10 Answers
SOURCE: toshiba estudio 200 keeps having false paper jams
sorry,,, it is not feed roller problm, (not every time same couldbe happen with feed rollr) ghost jams bothers with cassette
Posted on Oct 16, 2010
riceski
  • 1851 Answers
SOURCE: The automatic document feeder jams. Paper
You must unplug it and flip it over - you have something down inside it - paper clip or something - this happens from time to time.
Gary @ FixYa
Posted on Nov 15, 2010
  • 231 Answers
SOURCE: We have an Toshiba estudio 205 copier and are
E14 Cassette 2 feeding jam (PFU)
check for pices of paper in the sensor area, if you can not see any you will have to call a tech to check if the paper sensor si not damaged.
Posted on Nov 18, 2010
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
Document feeder error message
did u guys ever use maginzes to scan documents with they will get jamed in there i would open it up cheak feeders closly ok thx nick
Feb 09, 2008 | Office Equipment & Supplies
How to reset all originals in DP Kyocera km 2050
It just means take all the pages out of the document feeder on top and put the whole complete document in again
Jun 14, 2015 | Kyocera Mita KM-2050 Printer
Giving error place doc.feeder in the down position
problem with the feeder sensor >>top at the arrow
May 07, 2011 | Toshiba estudio 305 Copier
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Toshiba eStudio 203SD. ADF doesn't work despite tech "fixing" it. Put docs in ADF, message "Check ADF/RADF."
Most likely there is a sensor that is out of place. That is the most likely problem. If it is not out of position then it may have failed. But what is happening is when you insert the document into the feeder, the machine is detecting a paper already in the feeder.
Aug 03, 2010 | Toshiba Office Equipment & Supplies
I'm have error code e12 in toshiba estudio 350,pls help me!
hi there is paper jam in paper path plz first cheq yours machine for paper jam
thanks
May 12, 2010 | Toshiba e-Studio 350 Copier
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Automatic document feeder
May 12, 2009 | Toshiba Estudio 200L Copier
Toshiba e-Studio 2050C Multifunction Copier Logo
79 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
