Question about Panasonic NV-FJ620 VHS/S-VHS playback VCR
My VCR plays cassets perfectly, but recently I am facing recording problem. I am unable to record, I am seeing recording caption on my screen. But it is not recording.
    President:
  • 894 Answers
Well I think that the the machines mechanical piece that allows you to record is broken then and needs to be fixed so we perfer DVD players and dvd disc;s instead they are better at recording and have less problems too.
Posted on Aug 16, 2011
When I play DVD's my tv screen gets a rectangle box on it, the VHS is fine, it's just the DVD player.
Yes! you are right, this almost sounds like a captions problem, check the DVD/VCR Combo menu, if it has captions turn it off using your remote.
Mar 17, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Nov 18, 2007 | JVC HR-A592U S-VHS VCR
DVD & VCR Recorder Model ZV450MW8A
My grandmother had the same problem. Whenever you press "timer set" to set the timer, it automatically turns off the VCR and whenever you turn it back on the VCR is locked and it's stuck on DVD. All you have to do is press "timer set" to unlock the VCR side. Then you may have to press "VCR" to switch it back. Hope this helps.
Jul 26, 2008 | Philips Magnavox DVD/VCR Dual Player
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
Unable to record vcr while dvd playing
are you trying to record the dvd or tv or cable channels let me know then i can help
Jan 08, 2008 | Televison & Video
New casset insertion not displaying any image on the screen
JUST BUY A CLEANING CASSETTE AND PLAY TWO OR THREE TIMES AND PLAY YOUR RECORDED CASSTTE.IT WILL BE VERY CLEAR.
REGARDS
SANKAR
Oct 24, 2007 | JVC GR-D370 Mini DV Digital Camcorder
VCR not working for some cassettes
What do you mean by "not able to play my VCR with some cassettes. " Is it that some tapes do not display images? No Video? From your name it seems that you are from India, Assuming that to be so, I also presume that you must be possesing a Multi-System VCR, to play back PAL Tapes from India, and NTSC tapes from the US. And if that is the case, I guess it is a simple problem of resetting the System standards. Please go to the Main menu of your VCR using the Remote, and select AUTO in System (You will be given choices of AUTO, PAL, NTSC 3.58, NTSC 4.43 and NTSC PB PAL. Likewise, it is entirely possible that your Television SYSTEm Standard has been accidentally changed. If it is Multi System TV, Then, again, using the Remote of the TV, select Menu, and then select AUTO in System. In all likelihood your problem should get solved.
May 13, 2007 | RCA VR605HF VHS VCR
VCR won't tape and get no playback
First check how good / bad are your recordings. Take a current / recent recording done after this problem cropped up, and play it back on another VCR - maybe a friend's. If the recording plays back badly- showing the symptoms you described, then the problem is still dirty or worn out Video Heads. If the Recording plays back perfectly on the friend's machine, but plays back badly on your machine, I still suggest that you try cleaning the Heads one more time, and if the problem is not resolved, it is time to trash the VCR. One last question, you say that you have reset the channels. Are the reception channels' images clear? I may be able to give some more suggestions, based on this response.
Apr 17, 2007 | Goldstar GVR-E435 VHS VCR
Picture is jittery and voice is garbled with noise in background
I had the same problem recently with a Panasonic PV - V4521 which has worked for years for me. I tried everything including cleaning the heads with Q-Tips and pure alcohol. Nothing improved. I tried tape head cleaners. Nothing. So finally one day, as I was unscrewing the cables, this VCR fell down onto the bottom of my foot and drew blood. Now remember, I had been trying to fix this thing for at least 10 days.
So, I dragged it up and pounded the top of the VCR until the top caved in. Then, I opened my front door and tossed it so hard against the floor of my patio that pieces went flying everywhere. I gathered up the pieces and the twisted VCR, put it in a box, and tosses it real hard into the dumpster. It's fixed. I have no more problem with it.
Jun 27, 2006 | Panasonic PV-V4021 S-VHS VCR
Panasonic NV-FJ620 VHS/S-VHS playback VCR Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
