Question about Kyocera Mita Kyocera FS-1028 MFP Laser Print
How to reset a process unit
It gives an error message stating reset the process unit
  • 3 Answers
Make sure that the front and top covers close smoothly and fully. If the blue toner release arm is not fully to the rear the top cover will barely close. To reset the process unit you should remove it and then re-install it making sure it makes a good 'click' when you insert it.
Posted on May 16, 2014
Has error message that pc units are missing. Cannot get the message to clear or the printer to print
The PC or photo conductor must be bad or needs to be reseated.
I cannot state more given no make nor model was listed.
May 24, 2016 | Office Equipment & Supplies
Tablet shut down in the middle resetting. How do I finish the reset process?
Cry. Seriously, remove the drive and copy off of it any and all files that you want and need. Then format the unit and reinstall the operating system and programs from the backup disks that you have. No backup?
Now you are really ******* - see if you can get set from notebook manufacturer. If not check with your computer literate friends to see if any of them have OS installation disks.
Mar 26, 2016 | Computers & Internet
Unit has locked out in stanby. What is the process to reset. Locked out using remote.
I don't think you have a remote problem,but your unit need a hardware reset do it by professional. Basicly it reset your CPU and I bolive will start over
Mar 12, 2015 | Pyle PD3000A Amplifier
Error message on my Nikon D80
I have the same message r07 on the same camera & lens combination. It is an lens error message that the lense will not focus. You can manually focus the lens in the auto mode and the camera will allow you to take a picture. I have been told it is the MR unit and cost of repair around $135.
May 27, 2010 | Nikon D80 Digital Camera with 18-135mm...
My xbox is saying error e74
CAUSE This problem occurs when the Xbox 360 console experiences a general hardware failure.uparrow.gifBack to the top
MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request online by using the links in the "Additional support" section. To confirm your console is displaying the E74 error message, follow these steps: 1. Turn off the console. 2. Turn on the console. 3. Verify that your console displays the E74 error message.uparrow.gifBack to the top
Additional supportIf your console continues to display the E74 error message, it requires a repair. For more information about how to start the online repair process, please visit the appropriate Web site: United States Customers
http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
Outside the United States http://www.xbox.com/support/ Note Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 10, 2010 | Microsoft Xbox Console
Printer won't print labels
Try resetting the printer:
Note: it will erase all network settings.
Turn the printer off, press and hold the GO button, turn the printer back on, continue holding the GO button for at least 10 seconds, but for fewer than 20 seconds. After the Go, Attention, and Ready LEDs turn on, release the GO button. During this process, the Attention LED will turn on, the LEDs will begin to cycle, and the unit will perform a cold reset until the printer returns to the Ready state.
NOTE: If either the Go or Ready light turn off or no LEDs turn off before the GO button is released, repeat the process.
For PCL XL error: try to reinstall the printer drivers.
Oct 11, 2009 | HP LaserJet 2550L Printer
Phaser 8400 Error Code 07.009.42:265696
Hi carlt322:
Here is your problem.
7,009.4x: PM_FAULT_HEADTILT_PARK_ ERROR
The printhead is tilted back but not in the park arms and restrained properly. This is due
to the wiper assembly not moving up far enough for the park arms to hold it.
1. Check the printhead heater wiring.
2. Check for an obstruction or damage in the process
gearbox. Ensure the gears are correctly aligned and
homed, see page 6-8. If faulty replace the process
gearbox assembly.
3. Run the Head Maintenance Clutch test, if it fails replace
the clutch.
4. Run the Wiper Drive test. If the test fails, inspect the
maintenance drive system.
5. Replace the exit assembly.
Hope this helps
Sep 25, 2009 | Xerox Phaser 8400 Laser Printer
WHAT IS THE SOLUTION ON ERROR MESSAGE PE IN MY FUZZY LOGIC WFT601
There is a round clean out door accessed from the front of your unit. Some models you have to take the lower panel off entirely to clean it out. It unscrews and probably there is anything and everything you can imagine clogging the pump inlet....thus the error message "PUMP ERROR" THe unit's error code may manually have to be deactivated in the control panel to reset the unit to normal operation.
Nov 30, 2008 | LG WFT1071TP Top Load Washer
353 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
