Question about Lands Phones
ATC MAGAZINE PIN LOCKED INPUT NOT DETECTED
MAGAZINE NOT INDEX AN OPERATE IN SOFT-KEY IN ATC DIAGNOSTICS
I have copier xerox 5021 error is 092-910 what does it mean
That error is an ATC failure. It can be caused by a bad drum or MCU Board. You can first try clear the value of NVM [752-059] (ATC Fail) or NVM [752-060] (ATC Fail Continuous Count) to '0'. Enter Diagnostics, Press and hold the [0] key on the Control Panel for 4 seconds or longer and then press
the [Start] button while keeping your finger on the [0] key.
Password is 6789. And go to NVM Initialize.
Sep 06, 2015 | Xerox Office Equipment & Supplies
Where can i find a Honda repair manual for 185 ATC.
Contact Honda Guru eric the car guy who should be able to help with that. Just register on the forum and pose the question. They are good people there. Here is a link...
http://www.ericthecarguy.com/kunena/index
Feb 28, 2015 | Honda Cars & Trucks
How do I get my messages from the answering machine ? What do I need to key in ?
If you are using the handset, press Menu and scroll down to the line Answer Machine with the up/down arrows. Then press the left soft key twice (Select answering machine and then play new messages). The left soft key is above the Talk button. Press End to stop the play back of messages. When there are no new messages, the above will play all messages.
If you want to access the messages from another phone, you first need to change the Master PIN from the one it shipped with and set up remote access. You do this from the handset.
To change the Master PIN, press Menu, scroll to Advanced Set and press the left soft key. Then scroll to change PIN and press the left soft key. Enter the original PIN (or the current PIN) and press the left soft key. Then enter the new PIN followed by pressing the left soft key twice. You will hear a tone and see New PIN Stored on the screen. If you do not enter the correct PIN above, the screen will return to the previous menu. The PIN from the manufacturer is 0000.
For remote access, press Menu, go to Answer Machine and press the left soft key. Then scroll to Ans. Settings and press the left soft key. Scroll to Remote access and press the left soft key. Use the up and down arrows to select Activated then press the left soft key again.
Once these are set, call your phone number and when the machine picks up press #. Within 8 seconds, enter the PIN. An error tone will play if you do not enter the correct code; try again. The unit will hang up if the PIN isn't entered in 8 seconds. All new messages will play. Press 1 to replay a message (or go to the previous message), 2 to play all messages, 3 to advance to the next message, 4 to delete a message.
The manual is available here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=ID9371B/37&scy=us&slg=en .
I hope this helps.
Jan 19, 2011 | Philips ID9371B DECT telephone
My dishwasher seems to be locked up and needs to be reset. the clean led is constantly flashing. i had this trouble in the past, and the serviceman reset the dishwasher by using the touchpad on the front...
Control is programmed to
stop the current cycle and
not allow any further
cycles if it suspects a
faulty heater (no
temperature increase
detected in heated
intervals). Control blinks
the Clean LED 7 times in
repetitive fashion and
disables the Start/Resume
key until cleared.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater
circuit.
■ Faulty heater drive
circuit on control.
Running Diagnostics clears the control and
allows it to operate again. If heating problem
is not corrected though, the control will stop
running again on next cycle. See below.
1. Unplug dishwasher or disconnect power.
2. Check all components and connections in
the water heating circuit or heat dry circuit.
■ Check resistance of heater.
■ Check resistances of all connections and
components between the control and
heater.
■ Check operation of heater and temperature
sensor in Diagnostics cycle.
Aug 26, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
It wants pin code and puk
To change the PIN number on the phone,
  1. Press Menu (left soft key)
  2. Highlight Settings and press OK (left soft key)
  3. Highlight Security and press OK (left soft key)
  4. Highlight Change codes and press OK (left soft key)
  5. Highlight PIN code and press OK (left soft key)
  6. Enter your old PIN code then press OK (left soft key)
  7. Enter your new PIN code then press OK (left soft key)
  8. Repeat your new PIN code then press OK (left soft key).
Aug 07, 2010 | LG GB102 TMOBILE PAY AS YOU GO MOBILE...
I need the unlock code for an lg vx8100. I dont have the last 4 numbers of the phone. i pressed the number key by mistake
Hi friend,
Could you tell me the locked you said is the sim locked or the phone locked?
If the sim locked,you can input the PIN code to unlock your cell phone,but if you have input the incorrect PIN code for three times,the sim card will be locked up,by then, you need to input the PUK code to unlock the sim card, both codes might have been provided along with the sim card to you,if.....
You can visit our website: www.1010store.com to get more information. We are professional seller for Drop shipping unlocked China cell phone.
Have a good day!
Sep 12, 2009 | LG VX8100 Cellular Phone
My cell is lock
Hi friend,
If the sim locked,you can input the PIN code to unlock your cell phone,but if you have input the incorrect PIN code for three times,the sim card will be locked up,by then, you need to input the PUK code to unlock the sim card, both codes might have been provided along with the sim card to you,if not,please contact your network operator.The PIN code...You can get more information in the website: www.1010store.com
Good luck !!!
Sep 02, 2009 | Nokia 3110 Cellular Phone
1988 new yorker atc trouble codes
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles 14 MAP sensor voltage too low 15 No vehicle speed sensor signal
Dec 20, 2008 | 1988 Chrysler New Yorker
Print is clear and fuzzy
I'm sure you have fixed this by now... But solution is...
Check the hammer phasing. Adjust hammer phasing if
necessary.
6. On the control panel, press the = + > keys to unlock the ENTER key.
“ENTER SWITCH UNLOCKED” briefly displays. (If “LOCKED” displays,
simply press = and > again. This is the default key combination. The lock/
unlock key combination can be programmed by the user. If = + > does
not unlock ENTER, get the combination from the user.)
7. Press the ; key. “OFFLINE / DIAGNOSTICS” displays.
8. Press >. “DIAGNOSTICS / Printer Tests” displays.
9. Press >. “Printer Tests / Shift Recycle” displays.
10. Press ; until “Printer Tests / Phase Printer” displays.
11. Press ENTER. The display shows “Printer Tests / Phase Printer” and the
test begins. The current phasing value is printed on the left of the printed
pattern of all H’s. As the pattern prints, compare the H’s to the figure
below. If the phasing needs adjustment, go to step 12. If the phasing is
OK, go to step 15.
12. Press >: The current phase index displays. Press > again: An asterisk (*)
appears next to the phase value.
13. Press < to increase or ; to decrease the phasing index value, then press
ENTER to activate the value as it prints. Continue to increase or decrease
the phasing index until the pattern of H’s is acceptable.
14. Press = twice: “Printer Tests / Phase Printer” displays.
15. Press ENTER to stop the test.
16. Press CLEAR. “OFFLINE / CONFIG. CONTROL” displays.
17. Press = + > (or the key combination set by the user). “ENTER SWITCH
LineMatrix
Sinca Printers, Parts, & Repair
www.sinca.biz
Jun 11, 2008 | Printronix Line Matrix P5215 Printer
Code locking of siemens mobile phone
Siemens Mobile Secret Codes:
C25:
SP unlock *#0003*(secret code 8 digits)#
*#0606# shows you Secret Code, but only without SIM Card.
*#06# for checking the IMEI (International Mobile Equipment Identity)
How to change PIN:
**04*old PIN*new PIN*new PIN#
How to check simlock status
*#0606# and then press left soft-key, you will see strange characters, then text ("brak blokad"). If you see for example 260-02, it means the phone is locked to Era GSM. In older models you can use *#06# and see the same information after clicking on left key (you will see IMEI and software version).
S4:
Monitor Mode - how to activate:
Press left soft-key, then 9 (SET UP) 8 (Phone Status). You will see IMEI number, then press left soft-key and in order 7684666 and red phone at the end (monitor mode has been activated). To read information from Monitor Mode - press left soft-key, then 5 (GSM SERVICE) and 6 (Monitor). Monitor mode turns off when you switch off the phone. You must activate it again if you want.
How to see date of software:
Press left soft-key, then 9 (SET UP) 8 (Phone status). You will see IMEI number, then press twice left soft-key, 98, left soft-key, 7684666, red phone (activates Monitor Mode), left soft-key, 56 (turns on Monitor Mode), left soft-key, 98, left soft-key, 7684666, hang up (red phone) &gt;abck to "normal" and then left soft-key, 56.
S6, S8:
If you add to phonebook under 'own phone number' +12022243121 with namez (for example MMI), then you will see something smile.gif
S10, E10:
In phonebook enter +12022243121 as your own phone no. You will see a picture with sun, two palms and greetings.
S15e:
Monitor Mode:
Code: *#7436267*8378# (*#SIEMENS*TEST#)
Hold red phone button until it code disapears.
Menu 3.3.4 Choose frequency.
Menu 3.3.4.1 Automaticaly.
Menu 3.3.4.2 Choose GSM-900
Menu 3.3.4.3 Choose GSM-1800
Menu 10.1 MS info
Menu 10.2 Soft date
Menu 10.2.1 Software version.
Menu 10.2.2 EEProm version.
Menu 10.3 Tst and product info.
Menu 10.3.1 Handware data.
Menu 10.3.2 Date of manufacture
Menu 10.3.3 Service date
Menu 10.3.4 Date of repair.
S25:
Enhanced Full Rate
*#3370# turns on
#3370# turns off
Haft Rate Mode
*#4720# turns on
#4720# turns off.
Languages:
*#0000#+green phone - choose automaticaly
*#0001#+green phone - English
*#0030#+green phone - Greek
*#0031#+green phone - Netherlands
*#0032#+green phone - French
*#0034#+green phone - Spanish
*#0039#+green phone - Italian
*#0049#+green phone - German
*#0090#+green phone - Turkish
How to change PIN2?
**04*old PIN2*new PIN2*new PIN2#
What is my software version?
Menu 8-8-2 press left-softkey when you see IMEI number, or *#06# and then green phone button and then press left soft-key.
How to extend battery life:
IrDA - turn on only when you need.
Turn off automatic network search (6-3)Turn off Vibration alarm.
Resets language to automatic selection : * # 0000 # then Green button
S25, M35, S35, C35
Nov 29, 2007 | Nokia 1100
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
