Question about ASUS Tablets & eReaders
Screen lights up but want come on - ASUS Tablets & eReaders
    Sergeant:
  • 258 Answers
This is the most common problem with tablets - there are literally hundreds of people asking the same question and i have had the same problem myself - its usually corrupt bootloader or OS and can be a nightmare to repair.
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up. Its actually a disgrace and I have been repairing computers and latterly tablets for the last 30 years and it is by far the most common issue with any tablet except Apple - there is a reason they are so expensive - lol
Posted on May 13, 2014
My new Samsung SM-T310 tablet screen flickers so much I cannot use it. is there a fix?
find out if the actual display or just the back lights are flickering first .
turn on a good flashlight lay it on the face of the display when lights go out if the picture remains then it is the back lights not the display
but either way i believe you will end up replacing the display (backlights included( and probably LEDs) ) i will look at availability and feasability of this, come back with item model number and year
Jan 12, 2015 | Samsung Galaxy TabPRO SM-T320 16 GB Tablet...
My zeepads screen isn't lighting up. if you turn it just right in the light it can barely be seen. I have tried the back light and the brightness settings on the tablet and the reset..nothing has worked....
If you can see a faint picture on the screen then it is probably the screen inverter is faulty! If it is still under warranty then send it back!
Dec 25, 2014 | Tablets & eReaders
Toshiba AT200 is on but screen is black
Hi Andrea,
When you switch on your tablet, can you see some images on your screen - they are dark.
There are LED lights behind the screen that light it up, and these may not be lighting up.
If this is the case, you may have to take it back to the store where you bought it or a repair man.
Jan 30, 2014 | Tablets & eReaders
I can hear sound but screen won't light up
If you recently installed new content that could be the cause if there were an issue with the content. Otherwise your screen, connections, and/or component(s) inline are more then likely bad. Before condemning it have you tried resetting it in every way. Let the battery die then try charging and starting it at least.
Mar 31, 2013 | Tablets & eReaders
Screen went black
is there any light emitting from the device at all? (turn off light and see if the screen is showing light)
if it is, check your brightness settings on the device
if there is no light it is possible that the backlight burnt out, or that there are settings that need to be adjusted on the device. It is also possible that you downloaded an app that doesnt work properly with your device.
if none of this seems to be whats wrong, more information would be nice:
1) what model of tablet are you using?
2) what version of android OS?
3) what app were you trying to install?
From there you'll be able to get more help if needed.
Feb 28, 2013 | Polaroid Tablets & eReaders
My kindle wi-fi is not working. I went to turn it on and the light came on but stayed at the screen saver screen.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Nov 13, 2010 | Amazon Kindle Wireless Reading Device
M275 tablet laptop LCD back light stop working.
it is look like your laptop does not have the light runing on your screen , open the screen and chek the smal part under de scrren is in the midle of screen with 3or2 smal cable on 1 side and 3or2 that difer from brand to brand smal the other side  wich is conected to the light sourece, that is the problem change that part and will be ok.
Jan 16, 2009 | Gateway M275 Tablet PC
Monitor
If your LCD monitor has damage it could be in three forrmats:
1) Damage LCD ribbon. The screen will power up bright white and you will see random strings of color in diaganol or horizontal streaking slowly across your screen.
2) Damaged Liquid Crystal Container. The thin glass/plastic may have ruptured due to an impact on the screen. You will see sharp jagged lines and maybe a partial post screen, but where the sharp "jaggies" are, are now permantly broken
3) Nothing on screen. This indicates that your internal CCFL (oh I love LED technology) tubes have now lived their life and will not ignite. To test this method, hold a very bright light to the screen and see if you can see any logos (Compaq/HP/Win Xp loading screen...etc)
If you can see something, your screen is fine, but there is no light behind it for you to see.
Hope this helps.
Jun 05, 2008 | Compaq tc1000 Tablet PC
Tablets & eReaders Logo
49 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
