Question about Dynex Televison & Video
Colour dvd plays in black and white
Was playing in colour and changed to black and white
  • 17 Answers
SOURCE: TV SETTING
how do you have the dvd player hooked up to the tv
Posted on Dec 10, 2007
  • 108 Answers
SOURCE: DVD'S Play only in black and white
In UK this occures when an NTSC picture is played from a DVD player to a TV which cannot enitrely hand NTSC format. Possible this will happen in the reverse for USA.
Also my TV cannot handle SVHS signals and also displays them in black and white.
Try changing settings on the DVD Player to Composite or RGB.
Regards
Posted on Mar 10, 2008
SOURCE: Plasma Tv 42PD580DTA, Black and white screen while viewing DVDs or Video
My sister-in-law has exactly the same problem and is a common one with this unit.
I've spoken to a technician who says that:
1. Hitachi are withdrawing from Australia and there are VERY limited service centres left
2. The problem is a chip on the main board and depending when the TV was made will determine whether the chip is a plu-in or soldered on to the main board - if it's the latter, you'll be up for a main board at around $400
3. He couldn't get the price of the plug-in chip because he couldn't get through to Hitachi.
Cheers
Dave M.
Posted on Apr 28, 2008
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Posted on Nov 29, 2008
  • 133 Answers
SOURCE: dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Posted on Jan 11, 2009
Have a panasonic dvd recorder model number Dmr-Ex77. which worked fine now it records and only lets us watch in black and white.
programs recorded from tuner are now in black and white
Frank, try new cables and inputs if you can, cables or inputs could be faulty.
Apr 01, 2016 | Panasonic Televison & Video
Dvd plays black and white tv is colour
be sure to check all your input/output connections & cables
Nov 26, 2013 | Digihome LCD TV
DVD Playback is only Black & White
Different areas use different colour systems. The most common types being PAL and NTSC. What I think you might have done is changed the colour type setting to one that is not compatible with your TV. If you have the manual look up the colour settings. If you haven't got the manual look around the main menu for them. If all else fails use the factory reset.
Mar 12, 2017 | Toshiba Bdx1200 Blu-ray Disc Player
My lg video is only playing black and white films, the tv is still playing colour. It used to play colour videos at one time
try changing the colour options in the menu.
they are PAL,SECAM and others.try all of them till you find the one that matches your videos
Feb 14, 2011 | LG V271 DVD Player/VCR
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Plays dvds in black and white
need to change recording format!
May 18, 2009 | Televison & Video
Black and white
hey friend
It's Format Problam.. yr Country Standard Format is May Be PAL so when u play NTSC cd/dvd output is black and whight you have to change setting video format to AUTO and also chek yr pricute colour sillaction is set as AUTO..
Thaks for usig Fixya
Jo_Chimay.....:)
Mar 31, 2008 | Yamaha DVR-S150 DVD Player
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
