Question about Canon Office Equipment & Supplies
Canon ir 2570ci error code - Canon Office Equipment & Supplies
5 Suggested Answers
redzventures
  • 149 Answers
SOURCE: IR-2570CI
This error indicates that the patch image read sensor is dirty. You can locate the patch sensor by removing the drum unit from the front of the machine. The patch sensor is located in the machine, directly above the drum unit, halfway intothe machine. If you look into the machine and up you will see a white plastic unit running along the top about halfway point between the front and back of the machine. The patch sensor is inset into that unit and is black plastic. Clean with a lint free cloth several times - as it is hard to see the actual sensor, feel along the strip with your fingers until you can feel the indent where the sensor is - concentrate your cleaning around that area. Now replace the drum and turn the machine back on (I hope you turned it off first).
Removing the drum is easy but hard to explain. In fact, if you get the front cover off, you've done the hardest part. There are some hidden screws, one above the front cover to the left - as if you are looking down on the machine, there may be a small circular plastic cover hidding access to this screw. Remove it and unscrew. If you have an internal finisher, you will have to remove the circular covers above and below the front of it to push your driver through to the hole you need. Sounds complicated but once you've done it you'll see that it's easy when you know where the holes are. There is then another screw at the top, near to right that you access through the panel above - just look around and above the front cover to find the screws. Good luck
Posted on Aug 30, 2009
canontech
  • 1219 Answers
SOURCE: Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
Posted on Jun 16, 2010
  • 74 Answers
SOURCE: cannon ir 2570ci
E007 means that the fixing unit has an error. This unit gets very hot and is shut down if an error is detected to stop it over heating. You will need a qualified engineer to look at it.
Posted on Mar 29, 2010
  • 39 Answers
SOURCE: canon ir c3220 error code E602-0003
This is just a shot in the dark, but if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings. You will loose any settings and any work in progress. Just a guess. If you have an owner's manual, I would check there to find how to solve the problem. You also might want to enter the "menu" if there is one, and discover whether you can solve the problem there. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section. Good luck.
Posted on Nov 11, 2013
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - โ€Ž5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
Nov 22, 2014 - 3 posts - โ€Ž2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion ยท Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
Mar 15, 2007 - 4 posts - โ€Ž4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
Nov 05, 2015 | Office Equipment & Supplies
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
Cannon ir 2570ci
Mar 27, 2010 | Office Equipment & Supplies
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
IR-2570CI
Aug 19, 2009 | Canon IMAGERUNNER 2230 Copier
15 people viewed this question
old marine
old marine
