Question about Zebra Z4Mplus Label Printer
Zebra label printer buffering - Zebra Z4Mplus Label Printer
SOURCE: label printer
Try reseting the auto gap detection.
http://www.fixya.com/support/p257130-zebra_lp_2844_thermal_printer/manual-19245/page-15
Posted on Mar 30, 2008
  • 45 Answers
SOURCE: Zebra TLP2844 does not print the barcode label
Turn off the printer, then hold down the feed button while you turn it on again. After the configuration label prints, turn the printer off and on again,then try to print your labels.
If the barcodes still don't print, make sure they don't extand past the top, bottom or side of the label. If you software allows you to "clear the label cache" or "re-image the enitre label", try that.
Posted on Sep 23, 2008
  • 5 Answers
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
SOURCE: How to calibrate the label in QL320 plus zebra
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Posted on Apr 05, 2011
Testimonial: "Thanks"
Zebrazt230 doesnt print contiuesly
probably waiting for the buffer to re-fresh. maybe try re-install software
Mar 27, 2014 | Zebra ZT230 Direct Thermal Printer -...
Zebra lp2844 just keeps feeding labels
Power off your printer and disconnect it from the PC.
Allowe about 2 minutes for it to clear its buffer and then power it back on without connecting it to the PC.
If the problem still exists,
It may be a faulty paper sensor on the printer
Feb 10, 2011 | Zebra LP 2844 Thermal Printer
How do you clear the printer buffer on a zebra 140Xi111 plus
1. click on "start" select "run" and type "services.msc"
2. after open services windows select "print spooler" services
3. stop "print spooler" services
4. click on "start" select "run" and type "C:\WINDOWS\system32\spool\printers"
5. after open the printers folder deleted all the pending print jobs
6. restart the "print spooler" services and try to print now.
Aug 06, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Apr 21, 2009 | Zebra Z4Mplus Label Printer
Label Printing stuck in queues
I think your problem comes from your spool server. Check if you can select not to reprint on errors. As far as the error issue is concerned, i need to konw the reason of the errors to help
Jul 21, 2008 | Zebra Z4M Printer
Error in Print Jobs in the Queue
The use of a Print Buffer will help, the problem happens when there is a buffer overflow. Reboot the printer and let the print queue to resume will fix it every time, a print buffer will help with the overflow, try get one with a fair bit of RAM
Jul 15, 2008 | Zebra Z4M Printer
ZEBRA Z4M PRINT QUE ERROR
Try a reset: press the PAUSE and FEED keys while turning the printer, release the keys when feed the label. You can also try downloading the latest firmware.
Jul 02, 2008 | Zebra Z4M Printer
Zebra Z4Mplus Label Printer Logo
29 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
