How many feet can an extension cord safely carry power to run a battery charger
    New Friend:
There's a simple formula that can help you calculate electricity requirements: just multiply the number of amps by the number of volts... the resulting number equals that appliance's wattage.
Posted on Apr 15, 2014
3 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: power cord?
Yes it is safe to use. :)
Posted on Sep 12, 2008
  • 998 Answers
SOURCE: dell c640 notebook runs on charger but will not
You probably have a defective battery connection or circuit on the motherboard. It will have to be replaced or repaired.
Posted on Sep 24, 2011
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Aug 09, 2017 | Cub Cadet Garden
HOW TO HOOK UP A CTEK BATTERY CHARGER TO A 2007 MASERATI QUATTROPORTE SPORT GT
Wise decision my friend. Because with all the electronic stuff that's still running without the switch on, it can destroy a good battery after a while of non-use. A very, very slow drain. Just connect the hot wire directly to a lead directly to the battery and the ground to a bolt on the frame. Place the male end of the 110 cord where you can easily access it to plug it into the extension cord and wire tie it there. Mount the charger in an area where it can get air, under the hood on a fender well but out of the way. Because these new style chargers are "floating" chargers, it will shut down when battery is fully charged and restart with a 1% drop. Always remember to disconnect the extension cord from charger before starting the car. Otherwise you'll be replacing the charger. It's safe to hard wire the unit like this, no power goes back to the charger with the one way diode that's incorporated in the unit. Have fun with your toy.
Jul 29, 2014 | Vehicle Parts & Accessories
Charger tips to small for dell laptop
A Dell Mini net book is a small and very portable laptop. The compact size makes it a good candidate for travel or just simply using around the house. Outdoor aficionados can get the most computing life out of a Dell Mini by finding a way to charge the battery outside. One method works when you are near a building while the other can be used for more remote outdoor locales
Things You'll Need
  • Extension cord
  • Solar laptop charger
  • Dell Mini power adapter
    • 1 Plug an extension cord into an available power outlet. Run the extension cord to where you are outside. Many homes also have exterior outlets. Use an extension cord that is designed for outside use. Plug the Dell Mini power adapter into the extension cord to charge the battery.
    • 2 Purchase a laptop solar charger. Solar chargers are available from several different manufacturers and may come in the form of a roll or be built into a case that closes up for travel. Depending on the charger, you may also need to purchase a Dell Mini power adapter. Some chargers work with a Dell Mini cigarette lighter adapter that is designed to plug into a vehicle's power port.
    • 3 Place the solar laptop charger in a sunny location. Open up the case if the charger is in one and roll it out flat or unfold it to expose all of the solar cells.
    • 4 Connect the Dell Mini power adapter to the power port on the solar charger. Connect the other end to the netbook. The adapter will regulate the charge coming from the solar panel and recharge the battery in the Dell Mini.
  1. Tips & Warnings
  2. Solar chargers offer less power than a wall outlet. They can be used to extend the battery life of a Dell Mini or to recharge the battery when the netbook is off.
  3. Some solar laptop chargers are relatively heavy. Take the weight into consideration if you are going to be backpacking or otherwise carrying it on your person.
Oct 23, 2011 | Computers & Internet
I have a very deep yard. Approx. 150 feet from my nearest power outlet. Can I use your weed trimmer products? What is the recommended wire gage of the power cord I should use.
A 16 Ga extension cord will run 10 amps up to oo feet. Electric weed wackers run between 2 and 4 amps, so you should be fine with a 16 Ga cord.
Apr 29, 2011 | Garden
My compressor quit working when i flip the on switch it does nothing any ideas what is wrong???
If the tank is full (pressurized): Nothing will happen when the switch is turned on. Bleed some air from the tank to see if the motor turns on when the pressure drops.
If the tank is empty or low on pressure: First check the circuit breaker to the outlet the compressor is plugged into. Next, somewhere on the compressor, usually on the motor, there is a circuit breaker. They are usually a small round white or black button that if tripped will stick out about 1/4 inch or more. Push that back in and check to see if your motor runs. The usual reason for these circuit breakers to pop is because the compressor is being run on an extension cord. Rule of thumb for compressors: run longer air lines, NEVER use extension cords. If it is absolutely necessary to run an extension cord it should be 10-guage and no longer than 25 feet.
Jan 31, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
My scooter battery won't charge. Felt mild shock or short when attempted to insert connector. That seemed to disable the charger because the charger powers on, but will not run the charge to the...
Make sure that the charger is fully connected to the scooter; ususally the controller lights will go slowly left to right to indicate it is charging. Make sure the charger is plugged directly into the grounded wall outlet, not into an extension cord or power bar. If the charger is not being recognized by the scooter, you may need to replace the charger, or at least the power cord to the charger.
If your scooter has been sitting unused for a while? If so, the batteries might not charge anymore and will need to be replaced. Contact the manufacturer for a service call or troubleshooting over the phone.
Nov 04, 2010 | Pride Mobility Products Go-Go Elite...
Sterling sapphire 2 4wheel scooter
Larry,
Many scooters use a special charger that will not overcharge the batteries. Your best bet is to run a long extension cord to wherever you are safely storing you scooter and use the on-board charger. Be sure to charge your batteries often, since they last a lot longer if you do not run them down too far.
Oct 27, 2008 | Health & Beauty
Thanks again...
Sometimes, the battery alarm is set to high or off and it will automatically warn you when the battery is at a certain percentage. Most newer laptops will even warn you when the battery is going bad.
The AC cord is both the power cord and it will also charge the battery when plugged in as well.
So, it's safe to run on just battery as it may just be telling you that it doesn't have AC power and that you're running only on the battery. My Satellite laptop is setup to warn you when it's only on battery power as well.
Sep 16, 2008 | Dell Inspiron 1501 Notebook
Washer won't turn on
try running an extension cord to another outlet (another circuit breaker). ensure the cord is not too long (25 feet ok) and able to carry 15 to 20 amps (use 12 AWG cord).
Sep 03, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
