Hp laserjet 3510 network printer error 51.10
  • 78 Answers
Replace laser scanner assy. follow link
http://webpages.charter.net/dperr/hp_error.htm
Posted on Apr 26, 2014
  • 2692 Answers
SOURCE: how to install hp laserjet p1505n network printer in windows 98
I can not find a win 98 driver for your printer on the HP website. DO yu have the instalation disk that was writen for win 98? If not try installing the printer through  the control panel. Either printers/fax or through install new hardware.The first being the preference. Some of the win OSs have printr drivers already installed.
If this does not work out, then the printer has no drivr available for that version of windows and you ewither have to upgrade to Xp or use a different printer which has a driver for win 98.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us〈=en&product=3435671&
Posted on Jan 02, 2009
SOURCE: Network Printer Problem
In the later HP LaserJet printers the printer has a "Mopier mode" that will provide better print performance on multiple copies. However, if you have "Mopier mode" enabled and you don't have an EIO hard disk installed, you'll get the above message.
Right click on the printer, select "Properties". There should be a "Device Settings" tab. Under that tab, make sure that "Mopier mode" is Disabled at the bottom.
The unit will still print multiple collated copies with that disabled.
Posted on Jan 21, 2009
  • 102 Answers
SOURCE: HP LaserJet 3055 scan over network.
If you have installed the printer using Add printer and faxes then you have just install the printer drivers which will allow you to print over the network.
However if you want to scan over the network than you have to install the complete software of the printer .
If you do not have Software CD than you can download and install the software fom Link below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=1140780&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
brett207
  • 231 Answers
SOURCE: the printer (hp laserjet p2015) appears offline
Press and hol the green 'go' button until the lights flash, (about 4-5 seconds) and release the button,
Wait for the config pages to print out, and then check your network configuration, i.p address, Subnet mask and gateway.
If no network page prints out, you might have a dead Network Interface in the printer.
Posted on May 11, 2010
How to clear error code 49.4c02 error on HP laserjet P3015
Cancell all print jobs in the print que.. shut down computer disconnect USB or Network cabes to printer... turn printer off then back on wait till printer comes to READY then reconnect USB or Network cables ... turn computer back on and print again
Apr 02, 2014 | HP LaserJet 4250n Printer
HP LaserJet P3015 printer 51.10 ERROR
hp laserjet 3510 network printer error 51.10
Oct 12, 2011 | Office Equipment & Supplies
My printer hp laserjet 4350 shows error 49,what could be the cause
Most times a "49" error indicares the need for a firmware upgrade.
If the machine is networked, disconnect the network cable and power the printer off, wait 2 minutes and power it back up. It should reset the error.
BEFORE reattaching the network cable delete the job in the printer queue that caused the error ( Most likely a PDF file).
Go here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=412171&prodTypeId=18972&prodSeriesId=412160&swLang=8&taskId=135&swEnvOID=228#290
and download and install the latest firmware
A workaround is to print the PDF as an image
May 20, 2011 | HP LaserJet 4350 Printer
Model HP LaserJet M4345 MFP The printer displays
You've done everything but replace the formatter.
Can you look at the Event Log? Look for a 79.xxxx error. That is definately a formatter.
Is this a solid error, meaning does it appear when printer inits?
Remove the DIMMs and flash memory and network cable. And reinstall one by one until error reappears.
Do you have another 4345 that you can "borrow" a formatter from?
Jan 11, 2011 | HP LaserJet M4345 MultiFunction Printer
49.4c02 service error in hp laserjet 2300n
HP 2300 ERROR 49.XX
• A critical firmware error has occurred on the printer
• Turn printer off then on
• Disconnect the parallel cable or the network cable
• If message still there when the network cable is disconnected
upgrade firmware in jet direct card and the formatter board
• Bad network cable
• Replace firmware DIMM
• Replace the jet direct card
• Replace formatter board
• Replace engine board
95% of the time it is a PDF that has a font that is not recognized by the printer! If the error is not there when you follow the above, you may have to clear out the print queue.
Apr 23, 2010 | HP LaserJet 2300 Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
''HP Laserjet 4600, Error code 81 0180 E10 1 Error'' the printer does not work. please help !
That indicates that the printer has a network card problem. You can try rebooting/resetting which can clear it but usually means a trip to the hp repair shop.
Jul 09, 2009 | HP LaserJet 4600dn Color Printer
HP Laserjet 2200dn print spooler unable to connect
Have you tried a different driver eg. rpcs or another version of pcl?Have you checked your workstations services app to check if your print spooler is running?Also when you print a config page from the hp it will give you your network details.To eliminate your network grap a crossover cable and connect directly to the printer and test.Let me know.
May 22, 2009 | HP LaserJet 2200dn Printer
Installing hp 3550 printer driver on new OSX leopard system
When I try to print from an access data base to the laserjet color 3500 usb printer.
Tried diff. drivers, diff usb cable, it works for a while but after several test runs the error reapears.
PCL XL error
Subsystem: KERNEL
Error: ColorSpaceMismatch
Operator: VendorUnique
Position: 9
Mar 09, 2008 | HP Color LaserJet 3500 Printer
32 people viewed this question
jasbo
jasbo
