Question about Proscan 32LA30Q Television
Proscan 32LB30Q TV suddenly lost sound - completely mute. Picture is fine.
The sound bar shows but nothing. This TV is connected to a comcast digital adapter, same thing happens with the comcast remote - sound shows up and down on the screen but nothing. Neither remote is muted.
SOURCE: Proscan 32LA25Q Audio output
Check the manuals and seen may be something.
Posted on Dec 31, 2008
SOURCE: Proscan Tv is humming
This made my humming sound go away completely;
From JD at oncorpus.com [manufacturer of the 32LB30Q]
Please follow these instructions, should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
Posted on Feb 06, 2009
  • 16 Answers
SOURCE: How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Posted on Apr 02, 2009
SOURCE: Looking for a working remote code for a ProScan
Someone else on the web used 627 and I just tried it. It works!
Posted on May 07, 2009
  • 814 Answers
SOURCE: Proscan 32LB30Q HDTV Just stopped working--1month old
This unit need to be taken to a service center to repair to be tested for component failure. The PROSCAN website for customer support is www.oncorpus.com. go to the customer support and find out where you can take your television for service. The PROSCAN customer support telephone number is. 1-888-977-6722. I hope this helps you with your problem.
Posted on May 21, 2009
Connect Sound Bar to TV (flatscreen - Proscan)
How about fiber optic cable or composite cables. I usually recommemd that people do either of these.
Jun 04, 2014 | Proscan Televison & Video
Lost sound on tv suddenly
Just check whether the mute button on remote is jammed. Then if that is ok, check whether you can listen to the sound on a Head Phone connected to the TV. Even if it works, the TV needs attention by a qualified service technician.
Jul 14, 2012 | Samsung PN50A550 50 in. Plasma TV
TV has sound..no picture Philips DPTV335 was working fine and suddenly picture went out. Still has sound but nothing on screen (volume bars, picture)
This is a projection TV. No picture can have a whole host of causes.
When the TV turns on, you can see background dimly but no picture.
Caused by the picture being muted. Perhaps the video signal is too fast - 1080i on a TV that does not support it might cause this.
Menu works but no image.
Definite picture muting. A bad video cable, no video from the device providing the picture. From the tuner, the signal circuit board needs repair.
No background, no image, no menu
This is a loss of high voltage to the picture tubes. If the picture cannot draw up and down or side to side, this will happen. Definite time for a repairman. Can be pricey if certain parts have blown out.
Most likely is a loss of vertical drive. (up and down drawing of the picture)
Mar 21, 2010 | Philips Magnavox MWR10D6 DVD Recorder
No sound when playing a dvd on a proscan lcd tv model 32LB30Q tv
Do you have a different audio source to test with (such as a tape player or vcr?) . That way you can verify if the DVD player is putting out audio versus whether the TV audio input is bad, or if the TV is configured to use HDMI for audio input.
Some TVs give you a setup menu option where the audio comes in through the HDMI port versus the (RCA) component ports. If yours is like that, then you should be able to switch that in the TV menu.
Oct 04, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Is there anyway to hook up external speakers to the tv? Like a surround sound system? computer seakers?
there is no audio out in my proscan 32LB30Q tv so there is no way for me to hook it up on my amplifier....
Sep 11, 2009 | Proscan 32LA30Q Television
Proscan 32lb30Q. I need to hook up wireless
You can buy a digital to analogue converter that connects to your COAX digital output and then connects to you RCA jacks. They run around $75. The only problem I've encountered is the DVD does not work through the COAX output, just TV. I'm looking into it.
Jul 01, 2009 | Proscan 32LB30QD 32 in. LCD TV
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Remote code for a tivo remote
Ok I found it!  For the Proscan 32LB30Q from Costco, the 5-digit code for the Comcast remote is 00030, and the 4-digit code is 0030.
However, I still haven't found the code I need for the TiVo remote... but we're making progress.
Jan 31, 2009 | Proscan 32LA30Q Television
Picture goes on and on constantly
I have the same problem. Picture cuts out completely then back on. When I first turn it on, it does this constantly for about 15-20 mins, then about once every 30 mins or so. The sound is fine, but the picture just flashes on and off.
The color is also starting to shift a lot and cannot be fixed by adjusting COLOR-BRIGHTNESS-PICTURE in the video control menu system. Nothing seems to correct this. I've even unplugged the TV over night to see if it needed some sort of reset. Model = KV-20FV12. Purchased in 2004
My connection is a direct cable connection - Comcast cable. Same problem persist while showing a DVD as well.
Dec 18, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Proscan 32LA30Q Television Logo
18 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
