Question about Kitchen Appliances - Others
Icemaker not making ice
My Daewoo FRS-U20DCI HAS STOPED MAKING ICE WE WERE NOT USING IT ON A REGULAR BASIS ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 38 Answers
Chances are that the liquid has disovled/solidified you will need to get an engineer in to refill the gas cyclinder/or you could just try using it every few hours to see if it will release the solidation of the liuid make sure you use at least once a week in order to keep the lubrication of all components lubricated
Posted on Apr 15, 2014
  • 4 Answers
Sometimes when the icemaker is not used,,water will thaw, drip/pool around the auger,,this will keep it from dispensing.
take the bin out, inspect all the parts for ice...ck that the on/off wire is in the correct position
SOURCE: ge monogram zd115c automatic icemaker not making ice
Have you checked to assure the long narrow hose that comes from the upper lback left corner is attached both on top and inside the water tray? This drove me nuts for 3 hours.
Dan
Posted on Jul 29, 2008
22yooper
  • 828 Answers
SOURCE: Not making ice
If your machine is air cooled it is possible that the condenser fan motor is not running when necessary or the fan switch that turns the fan on by pressure may be defective.
Posted on Oct 23, 2008
SOURCE: b195 ice maker not making ice
the solenoid might have packed it in
Posted on Oct 27, 2008
  • 4 Answers
SOURCE: ZDI15 make too much ice
high level sensor is bad.
Posted on Mar 13, 2009
Karthik316
  • 187 Answers
SOURCE: GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Posted on Jul 25, 2009
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
How do I get the icemaker to make ice
TROUBLESHOOTING ICE MAKERS.
Nov 23, 2014 | Refrigerators
Ice maker has stoped making ice
Check to see if you have ice build up in the water tube behind the icemaker. Sounds like your inlet valve is bad behind the back panel on the bottom. Good luck!
Aug 20, 2010 | Maytag Refrigerators
ICE MAKER STOPED MAKING ICE
Water line could be blocked. Does water dispenser still work?
Water valve at bottom of refrigerator that sends water to the icemaker could have malfunctioned.
Icemaker control that calls for water could have malfunctioned.
Oct 18, 2009 | Frigidaire GLHS238ZDB 22.6 Ft Classic...
Ice maker stoped making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser
Thank You for using Fixya.com
Jul 30, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
GE Refrigerator Stoped making ice
the small pipe in side the freezer the one that supplies water to it, it builds ice in side, you can melt the ice by getting some hot water and a towel and wet the pipe with it intel ice melts , or you can unplug the frige with the door open over night.first solution is better.
Dec 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Changed filter, red light flashes, not making ice at all
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjkjl
Aug 08, 2008 | U-Line Refrigerator Ice Maker
Frigidaire Side by Side Icemaker
The icemaker evaporator system that releases the cubes is faulty , and must be replaced.
Apr 02, 2008 | Frigidaire FRS-26DR7D Side by Side...
Kenmore - Ice Maker Not making much ice
check water inlet valve on your frig
Nov 06, 2007 | Refrigerators
Kitchen Appliances - Others Logo
42 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
