Can u use silver wire as an extension cord - Heating & Cooling
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
No its too dangerous, always use proper insulated wire
Posted on Apr 15, 2014
How do I replace a power cord on hoover u6311?
Heat shrink wrap not electrical tape since it can peel away
New cord longer is better in my opinion
Wire cutters
Or Wire extension or splice adapter
If the wire is brown copper use a new copper wire if it is silver aluminum use a new aluminum wire.
Jun 28, 2014 | Bissell 6594 PowerForce Bagless Upright...
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
Need an extension power cord for the TG5632
You can get up to a 25ft silver satin line cord for phone, or even an extensine cord. Or contact the manufactor about a longer cord.
Feb 05, 2014 | Panasonic KX-TG5632 Phone
Wall light switch timer inline with Extension cord GE 15313
Black to black (hot), Green to green (ground) and the only one left is of course white to blue. The (neutral) white wire can be many different flavors (blue, red, orange, brown, etc.).
If the outlet your plugging into (or controlled by the service panel breaker) is 15 Amps use a minimum of 14 gage wire (or 12 gage is even better), if its a 20 Amp outlet use 12 gage wires (or 10 gage). Don't use a 16 or 18 gage wire because it may get hot and start a fire because its undersize for the Amps.
Nov 13, 2012 | Hardware & Accessories
How do I put a light switch on a extetion cord
You want a light switch on extension cord.
What kind of light switch do you have? You posted under GFCI device which is totally different than ordinary wall switch.
And what type of extension cord?
Add a comment with more information.
If ordinary light switch is installed on 3-wire outdoor extension cord:
Slice open the side of cord and you see 3 wires: black, white and green.
Cut the black wire in half and connect each end to brass screw on light switch.
If ordinary light switch is install on indoor 2-wire extension cord.
Look at plug and notice there is a wide blade and narrow blade.
Narrow blade is hot. You want the wire connected to narrow blade.
Cut that wire in half, but do not cut other wire.
Connect each end of wire to brass screw on light switch
If you want to install line switch onto indoor 2-wire extension cord:
Narrow blade is connected to hot wire.
Open line switch.
Connect each end of black wire to brass screw. OR if no screws, then place cut wire in open grooves.
Tuck other wire into groove and then reassemble switch.
Jul 05, 2011 | Leviton 8299 Combination Switch / Smart...
Have switch 691-WCC6. Replacing an old outlet with no ground wire - have 2 black and 2 white wires coming out of box. Looks like two brass connections on one side and silver one on the other side with a...
Question is posted under switch, but asks about outlet.
Outlet is where you plug extension cord for example.
Usually screws are color-coded.
Outlets have brass and silver screws.
Without testing wires, trying hooking wires to same color screw they came from.
If breaker blows, then take off one wire and try again, or test wires to see what each is connected to.
As general rule with newer wiring inside outlet box, code says Black wires are Hot and go to brass screws, White wires are neutral and go to silver screws.
Older wiring could be very different especially if wiring was not done by code.
Use cheap circuit analyzer from home center to help diagnose outlet problems.
Add a comment with photo of your old wiring device, plus wiring.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Apr 10, 2011 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
WHAT SIZE EXTENSION CORD FOR GA7021 SHOULD I USE AND MAX LENGHT? BURNING UP GRINDERS
Well for 15A the minimum wire size in your cord should 14 gauge, Length can't really be specified but you want to go for less resistance in the cord, thicker wire and less length will give you less resistance (more so thickness). If your grinder works fine without the extension cord, I would recommend getting a heavy duty extension cord with 12 gauge wire and trying that.
May 25, 2010 | Makita Angle Grinder 7" 6600 Rpm, 15 Amp
Four prong cord three prong outlet
Ok this is how you will wire the three prong to the dryer.
You have 2 wires that are gold/brass in color, those are the hot wires.
You have 1 wire that is crome/silver in color, that is the neutral
On back of fryer where you wire it you put the wires on like this right to left Gold/brass hot, silver/nuetral, then the other hot wire.
On back of dryer you will have screws from right to left this color gold/brass, silver/crome, then gold/brass again.
If you do have a 4 wire cord the extra wire is ground and you screw that to the machine body.
Mar 14, 2010 | Roper RGS7646KQ Gas Dryer
1 HP. motor wiring, need help!
Simple to do. Go to the local hardware or home improvement store and get a 6 to 8 foot heavy-duty extension cord. Cut the outlet end (not the Plug end) off, you won't use it. Strip back the outer casing of the cord to expose the three wires, black, white and green.
The Green wire is connected to frame of the motor or saw to ground it for safety reasons.
The White wire is connected to the silver color screw connection.
The Black wire is connected to one terminal of the switch, another wire is connected from the second switch terminal to the brass color screw on the motor.
Plug in the extension cord, and flip "ON" the switch and cut some wood and think of your Grandpa....good guy!
Sep 17, 2009 | Craftsman 10" Table Saw
Looking for manual for ''nec n-3480'' TV, missing power cord
Colour code Standard wire colours for flexible cable
Such as Extension cords, power (line) cords and lamp cords World Region, country
or other entity(ies) Live Neutral Protective earth/ground EU, Australia & South Africa (IEC 60446) brown blue green & yellow Australia & New Zealand (AS/NZS 3000:2000 3.8.1) red black green/yellow United States and Canada black (brass) white (silver) green (green) Standard wire colours for fixed cable
(In or behind the wall wiring cables) Region Live Neutral Protective earth/ground EU (IEC 60446) including UK from 31 March 2004 brown blue green & yellow Australia and South Africa red black green & yellow (core is usually bare and should be sleeved at terminations) United States and Canada black, red, blue(brass) white (silver) green (green)
or bare copper wire Note: the colours in this table represent the most common and preferred standard colours for single phase wiring however others may be in use, especially in older installations.
Nov 19, 2008 | Televison & Video
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
