Question about Bose Audio Players & Recorders
Bose Accoustimass Power Surge caused it to stop working
3 Suggested Answers
  • 11 Answers
SOURCE: Problem connecting Onkyo Amplifier to Bose Accoustimass speaker system
This is probably correct as modern equipment uses electronic volume controls rather than potential dividers the range is normally biased towards the bottom end so there is lots of the range that is quiet and a smaller part that is loud.
Unless you find that at the top of the volume range the system does not seem to be loud then it is probably correct. It is not uncommon for modern equipment to clip at 80 / 90% of the volume range. Where as old style equipment with volume pots used to clip at arround 30% of the volume range as it gave the apperance there was loads of extra volume available. In fact all that happened if you turned it up louder was it clipped more and more.
Regards,
Andrew
Posted on Sep 17, 2008
  • 55 Answers
SOURCE: Can a Bose radio get fixed after a power surge?
YES IT CAN UNPLUG THE RADIO ..OPEN IT UP LOOK @ WERE THE POWER CORD COMES INTO THE RADIO SEE HOW BAD IT IS >>>IF IT IS ALL BURNT UP YOU HAVE TO GET AN IDEAR HOW MUCH A REPAIR PLACE WILL WANT>>>>>>>>BUT IT MAY ONLY BE A FUSE IN SIDE YOU MAY GET LUCKY>>>>>>>>>YOU CAN EVEN FIX THAT YOUR SELF WITH A SOLDERING IRON FROM RADIO SHACK OPEN IT UP SEE WHATS GOING ON IN SIDE MAKE SURE POWER IS UP PLUGGED GOOD LUCK
Posted on Feb 20, 2009
Bose AV321 11 remote will not power on or off console remote is ok works on my other BoseAV321 11 console
Do the walkaround --unplug-check antenna wire--unplug is the process because the bose system just slumbers--a power surge is common cause it's not that noticeable
May 29, 2017 | Bose Televison & Video
How do you open the cover to bose accoustimass
Bose Acoustimass is a bandpass cabinet. Needs to be sealed. I recommend to send it to a service center.
Nov 21, 2013 | Bose Lifestyle 12 System
The display is suddenly filled with information (sometimes unreadable). Everything has now stopped working.
From the sounds of it the microprocessor is scrambled, this can be caused by a power surge or thunderstorm, unplug unit, press and hold power button for 60 seconds in an attempt to clear the processor, if this fails this will be a job for a Bose factory trained technician.
Sep 16, 2012 | Bose Wave Radio
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
Error code 10 during sound calibration
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
May 31, 2009 | Bose Lifestyle 35 Series II System
Feb 20, 2009 | Bose Wave Radio
Bose - Custom EQ Error: 10
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
Sep 01, 2008 | Bose Lifestyle 28 System
29 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
