Question about AEG Ovens
Electric oven Cuts off when it reaches temp
Hello, I have an AEG competence C31090 GM Model M9168C5X0D gas and electric stove. I recently replaced the bottom element because it had split. Soon after the repair I now have a new problem. If I want to bake and set the temp at lets say 200 C when it reaches the correct temp it just switches off. I also find that when turning the dial for temp I hear an electric short and have to push it in to make the sound stop. please advise if this is a part I can buy and replace myself or if I will require a service provider. Bearing in mind that the product is out of warranty.
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Need replacement Dial knobs on Oven
Look in yellew pages for a Zanussi dealer, you will need mod number,,serial number, and er number, all of which are on the rating plate found at the front of the oven.
Posted on Nov 17, 2008
  • 44 Answers
SOURCE: Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Posted on Mar 19, 2009
bestdarngood
  • 3037 Answers
SOURCE: GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
Benjamin
Posted on Nov 04, 2010
I have an AEG Competence Single oven model B2100-1-w The oven is not reaching or holding temperature I have noticed the fan is not spinning
Hi steve sounds like your fan motor is faulty they are not very powerful any resistance in the bearings can stop it starting. oiling the bearings wont help you need to replace the motor also it will have damaged the element no air circulating it will of overheated. an overheated element usually lasts till xmas morning.
Nov 09, 2010 | AEG U3100-4 Electric Double Oven
Turn oven on to bake when it reaches temp oven cuts off and f2 sh
This indicates the oven has reached an over temperature. You will first need to check the temperature probe for the proper reading. Refer to the tech sheet located somewhere on your stove. It should be around 1100 ohms. If this checks out good the ERC electronic range control will need to be replaced. Here is a couple links that should help
http://appliancehelponline.com/oventempprobe.html
http://appliancehelponline.com/ovenerc.html
Jul 27, 2010 | GE Profile JTP18 Electric Single Oven
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2008 | AEG D5701-4 Electric Double Oven
Nov 17, 2008 | AEG B1180-4 Electric Single Oven
Oven
I don't think there's somthing to do about it, try and conntact AEG support team perheps they can send you marking labels
Best of Luck
Bono1
Dec 06, 2007 | Ovens
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
Top AEG Ovens Experts
Sal De
Steve
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
