Question about Apple iMac Computers & Internet
Black and White Horizontal Lines
Went away from computer for a couple of hours, upon return the screen was white. Turned it off and restarted. Screen was white with apple for a few minutes, then went to white screen and now has black and white horizontal lines with rectangular white/black boxes throughout pattern. Computer is unresponsive. What does this mean?
    Master:
  • 388 Answers
Sounds like the graphics card just died. You will need that repaired.
Posted on Apr 15, 2014
fire sine
  • 382 Answers
SOURCE: Screen Changes and Comupter freezes
It may be possible that the power supply, display and or logicbpard may be having issues. Apple recommends resetting the pram and nvram. If issue persists reset SMU. YOur machine is 6 months outside of the original warranty, but if you purchased the 3 year extension plan, you may want to take action on it.
http://search.info.apple.com/index.html?q=imac%20g5%20reset%20pram&lr=lang_en&search=Go&type=
http://search.info.apple.com/index.html?q=imac+g5+reset+smu&type=&search=Search&lr=lang_en&search=Go
Keep me posted.
Posted on Nov 11, 2007
  • 55 Answers
SOURCE: white vertical line going through my IMAC screen
The line is an indication that there is a failure in the display, most times the failure will be limited to the line you see but occasionally the problem will spread, causing more lines. the only way to fix it is to have the display replaced.
Posted on Dec 15, 2008
  • 55 Answers
SOURCE: inch wide vertical white band on my Imac screen?
If the white band appears right from start up, the display needs to be replaced, if it comes on after it starts, it is most likely a software problem.
Posted on Feb 22, 2009
KenKaBob
  • 89 Answers
SOURCE: Resolution issue Acer V223w
Hi, I'm sorry to hear you are having trouble....
THis is a tricky one. My first step would be to connect another screen to your G5 and connect your V223w to another Mac... Are you able to do this, do you have access to another system, could even be a PC ( in the worst case )
Ideally, having 2 screens connected to your G5 would be the best situation.
THis way, with one working screen, you can attempt to modify the resolution and refresh rates on the V223w from the good screen, be sure to activate screen mirroring, otherwise you will not have access to the other window of monitors system preferences.
If you can get two monitors connected and mirroring is not an option, then either your monitor is KAPUT or the video card secondary port is KAPUT, try switching the port of the card your displays are connected to. I think they are both DVI ports. If the opposite screen is now working, then you know it's the port on the video card.
Hope this will get you through it.
Posted on Mar 31, 2009
  • 1099 Answers
SOURCE: Grey screen with a blinking folder and question mark
Two possible things are wrong either your hard drive has gone or your system has corrupted. Put your instal disk in start it up holding down the c key. Once it has started check that the hard drive exists by go to the menu bar and selecting the disk utility. If the hard drive shows it means that it is okay run the disk utility check drive and then run the repair permissions. Then try restarting, if it works then you are back up and running again. If the drive shows up and you restart and the same thing shows up with the grey screen, you will need to reinstal your system. You do this by starting up with the instal disk holding down the c key and run the instal script. To keep your hard drive contents your will need to use the preserve users instal.
If your hard drive does not show up the hard drive is probably a gonner and you will have to purchase a new hard drive and instal a fresh system.
Hope this helps
Posted on Mar 23, 2010
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
3 horizontal lines on Samsung LN46A650 upon start up. Causes the Tivo menus and on screen graphics to refract. Goes away within a 1/2 hour but returns when powered down and restarted.
I had the power board capacitors on my Samsung 46LNA650 checked, and the out-of spec/leaking ones (13 in all) replaced. The horizontal lines disappeared; but, the left side of the panel was dark for about 20 minutes (until warmed-up). I then found this forum/link that solved the problem! This simple fix was probably all that was ever needed - IT WORKS!!!!!!
http://forums.cnet.com/7723-13973_102-391250.html
My Samsung now has a perfect picture again.
Nov 16, 2010 | Samsung LN46A650 46 in. LCD HDTV
Blank white screen on my blackberry 8520 curve from switch on
Sounds like your screen is physically broken. If your Somebody needs to open your Blackberry and replace it. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
Jun 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
The tv was on for 2 hours and then just went to a black screen. Unpluged for 10 min and tried again, the picture came back for 5 to10 seconds black and white vertical lines and then to a black screen. The...
The tv have problems with it Tuner incomming Signal board,it have dead componnents on it board.Call for warrenty repair,it the Tuner board it dead.Or return where u purchase it,get a new tv for the replacement.
May 24, 2010 | Vizio VO47L 47 in. LCD TV
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Computers & Internet Logo
104 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
