Question about Kyocera Office Equipment & Supplies
Process unit reset
It brings the message"reset the processor unit"
HOW TO RESET HARMAN KARDON AVR70
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
main
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
harman
kardon service center for assistance.
to locate an authorized service center,
visit our web site at www.harmankardon.com.
https://www.harmanaudio.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw409ee4c9/pdfs/AVR700NEW_OM_EN.pdf
Jul 28, 2016 | Harmon Kardon Harman / Kardon Avr 70...
How to reset a process unit
Make sure that the front and top covers close smoothly and fully. If the blue toner release arm is not fully to the rear the top cover will barely close. To reset the process unit you should remove it and then re-install it making sure it makes a good 'click' when you insert it.
Apr 15, 2014 | Kyocera Mita Kyocera FS-1028 MFP Laser...
I have a Compaq presario sr192onx with an Asus A8N-LA motherboard and an AMD Athlon 64 +3500 processor. I took apart the fan and heat sink so I could read my serial number on my processor, and now after...
Try making sure all of the plugs are connected properly (some may have moved during) hopefully you haven't unseated the processor but just repeat process sometimes that fixes the problem. But to me sounds like a connection issue between either graphics card(if you have one) CPU, Power Supply Unit and motherboard
May 04, 2017 | Computers & Internet
My last load had three minutes left of spinning and I stopped washer to take clothes out. When I added another load a message came on scsreen that said "Notice! A problem has been detected with this...
Since the program was interuppted while it was running it was possible that the processor in the main controller unit has an error and so the output had hung up.
Hence you can remove the plug and allow the processor to reset, press down the panel play /stop button and after about an hour plug back to check .
The processor should normally reset and work normally unless there is a fault in the controller unit.
Aug 31, 2011 | GE WPGT9350C Top Load Washer
My HTC Hero brought up a notification that said it was running low on storage space. When I tried to get out of the notification page, the phone said it had to force a close. It kept bringing up the...
Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state. Press HOME > MENU, then tap Settings > Security > Factory data reset. On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons, with the phone turned off, press and hold the HOME, END CALL/POWER, and BACK buttons. The reset process will start after a few seconds
Feb 26, 2011 | HTC Hero Smartphone
Mailbox full message even after deleting all messages.
you will have to do a factory reset or bring it back to default settings, something is not set right in the software or the phone software is playing up, do a complete reset to factory default settings, follow your manual on how to do this
Jun 25, 2009 | Panasonic KX-TG5632 Phone
Shutting down
Look...maybe the processor cooler is dusted.If the processor get to varm hes shut down.
Nov 22, 2008 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Backup Problem
unplug battery and cord and push power switch for 60 sec. this resets the unit
Dec 30, 2007 | Acer Aspire 3610 Notebook
Consumable replacement message
You need to go into service mode to reset these parts. Start by hitting the "Utility" button on the control panel. Then select "Meter Count" from the menu. Next hit "Details". Then you need to hit the following buttons in this order, STOP,0,0,STOP,0,1. This will bring you into the service mode on this machine. From there you should select "Counter". From the Counter menu select "Special parts counter". Highlight the parts you replaced and hit the "C" on the control panel to clear the counter. This process should be done for any parts that you replace and will prevent the message from popping up.
May 11, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
20 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
