Receiver Marantz SR 930
Hello, immediately after powering up the receiver, the sound on both channels is being cut off for a short time, then comes again, is being cut off again, and so on for several times, accompanied by a soft rumbling noise, and after a while everything is fine for a quarter of an hour with normal sound quality, but then the procedure starts again. The sound level is rather low and the reception quality is perfect all the time. Any hints what to do? I am not an electrical engineer but able to change parts if informed in a reasonable way with not too much abbreviations I do not know ... Please help if you can. Thanks so much, Lisa
  • 4 Answers
When the unit detects a problem, it shuts itself off to prevent any further damage. Your outputs (the IC's that give you sound) are most likely bad. You would need to know how to solder, etc. to replace them. Your best bet is to take to a repair shop if you can find one...
Posted on Apr 16, 2014
killer_clown
  • 86 Answers
SOURCE: SA8 5.1 receiver overload comes on with no sound
Try checking your fuse if it overloaded then it probably blew it
Posted on Oct 22, 2008
SOURCE: Marantz SR 7200
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
Posted on Mar 29, 2009
  • 8 Answers
SOURCE: Marantz SR-18EX Loses Memory and Has Distortion on Center Ch.
There is a 1 Farad "super capacitor" that needs to be replaced. You need soldering skills to do it. The board is accessible if you remove the front panel of the receiver. The part # is DB-5R5D105; you can get them on eBay for about $2.00 each. Regarding the center channel issue, you may have a bad solder joint on the P781 connector on the P774 board. This is the board that houses the output transistors for the 3-channel main amp board (P704). If not these solder joints, you have a weak driver transistor on P704, and troubleshooting would probably be best left to a pro. Good luck!
Posted on Oct 18, 2009
SOURCE: I have a Marantz SR5500 and the unit will not stay powered on.
I have this problem. it is caused by an o/c mains transformer primary winding. the clicking and flashing light is the stanbyy circuit trying to switch the power on to the main (large) transformer when it gets no voltage out it switches back off
Posted on Jan 29, 2010
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
Marantz SR-66 Shut down!
Sounds like the protection circuit is tripping. With power off, check for loose speaker connections. Also, look very closely for shorts in the speaker wires. Even a single loose strand can touch another connection and create a short, which shuts down the receiver.
I would take take the frequency splitter out of the circuit and see what happens. Check for acceptable impedances in the manual. The receiver may not like the load the splitter presents.
The receiver may have settings for bi-amping. Then you use one set of terminals on the back for treble, and a different set for bass.
Feb 03, 2015 | Marantz SR-66
Marantz SR-14 EX 5.1 Channels Receiver fuses.
Changing the type of fuses in your receiver will not change your sound quality at all.
Jun 07, 2012 | Audio Players & Recorders
How to reset marantz sr4003
marantz SR 4003 how to reset (hard reset ) remove power plug from power .Take cover off locate ic 12 (24 c eeprom) short pin 5 to ground while plugging the power in .Unit will show clear on fl screen .if the unit trips again check channels.
Jan 04, 2012 | Marantz SR4003 Receiver
I have a MARANTZ SR7000 Receiver . I would like to play music CDs in direct source mode and also be able to use the subwoofer. How does one do that.
Not sure that this will be possible, direct source will cut out any changes made by the amp, and as a cd is 2 channel stereo, it wont include the subwoofer. Try some of the other settings with direct source mode.
May 03, 2011 | Marantz SR-7000 Receiver
Aug 17, 2009 | Marantz SR-18EX Receiver
Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Oct 02, 2008 | Marantz SR-7200 Receiver
Receiver will not turn on
It is probably shorted out. the fact that you hear a relay click is bad news for you. Take it in and tell them that you cannot get power from the switch through to the main board.
Jul 26, 2007 | Marantz SR-7300 6.1 Channels Receiver
No output from left channel after crackling sound
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Jul 08, 2007 | Marantz SR-4200 Receiver
Marantz SR 7200
Good luck.
Jan 29, 2007 | Marantz SR-7200 Receiver
Marantz SR5200 - front speakers not working unless direct
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
Aug 26, 2006 | Marantz SR-5200 Receiver
83 people viewed this question
 Grubhead
Grubhead
